4Likes
post #1 of 12 (permalink) Old 01-08-2017, 12:27 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
air compressor usage
Hi all. now that I know my sir ride works, how else would I use it? I see it has an outlet in the right hand saddlebag... could I use this to inflate my own tires? If so, what kind of adapter would I need to do that? What else can it be used for?
thanks
edromero is offline
post #2 of 12 (permalink) Old 01-08-2017, 01:37 PM
I had no idea a fz6r had that so I wouldn't know.
[SIGPIC]
post #3 of 12 (permalink) Old 01-08-2017, 01:43 PM Thread Starter
edromero's Avatar
Year: 1990
Make: gl 1500
Model: gl 1500
you could probably surmise that most likely scenario is that I just got my wing (2 days ago) and just hadn't updated the profile details.
edromero is offline
post #4 of 12 (permalink) Old 01-08-2017, 02:41 PM
Model: '92 GL1500
I have the same on my 1992 Aspencade. You can purchase a 10ft hose from anyone who sells acessories for your bike. You can definitly use it to inflate tire on your bike. The handbook gives instructions to do so.
Happy Riding!!!
Wingrider59
Wingrider59 is offline
post #5 of 12 (permalink) Old 01-08-2017, 03:32 PM
It does help to have it in your profile but please in the future reference what you are working on in your post.
[SIGPIC]
post #6 of 12 (permalink) Old 01-09-2017, 12:22 AM
Certified Slacker
Year: 94
Make: Wing of course!
Model: 1500 SE
Yes, it will slowly re-inflate a tire you have made an emergency plug repair to.
Time limits apply on compressor use-- for heat buildup and battery drain.
Many self-rescue riders carry a separate, faster 12volt compressor just for the tires...~$25
AZgl1800 and flylow like this.
Certified Slacker is suffering under the delusion of being an expert... We need more Voltage! IGOR- throw the 3rd switch!!
Not the 3rd switch Master!!
Aloha Tom is offline
post #7 of 12 (permalink) Old 01-09-2017, 08:02 AM
I personally carry the Slime air compressor. comes in a very small zipper case and has a long power cord with a stardard NEMA rubber two wire trailer type connector. i have the mating connector wired direct to the battery thru a fuse, this connector just barely hangs thru the opening in the side cover.
easy to power it up, and it works like a champ. it will air up my Michelin car tyre from 30# to 55# in about 5 minutes. did that once just to see. then i let the air down in stages until i was happy with the ride.
Kyle and flylow like this.
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #8 of 12 (permalink) Old 01-09-2017, 09:10 AM
joe in calif's Avatar
Model: 1997 SE
If you use it to op off your tires make sure you disconnect the air hose after use. If I remember right the compressor will not work to adjust your rear shock if the air hose is connected.
IF YOUR BORN ONCE YOU WILL DIE TWICE
IF YOUR BORN TWICE YOU WILL DIE ONCE
A NEW START ON 1/20/2017
joe in calif is offline
post #9 of 12 (permalink) Old 01-09-2017, 12:32 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
thanks
You COULD use it to fill a high pressure storage tank that's connected to a pneumatic ram under the pillion seat. That way, if there is too much noise coming from the back, you could hit a switch, dump the air into the ram, kicking your passenger straight off the back. Think James Bond ejector seat!
Not that I would ever do such a thing, but you did ask WHAT else it could be used for!
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #10 of 12 (permalink) Old 01-10-2017, 12:06 AM
Certified Slacker
Year: 94
Model: 1500 SE
Im almost certain filling a high pressure tank would exceed not only the design limits but the practical functionality of said on-board compressor,
causing its life functions to cease with a most horrifying noise.
GL1500 Air Compressor usage - outlet Button Nyme Goldwing Technical Forum 6 05-28-2012 08:07 AM
Air Compressor dr_opus2001 Goldwing Technical Forum 3 08-14-2009 07:46 PM
Air compressor oharaLTD Goldwing Technical Forum 7 05-12-2009 05:12 PM
Air Compressor and Air Supply Hose Kikker Feedback for Hondas Goldwing Team 5 04-11-2009 11:11 AM
air compressor runs but no air to shock denziel56 Goldwing Technical Forum 4 02-23-2009 06:31 PM
