4Likes
  • 1 Post By basher
  • 3 Post By redwing52
post #1 of 6 (permalink) Old 01-09-2017, 03:09 PM Thread Starter
Electric handbrake
Hi, looking to install an electric handbrake on to my current trike build and was thinking of using an electric windows motor to pull the 2 cables to apply the brake but I'm unsure what type of motor would be best.
Any advice please.
Cheers Bash
basher is offline
post #2 of 6 (permalink) Old 01-09-2017, 04:11 PM
CrystalPistol's Avatar
Lehman used what looks like a Mustang II or Pinto handbrake ratcheting lever.
I see UK ..... needed for MOT?
Will a hydraulic lock not pass?
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
'74 Triumph T-150V Trident
...( It's a Triple )
CrystalPistol is offline
post #3 of 6 (permalink) Old 01-09-2017, 04:37 PM Thread Starter
Has to be completely separate from the hydraulic system for the UK mot.
Because I'm doing an anniversary trike were in usually put the parking brake lever is not possible as the foot rest moves so trying to think of an electric system to bypass the problem.
Cheers Bash
CrystalPistol likes this.
basher is offline
post #4 of 6 (permalink) Old 01-09-2017, 05:37 PM
Maybe a linear actuator?
http://www.ebay.com/itm/like/2723502...&ul_noapp=true
DaveO430, Ken Bergen and RKB53 like this.
redwing52 is online now
post #5 of 6 (permalink) Old 01-10-2017, 06:10 AM Thread Starter
That looks just the job. Any idea how much pull it would need to operate the handbrake?
And does it need to go all the way back in to operate properly.
Cheers Bash
basher is offline
post #6 of 6 (permalink) Old 01-12-2017, 07:18 PM
Pure Texas's Avatar
Make: Goldwing
The liernear is strong enough to break anything it's hooked to,some kind of limit switch would need to be in line somewhere,you might be able to put a strong spring in to hold the brakes and set it to just pull on the breaks to hold the trike.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is online now
Goldwing Trike Handbrake clippy Goldwing Technical Forum 14 05-18-2015 05:41 PM
Handbrake MrHill06 Goldwing Technical Forum 5 07-16-2014 07:05 PM
1981 GL1100: Handbrake is Leaking Brake Fluid johnnynogood Goldwing Technical Forum 2 04-08-2011 12:15 PM
Just think, this is all electric AZgl1800 Miscellaneous Forum 12 12-19-2010 07:11 PM
Handbrake doesn't light up brake light Goldwing1981 Goldwing Technical Forum 4 04-25-2008 08:51 PM
