| 1200 teardown | Rate Topic |
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: 1 2 3 4 5 6 ... |
| Author | Post |
| Posted: Sun Aug 14th, 2005 06:29 pm | 1st Post |
folks wanted to see pics, so heres some Attachment: goldwing rebuild 026 (Small).jpg (Downloaded 1361 times)
____________________ 87 GL1200 Interstate(reborn |
| Posted: Sun Aug 14th, 2005 06:30 pm | 2nd Post |
and Attachment: goldwing rebuild 027 (Small).jpg (Downloaded 1164 times)
| Posted: Sun Aug 14th, 2005 06:31 pm | 3rd Post |
you can see the mess the leaking shift shaft seal made. Attachment: goldwing rebuild 032 (Small).jpg (Downloaded 1165 times)
| Posted: Sun Aug 14th, 2005 06:57 pm | 4th Post |
Just what you wanted to do with all your spare time huh! Keep up the good work! Bob
____________________ 83 GL1100 Aspencade |
| Posted: Sun Aug 14th, 2005 08:19 pm | 5th Post |
Will you be splitting the cases as well? Vic
____________________ http://www.gl1200goldwings.com/ A place for GL1200's to gather. |
| Posted: Sun Aug 14th, 2005 10:21 pm | 6th Post |
uhuhh... Attachment: goldwing rebuild 045 (Small).jpg (Downloaded 1118 times)
| Posted: Sun Aug 14th, 2005 10:23 pm | 7th Post |
broken second gear shift dogs, just floating around..... Attachment: goldwing rebuild 044 (Small).jpg (Downloaded 1058 times)
| Posted: Sun Aug 14th, 2005 10:24 pm | 8th Post |
and the gear, hope you can see this. Attachment: goldwing rebuild 049 (Small).jpg (Downloaded 1055 times)
| Posted: Sun Aug 14th, 2005 10:25 pm | 9th Post |
AZWinger wrote: Just what you wanted to do with all your spare time huh! keeps me out of the bars.
| Posted: Sun Aug 14th, 2005 10:27 pm | 10th Post |
What does Honda call for to seal the case halves? I suppose I could go look but the book's out in the shop and it's 93F here today. On the Continental and Lycoming flat fours it was common practice to use a thin coat of sealer and lay a thin silk sewing thread along the case flange, the thread would squash out and really sealed things up nice, never a leak.
____________________ If you can't ride, fly or sail it, why bother? 2001 Goldwing 1800 Paul W. |
| Posted: Sun Aug 14th, 2005 11:27 pm | 11th Post |
exavid wrote: What does Honda call for to seal the case halves? I suppose I could go look but the book's out in the shop and it's 93F here today. On the Continental and Lycoming flat fours it was common practice to use a thin coat of sealer and lay a thin silk sewing thread along the case flange, the thread would squash out and really sealed things up nice, never a leak.I don't know, Clymer manual recommends Gasgacinch, which I haven't seen in years. It looks like it came from the factory with RTV silicone between the case halves. Thats what I'm scraping off anyway.
| Posted: Sun Aug 14th, 2005 11:42 pm | 12th Post |
I like the red silicon Permatex. It only takes a very thin coat and the stuff stands up to very high temperatures. It is a pain in the a**e to clean it off. I wonder if this stuff would cut it? http://www.handymanformula.com/
| Posted: Mon Aug 15th, 2005 12:00 am | 13th Post |
I used silicone the first time I changed my stator with no problems and used permatex the second time, I do get a slight leakage of oil with the permatex. Not an actual leave so much as a misting of oil around the joint. I guess its going to keep misting as I will do the external alternator next time
____________________ While any advice given may concern earlier or later models it specifically pertains to the 1985 Aspencade. Click here for another place for 1200's to gather! |
| Posted: Mon Aug 15th, 2005 12:07 am | 14th Post |
That's why the aircraft engine used the silk thread, even it there was a missed spot of sealant, the thread was known to be continuous so once it was squashed in there was no way for oil to get past. I'm talking about a thin thread, like one you'd use in hand sewing delicate fabric.
| Posted: Mon Aug 15th, 2005 04:22 am | 15th Post |
Hey Gambler, thanks for sharing the pictures!! By the looks of the lathe in the background, this project won't be a problem for you.
____________________ John 1996 GL1500 SE Past bikes 1985 Aspencade 1200 1978 Honda GL 1000 1974 Honda 350 Four 1974 Yamaha TY 250 Trials 1973 Yamaha 360 RT3 1971 Honda SL 100 1968 Honda Trail 50 3 1/2 HP mini bike |
| Posted: Mon Aug 15th, 2005 04:55 am | 16th Post |
johnmac wrote: Hey Gambler, thanks for sharing the pictures!! By the looks of the lathe in the background, this project won't be a problem for you.I just got done restoring that, 1946 Logan model 820. I still need to replace the original electrical motor. It's Sam Adams time.. Attachment: goldwing rebuild (Small).jpg (Downloaded 948 times)
| Posted: Mon Aug 15th, 2005 05:06 am | 17th Post |
Hey gambler keep us informed of the evolution of the project it must be nice to have the place (room) to get your hands durty an work on a project like this. Good luck By the way is it a LTD or SEi i noticed a (crank pos sensor) on the 2 first pics ?????
____________________ Norm. LTD 2001-2011 1997 1500 SE White 2012 ------ I am now back to life and will ride to death |
| Posted: Mon Aug 15th, 2005 09:14 am | 18th Post |
Is this an 84 1200? Have you pulled the crankshaft out yet? It would be interesting to see some pics of the journals and bearings since there was so much loose metal floating around in the engine. BTW, have you sourced the replacement parts you'll need so far? It is my understanding that the main and connecting rod bearings were no longer available from Honda for the 1200. Also, how many miles on this engine and how does the crosshatch pattern look in the cylinders? Most 1200's I've seen still had the crosshatch pattern clearly visible on the cylinder walls illustrating how little wear occured over the years. I don't think Honda sold a lot of pistons and rings for these bikes Permatex produces a gasket maker that's different than silicone in that it dries harder and bonds better. It comes in a can with a brush built into the cover. I have used this sealer in the past to seal case halves with good success. I had thought about using silicone but was afraid that I might have problems like Twisty had with oil seepage. Thanks for posting the pics and looking forward to more if you have them. Good luck with the project. (Now if we could get some pics of an 87 1200 with the cases open we could do some gear comparison.) Vic
| Posted: Mon Aug 15th, 2005 02:45 pm | 19th Post |
| Posted: Mon Aug 15th, 2005 02:51 pm | 20th Post |
The machine tolerances for both halves of the case are within .001" - .004". All you need is a very clean surface and some good quality silicone.. I use the Permatex gold.. Never ever had a leak... You already know this, but it's critical to torque the case bolts properly so there is no distortion on the mating surfaces..
____________________ Old Nam Vet LZ English 66 - 67 New '08 Titanium Nav I'm old and wise, but was once young and stupid. |
| Current time is 05:47 am | Page: 1 2 3 4 5 6 ... |
| Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 1200 teardown | Top of Page |
