Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > GL1800 Goldwing Trike Build with Pictures
GL1800 Goldwing Trike Build with Pictures  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  ...  2  3  4  5  6  7  8  9  10  11  12  ...  Next Page Last Page
Author Post
 Posted: Sat Jan 28th, 2012 11:51 pm 121st Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Another part I didn't show but I will when I put every thing back together is removing the front wheel assembly. Mabe someone wants to just do that so I show details on that on reassembly.
 Posted: Sat Jan 28th, 2012 11:55 pm 122nd Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
There is a allen bolt on the end of the fork tube that will have to be removed. Do this now.
Attachment: Fork 016.JPG (Downloaded 220 times)
 Posted: Sat Jan 28th, 2012 11:58 pm 123rd Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Here is another view showing the allen screw with the allen wrench on it.
Attachment: Fork 019.JPG (Downloaded 218 times)
 Posted: Sun Jan 29th, 2012 12:01 am 124th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Next is the removal of the dust cover. This can be accomplish by placing a flat tip screw driver under the lip and prying it loose. It will come off easy.
Attachment: Fork 017.JPG (Downloaded 219 times)
 Posted: Sun Jan 29th, 2012 12:05 am 125th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Stand the fork on the end and you'll see a inner locking spring that holds the seal in place. Take a small screw driver and grab it in the open slot and pry toward the fork and it will pop loose.:?
Attachment: Fork 018.JPG (Downloaded 219 times)
 Posted: Sun Jan 29th, 2012 12:21 am 126th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
After you remove the inner spring you can take the top nut off the top of the fork. The spring won't have alot of tention on it so don't worrie about it all flying out. You'll turn it upside down to finish drainning the fork oil out in a bucket. With a few slides back and forth of the fork tube the seal will come off along with the bushing. Watch how it comes loose to reverse the way it goes back in. You'll have a bushing, a washer then a seal, the clip and last the dust cover. The inside you'll have the inner fork loading rod assemble, fork spring then the spring washer and last the cap nut.
The last part is to put the allen bolt back in the bottom.
 Posted: Sun Jan 29th, 2012 12:35 am 127th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
On the right fork you go throught the same preceedure as on the left side. The only different is you'll have to perload the piston that is on the right side before you place the top cap on. The way I did this is to pour some fork oil into the sleeve of the fork tube with the main spring out. Pull the small rod out and you'll hear the piston filling as you're pulling up. Push it back down and do the same thing again untill you clear all the air out and you have a good strong pull with no air. Turn the fork upside down a remove any extra oil in a bottle. It won't drain what is inside the valve that you filled. Measure the 16.5 oz of fork oil in a measuring cup and pour into the top of the tube. Then place the fork spring in and the washer and last the cap.
 Posted: Sun Jan 29th, 2012 12:40 am 128th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
After installing the left tube in the triple tree you can attach the anti dive assemble back on and them remove the top cap and pour 17.5 oz of fork oil into the tube. You'll see some bubbles as the dive valve is refilling with oil. This is why the left side takes one more once of oil than the right side.
 Posted: Wed Feb 1st, 2012 08:58 pm 129th Post
PMQuoteReply
glennuk
Goldwing: GL1500, GL1800
Mileage: 27.000 miles
Status:
Offline
Mana:
back to top
Looking good keep up the good work .hope to get back on to my trike project this weekend (see glennuk) hope to get things back to normal
Glennuk
____________________
Glenn/uk Germany,Poland,Holland,Slovakia,Croatia,Slovenia,Austria,USA,Hungary,Ireland, chec rep,Estonia,Latvia,Lithuania,Romania on a 1988/1500 115.000 miles and rising/new 1800 start again,Italy,Switzerland,Belgium,France,Nurburgring ,Bosnia ,Montenegro ,Luxembourg ,
 Posted: Thu Feb 2nd, 2012 01:50 pm 130th Post
PMQuoteReply
SCB
Goldwing: GL1500 Aspencade
Mileage: 79500 ...
