post #1 of 5 (permalink) Old 06-17-2007, 11:08 PM Thread Starter
wastings's Avatar
Hi everyone,
I am in the mood to ad a cb radio to my gl1500 and have looked at the JMCB-2003 Installation/Integration Kit for Honda GL-1500. Or should I go with used factory cb off ebay? In need of all your expert opinions .It isa chunck of change no matter how you look at it.
thanks
larry
stand her on her head and you will find they all have bad breath.
1993 goldwing aspencade
Larry..... KB8SES
wastings is offline
post #2 of 5 (permalink) Old 06-18-2007, 12:17 AM
There's no doubt you could install a used Honda CB as long as you got all the parts. The Helm Honda manual shows the CB wiring and installation. The aftermarket system you mention looks pretty slick too.
I think it breaks down to the cost and effort. The Honda CB is the cleanest way to go as it integrates in to the audio system and is a nice looking clean installation without complicating the handlebars. The JMCB unit is cheaper than a used Honda CB and would be easier to install. It might be difficult to get the handlebar clamp attached to the ASPY's handlebar without cutting away the handlebar cover which might not look too good.
post #3 of 5 (permalink) Old 06-18-2007, 02:08 AM
wexy's Avatar
The j&m set up is excellent and it also has an input for a MP3 or ipod .It will work out way cheaper than trying to buy an original off ebay ,The problem with the ebay OEM ones is that 9 times out of 10 they only sell you the actual CB and not the wiring look and the PTT button set up ,Go with the J&M,if you sell the bike you can take it off in a few minutes and put it on your new bike ..cheers Ciaran
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
post #4 of 5 (permalink) Old 06-18-2007, 04:20 PM Thread Starter
wastings's Avatar
I will be buying a gl1500 setup ,the best price i could find was $529.00 plus i still need to buy an antenna. so here is what the web site says about the system for those interrested.
JMCB-GL15 - GL 1500 CB/Weather Radio Kit
A complete JMCB-2003 installation/integration kit for Honda GL-1500. This new 40 channel CB/Weather radio kit integrates with the factory-installed Honda audio system exactly as the Honda CB did for this model. The unique, J&M-designed, mounting bracket allows for the correct position of the unit over the handlebars to allow easy access to the PTT lever, even while holding in the clutch. You can switch the CB receive audio to the fairing speakers or to the helmet headsets by using the bracket-mounted control switch. This CB addition does NOT change the type of headsets and/or headset hook-up cords required for the GL-1500 as this unit just plugs into the back of the Honda stereo/intercom system and has no impact on the standard 5-pin headset leads that were included with these Gold Wing motorcycles. This kit includes everything you need to mount the JMCB radio on your GL-1500 and integrate it with the factory installed audio system, with the exception of the CB antenna, which is a separate item that is available from your local Honda dealers.
hope it works
Larry..... KB8SES
wastings is offline
post #5 of 5 (permalink) Old 06-18-2007, 04:47 PM
Hey Wastings from Hastings!You did it the way I would have done it*, not the cheapest or easiest but the cleanest. The Axe was right about cost but when you're done your bike will look factory.
*[suP]not necessarily the brightest but definitely the hardest way.[/suP]
ECU question for GL1500. Are they all compatible with any year GL1500? kemoloney Goldwing Technical Forum 6 11-01-2011 05:53 AM
2000 GL1500 SE clutch basket in a 1995 GL1500 SE mosesm Goldwing Technical Forum 7 07-06-2010 05:23 PM
Interchangeable body parts 1988 GL1500 and 1991 GL1500 Aspencade guywithsidecar Goldwing Technical Forum 2 08-12-2007 03:01 PM
Wanted: GL1500 Final Drive, 88 or 89 GL1500 Drive Flange, GL1500 Driveshaft tuntrep For Sale/Wanted Forum 0 07-09-2006 08:06 AM
