CLICK HERE |
| 1979 gl10000 | Rate Topic |
| Author | Post |
| Posted: Mon Feb 6th, 2012 06:15 am | 21st Post |
the rpms were working fine before I did the spark plugs. It wouldn't go past 6 after I replaced the spark plugs and caps today. Tthats why I was thinking it might be something with the plugs. The bike ran good after I put in a new battery.
| Posted: Mon Feb 6th, 2012 06:20 am | 22nd Post |
The old caps have resisters in them. Did you replace them with the same kind?
____________________ Happy Trails http://www.bluegrasshighway.com http://www.live365.com/index.live?curl=%2Fstations%2Febanjo I'm looking for a 4 wheeler Triumph TR5 or TR6 fixer upper. |
| Posted: Mon Feb 6th, 2012 06:22 am | 23rd Post |
Yeah exzact same as the 1 in I matched them at a bike store.
| Posted: Mon Feb 6th, 2012 06:24 am | 24th Post |
You will get it going, at least you know it runs.
| Posted: Mon Feb 6th, 2012 06:26 am | 25th Post |
Yeah appreciate the help. Play around with her tomorrow. Thanks again everybody.
| Posted: Mon Feb 6th, 2012 10:26 pm | 26th Post |
I checged all my gaps on the plugs there all good. So I took off my radiator and cover to belts and they look like they brand new so now I don't know what to do. The bike still won't go past 6000 rpms and deffinatly lost a lot of power
| Posted: Mon Feb 6th, 2012 10:40 pm | 27th Post |
Did someone write down what mileage the belts were changed? Sometimes written under the cover somewhere. You can't tell by looking at them. Probably a carb problem, sticky slides, blocked jets. ????
| Posted: Mon Feb 6th, 2012 10:44 pm | 28th Post |
The reason I suspect they were done recent cause the marks he put on the pully look really fresh still. and 2 bolts r missin next to the middle pully. Would replacing the plugs and caps make carberater act up now. When she was runnin fool rpms before the plugs.
| Posted: Mon Feb 6th, 2012 10:53 pm | 29th Post |
Still think it is some loose debris in the carbs from sitting so long. But it could be bad coils. Have you checked if all the plugs are getting a spark? Pull each wire while the motor is running and see if there is a change in rpm.
| Posted: Wed Feb 8th, 2012 10:31 pm | 30th Post |
hyphy801 wrote: the rpms were working fine before I did the spark plugs. It wouldn't go past 6 after I replaced the spark plugs and caps today. Tthats why I was thinking it might be something with the plugs. The bike ran good after I put in a new battery. OK. Be logical. If it was fine before you did this and is not now, something in what you did, or the parts you used, is wrong. So first, using what you have there. Run the engine. With insulated pliers, pull one ignition lead off at a time and see if the revs drop. If so, next step. In that lead, use an old but good plug in the cap. Hold the plug with insulated pliers (or for a bit of fun get your mate to hold it! If you don't get a spark from the used plug then it's your new cap; if you do, then it's the plug. It's not unknown for new plugs to be faulty. Repeat for the other three. Last. Trust Me On This. Buy a length of (from memory 3 or 4mm) brass rod, cut 4 pieces the same length as the resistors in the caps. Use these in place of the resistors. Your ignition system will be so thankful to you for doing that , that it will now give you a spark to light up the sky....or something like that.
____________________ 1976 GL1000 'The Swan' - from an ugly ducking.. 1979 GL1000 'Black Bess'- original. wingformation on http://www.wingovations.com |
| Current time is 03:12 am | Page: 1 2 |
| Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 1979 gl10000 | Top of Page |