Status:
Online
Mana:
My Gallery
back to top
Cobra 1800 wrote:
Now that all the nuts are out of the way:ROFL: and the fork tubes are out you now can tap the top just with the bottom of the hammer and the lower tree will fall out. Here shows the tree out and laying on the floor.
I missed any description for the wire, is this for ABS?
Oh, btw, excellent thread!!!
The day the Lord created hope was probably the same day he created Spring.
 Posted: Thu Feb 2nd, 2012 10:45 pm 131st Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
No SCB, The wire is for the turn signal cancel switch and it runs down the tube of the triple tree.
I'll try to remenber to take another picture this weekend and show the rubber cover it's under
 Posted: Thu Feb 2nd, 2012 10:49 pm 132nd Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
thanks glennuk,
I'll have to look that up and watch your build
 Posted: Sun Feb 5th, 2012 08:35 pm 133rd Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
I ordered new brake pads and K&M air filter to work on this weekend but didn't come in. I ended up doing income tax this weekend and my Honey Do List.:kissing:
Anyone know what I mean??
 Posted: Sun Feb 12th, 2012 10:05 am 134th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
I work on the front end Saturday putting on the brake pads and calibers. There was two screws under the plastic that goes to the triple tree I had to put back in and it took me two hours on that! :sadguy:
Have you ever had those days where it's easy to get them out but you can only get a finger tip on it to put them back on?
 Posted: Sun Feb 12th, 2012 10:14 am 135th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
I guess it's just one of those days in the Man Cave!! I took off the bolts to get to my air cleaner and a little mouse built him a home on the top of the filter!!:ROFL:
When you set your bike up trying to build the trike you have some unwanted guess try to move in. Good bye little buddy!!:waving:
Back to the project, I finally got the old filter out and replaced it with the K&N filter. Took it down the street for a test ride to see how it cornered after placing the sway bar. Went GREAT!!!
 Posted: Sun Feb 12th, 2012 06:49 pm 136th Post
PMQuoteReply
Lightin
Mileage:
Status:
Offline
Mana:
back to top
Test riding !!!!!!!!:applause::applause::claps::action:
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
 Posted: Tue Feb 14th, 2012 04:58 am 137th Post
PMQuoteReply
Cobra 1
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Are you going to build it all yourself or use a kit such as Champion trike Of Cal?
 Posted: Tue Feb 14th, 2012 01:39 pm 138th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Cobra 1,
I have started with a body I bought from Skip  that was for a 1500 Goldwing and modified it to work on the 1800 Goldwing. As in prior pictures I re-glass the front and top over again to make it fit. I welded the frame and swing arm from scratch. I used the same principal of sprint car that use rod end. The price of a Champion kit is around $8,500.00 and so far I have around $1,900.00 in this build.
I have the paint included in this price. I will custom paint it with candy blue. Hope this answered your questions
 Posted: Tue Feb 14th, 2012 05:36 pm 139th Post
PMQuoteReply
skip20
Goldwing: GL1500, GL1500 SE
Mileage:
Status:
Offline
Mana:
back to top
WOW, When do we get to see that Candy Blue paint job?:weightlifter:
GWRRA 78111
PGR 255645
1st Bike Honda Dream 150 Dream Bought in '68
1st GoldWing GL1100
1993 Gl1500A Trike Build SOLD
To many projects to finish
 Posted: Tue Feb 14th, 2012 07:49 pm 140th Post
PMQuoteReply
Cobra 1800
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
back to top
Skip,
That is aways off for now. I tore everything back down getting ready to sand and prime the frame and axle. That will be a couple weekends
 Current time is 02:50 am Page:  First Page Previous Page  ...  2  3  4  5  6  7  8  9  10  11  12  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > GL1800 Goldwing Trike Build with Pictures Top of Page
