GL1000 FUEL PROBLEM?  Rate Topic
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2
Author Post
 Posted: Thu Feb 9th, 2012 07:05 am 21st Post
PMQuoteReply
kingarthurup
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Thanks,... well I am pretty handy, and I have a good supply of tools... any more suggestions?
 Posted: Thu Feb 9th, 2012 07:47 am 22nd Post
PMQuoteReply
SMEDEN(=the blacksmith)
Goldwing: GL1000, GL1800
Mileage: 170.000 KM on GOLDWING ...
Status:
Offline
Mana:
back to top
The ignition TIMING , (not the dwell angle) is eaysiest to do with a stroboscope lamp and the "timing plug".
Maybe the timing plug is difficult to find ,because when i ordered 3 of them ,3 years ago , they told me it was the last ones:sobbing:
____________________
 Posted: Thu Feb 9th, 2012 01:14 pm 23rd Post
PMQuoteReply
dingdong
Goldwing: GL1000, GL1500 Aspencade
Mileage: 76=72k / 93=59k
Status:
Offline
Mana:
My Gallery
back to top
Unless I missed it, no one has suggested that the mechanical timing advance could be binding up. Except for the fuel smell, the symptoms are exactly what would occur with this problem.
Tom
Black 93 1500 Aspy
Yellow 76 1000
Member: Wild Rhinos, Oklahoma Chapter
Women will never be equal to men until they can walk down the street with a bald head and a beer gut, and still think they are sexy.
"You have enemies? Good. That means you have stood up for something, sometime in your life."
Winston Churchill
Double Darksider
Austone Taxi & Michelin Pilot Activ
 Posted: Thu Feb 9th, 2012 02:30 pm 24th Post
PMQuoteReply
Status:
Offline
Mana:
back to top
To "dingdong"
That was one off my points :ALWAYS be sure your ignition works correct !
By the way , one of my friends over here is also nichnamed dingdong , because his work is to "tune" church bells ! - and as some us will think , he havent always used the rigth earprotection
 Posted: Thu Feb 9th, 2012 02:48 pm 25th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
dingdong wrote: Unless I missed it, no one has suggested that the mechanical timing advance could be binding up. Except for the fuel smell, the symptoms are exactly what would occur with this problem.
You're right. Could be a bind not allowing one of the fly-weights to swing out, or could be a broken spring keeping one out. I'm with the blacksmith on the approach to it. I've been fooled to many times by the inter-relationship of the not-so-obvious "carb" problems actually being ignition problems. He could have both being issues, but I'd start knocking-down the "could be" to the known in a "ignition first" order. Ignition checks are easier to get out of the way and eliminate as contributing to the problem. Visual inspection goes a long way in eliminating a lot of them.
"They're gonna make it look like suicide."
Hunter S. Thompson, one day before his death.
 Posted: Thu Feb 9th, 2012 03:09 pm 26th Post
PMQuoteReply
Status:
Offline
Mana:
back to top
CaptainMidnigth85 is correct !
I have seen many carbs on bikes and cars "ruined" because of faulty ignition !
And before starting on the carbs , you ALSO need to be sure that compression is correct , (valves /rings and-and )and to messure this correct you need to do a leak test when the engine is hot !(and not just an ordinary compression test ).
- AND you must also be sure that the camshaft timing is ok !!
 Posted: Thu Feb 9th, 2012 04:13 pm 27th Post
PMQuoteReply
kingarthurup
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
How do I go about checking the points?... I have inpected the wiring, and it is practically new.
 Posted: Thu Feb 9th, 2012 04:46 pm 28th Post
PMQuoteReply
newday777
Goldwing: GL1500 SE
Mileage:  1999 SE @57,000 7/2010 now 91,000 ...
Status:
Offline
Mana:
My Gallery
back to top
kingarthurup
Do you have a repair manual for your bike yet? If so which one, Clymer or Honda's?
They will give step by steps on just about all you'll need to do.
You also need to replace the plug wires, spark plug caps and the spark plugs. They get corrosion in the wires and the caps crack and leak. The wire can be bought at some M/C shops that carry a roll of it. I bought wires(6'), 4 caps(NGK), and 4 NGK plugs for $30 a year ago.
Stu
John 14:6
CMA Wings of Eagles-Escondido CA SAN DIEGO
Patriot Guard Ryder
1999 GL1500 SE(@57k) The LORD provided this through a friend's wish to leave it to me
I'm blown away! Dan beat me there and is enjoying the real Heaven. Remember to be there for your friends and thank them for being your friend.
Previous bikes
1983 ASPENCADE(Barn find) bought 7/08 & restored from 13 yr neglect by po @ 35,595mi,
now given to a pastor to enjoy the blessings @ 62,000
25 Yrs. of Abstinance(no bike) - Raising kids, now a PA PA
76 CB750K(new) w/Golden Lab Cody, rode w/me 35k miles & 5 times X country in 3 yrs sold @ 45k
75 CB750K(new) 9,000 mi http://www.motorcycleclassics.com/MC-Dispatch/Royce-Thiessen-Honda-CB750.aspx
74 CB450(new) 9,000 mi first yrhttp://www.bikez.com/motorcycles/honda_cb_450_disc_1974.php
 Posted: Thu Feb 9th, 2012 04:50 pm 29th Post
PMQuoteReply
newday777
Goldwing: GL1500 SE
Status:
Offline
Mana:
My Gallery
back to top
http://www.randakks.com/TechTips.htm
Stu
John 14:6
Patriot Guard Ryder
Previous bikes
 Posted: Thu Feb 9th, 2012 04:54 pm 30th Post
PMQuoteReply
scotterichmond
Mileage: 48,000 40,000
Status:
Offline
Mana:
My Gallery
back to top
this I how I do points:
Attachment: static split timing.txt (Downloaded 3 times)
If you can't afford to do it right the first time,
You sure can't afford to do it the second time.
Life is a long series of choices, some good some not
 Posted: Thu Feb 9th, 2012 05:04 pm 31st Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
...a test-light of some sort is a good start. Could buy one inexpensively or even make one up in short order. Worry about advance timing later, as you'll be pulling the points plate and checking the advancer visually and by hand to see if it has any obvious problems of freely moving its parts.
Definately need a manual. Check your PM's. There are do's and don't's as far as lubing and such. You don't want any 3-in-1 oil anywhere near them points.
Remember to look at those resistors if you haven't already.
 Posted: Thu Feb 9th, 2012 05:43 pm 32nd Post
PMQuoteReply
dingdong
Status:
Offline
Mana:
My Gallery
back to top
SMEDEN(=the blacksmith) wrote: To "dingdong"
My last name is Bell and no matter where I go someone always ends up nicknaming me dingdong.
Tom
Black 93 1500 Aspy
Yellow 76 1000
Winston Churchill
Double Darksider
 Posted: Wed May 9th, 2012 09:47 pm 33rd Post
PMQuoteReply
kingarthurup
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Hey guys... more fodder for the mill!...LOL...
I have my bike at a small engine shop and he tells me that I don't have spark to my front cylinders... would that explain my above problems?... and what do I have to get?... an new coil?
God Bless you Dudes! :waving:
 Posted: Thu May 10th, 2012 12:30 am 34th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Well, got to make sure the points are set correctly and firing off. Got to make sure the point wires are plugged-in there at the battery bo area (bullet connectors), that the coils are getting the voltage allowing the primary to fire-off the secondary to the plugs.
Swap the point wires down around the battery box to see if it's a coil that may be bad or if it's a point issue.
 Current time is 02:41 am Page:  First Page Previous Page  1  2
 Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > GL1000 FUEL PROBLEM? Top of Page
