CLICK HERE |
Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 83 Aspencade- brakes dragging- fluid return port? |
| 83 Aspencade- brakes dragging- fluid return port? | Rate Topic |
| Author | Post |
| Posted: Mon Apr 18th, 2011 01:48 am | 21st Post |
It seems to go straight in, if at any angle it is very slight. I don't think the hole being slightly larger would hurt anything.
____________________ I am doing the best I can so don't give me any crap. Honorary Wild Rhino Darksider #304 the force is strong in this one. |
| Posted: Tue Apr 19th, 2011 12:18 am | 22nd Post |
You won't see it inside the cylinder bore. When you know where it is, you still won't see it! I took mine apart because my rear brake had siezed. I kept poking with a wire from a wire brush until I found it. It was blocked with gunk. Just make sure the wire is small enough in diameter. I don't think you would find it with a dental pick-type tool. Good luck.
____________________ Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer. George Santayana. |
| Posted: Tue Apr 19th, 2011 12:31 am | 23rd Post |
Tonight I go into the rear caliper to find the hole also. wish me luck! Here's hoping there's some hair around mine and it's easier to find LOL! I do know that if you drill it out your caliper will make a nice paperweight! It is this tiny for a reason and if it is too big you will not be able to retain the pressure needed to stop.
____________________ Twice bitten Once burnt! |
| Posted: Tue Apr 19th, 2011 12:50 am | 24th Post |
ive boiled 5 times now and have been using a small sowing needle and yet to no avail. i will keep trying until i sucseed!!!
____________________ Honda NightHawk 250 87'? Hondamatic 450 81' Fixed and sold multiple Vintage Honda 175's and 350's Fixed and sold 9-10 Yamaha XS650s 2003 Honda Shadow Ace 750 (current) 83 Goldwing Aspencade (current)Fixing and Restoring? Making the mile + keeping the rubber side down. |
| Posted: Wed Apr 20th, 2011 03:04 am | 25th Post |
Allrighty good news. after boiling 5 times and still no hole i was beginning to wonder if it had completely sealed up, actually i still believe that. i went to harbor freight and found a pack called mini drill bits, they are very small, i think i used a .8?. anyways with some cutting oil and some extremely slow drilling with the drill press i drilled through. i put the rear mc back on the bike, mighty vacumed for ten minutes and bam the brakes are better than new (this is after i rebuilt the calipers as well). The tiny bit was just enough. if i can figure out how to download a pic i will now, if not tomo in the am. Thanks for all of your help and keep on wingin'!
| Posted: Wed Apr 20th, 2011 03:58 pm | 26th Post |
Good for you Willis! Your persistence paid off.
____________________ Larry "Only two things are infinite... the universe and human stupidity; and I am not sure about the former" -- Albert Einstein I'm sure you believe you understand what you think I said but I'm not sure you realize that what you think you heard is not what I meant.
| Posted: Wed Apr 20th, 2011 08:02 pm | 27th Post |
Allrighty good news. after boiling 5 times and still no hole i was beginning to wonder if it had completely sealed up, actually i still believe that. i went to harbor freight and found a pack called mini drill bits, they are very small, i think i used a .8?. anyways with some cutting oil and some extremely slow drilling with the drill press i drilled through. i put the rear mc back on the bike, mighty vacumed for ten minutes and bam the brakes are better than new (this is after i rebuilt the calipers as well). The tiny bit was just enough. if i can figure out how to download a pic i will now, if not tomo in the am. Thanks for all of your help and keep on wingin'! Attachment: 2011-04-19_20-18-52_860.jpg (Downloaded 35 times) Last edited on Thu Apr 21st, 2011 01:44 pm by Willis ____________________ Honda NightHawk 250 87'? Hondamatic 450 81' Fixed and sold multiple Vintage Honda 175's and 350's Fixed and sold 9-10 Yamaha XS650s 2003 Honda Shadow Ace 750 (current) 83 Goldwing Aspencade (current)Fixing and Restoring? Making the mile + keeping the rubber side down. |
| Posted: Wed Apr 20th, 2011 08:05 pm | 28th Post |
I was referring to the master cylinder- I had good luck with drilling a tiny hole in the fluid return port. Have any lu
| Posted: Wed Apr 20th, 2011 08:08 pm | 29th Post |
You may need to resize the picture. The attachment feature works for me at the bottom of the message page. Attachment: DSC00002fd.jpg (Downloaded 37 times)
____________________ Happy Trails http://www.bluegrasshighway.com http://www.live365.com/index.live?curl=%2Fstations%2Febanjo I'm looking for a 4 wheeler Triumph TR5 or TR6 fixer upper. |
| Posted: Wed Apr 20th, 2011 11:00 pm | 30th Post |
I recently had to put a kit into a clutch master cyclinder, and front brake master cylinder, for an 86 aspy and the return hole in both, wasn't that good. I got a spray can of disc brake cleaner, and with a plastic straw, attached the nozzle I was able to clean the hole, and everything else with it. It even cleaned the gunk off the little window. it dries quickly, and doesn't leave any residue. good luck,
____________________ Robbie, 1986 Gl1200 Aspencade (Mariah) 'I ride not to get there, but to go' |
| Posted: Wed Apr 20th, 2011 11:20 pm | 31st Post |
you are lucky that the hole unclogged that easily! maybe disc brake cleaner is the answer.
| Posted: Thu Apr 21st, 2011 12:00 am | 32nd Post |
Willis, Make sure, to prevent further issues, you replace the hose from the resovoir to the MC. Check this out... read post #11. http://www.goldwingfacts.com/forums/forum1/92460.html Tim.
____________________ **** Proud new father of a 91 1500 Aspencade **** 1) Experience is something you don't get until after you need it. 2) A closed mouth gathers no foot. 3) You aren't learning much when your lips are moving. 4) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER?? |
| Posted: Thu Apr 21st, 2011 07:40 am | 33rd Post |
Awesome!! Glad you worked it out and thanks for the info! Happy I was wrong! Mine are quite dirty had to run out and buy some cleaner gunk wish me luck!
| Posted: Thu Apr 21st, 2011 01:43 pm | 34th Post |
Thanks 1 million!
| Current time is 02:38 am | Page: 1 2 |
| Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 83 Aspencade- brakes dragging- fluid return port? | Top of Page |
