| Author | Post |
Gambler
Guru
back to top
Posted: Sat Sep 17th, 2005 05:15 pm | 201st Post |
| got the wheels done(best as I could) lot of corrosion, so I clear coated them after painting. before.. Attachment: goldwing rebuild 005 (Small).jpg (Downloaded 485 times)
____________________ 87 GL1200 Interstate(reborn )
Gambler
Guru
back to top
Posted: Sat Sep 17th, 2005 05:17 pm | 202nd Post |
| after, two coats of black and one clear.(yes, she who tickles my fancy taped them off for me) Attachment: goldwing rebuild 286 (Small).jpg (Downloaded 196 times)
Gambler
Guru
back to top
Posted: Sat Sep 17th, 2005 05:18 pm | 203rd Post |
| started on the carbs, and found this. Attachment: goldwing rebuild 282 (Small).jpg (Downloaded 192 times)
Gambler
Guru
back to top
Posted: Sat Sep 17th, 2005 05:21 pm | 204th Post |
also. drilled out the idle mix screw holes and found every screw at a different setting.
1=1/4 turn out
2=2.1/4 turns out
3=0 turns out(tight)
4=1 turn out.
makes you wonder. but the inside of the carbs looks clean
Attachment: goldwing rebuild 281 (Small).jpg (Downloaded 170 times)
Ruaidh
back to top
Posted: Sat Sep 17th, 2005 05:30 pm | 205th Post |
| I've loved reading this string. Almost makes me, the biggest motard here, feel like I could do the same.
____________________ "Words, unwritten, have no value" - Caius Merlinus Brittanicus.
'90 Caramel Blue 1500
Gambler
Guru
back to top
Posted: Sun Sep 18th, 2005 06:01 am | 206th Post |
skins today, installed the forks also. metzlers front and rear. Attachment: goldwing rebuild 291 (Small).jpg (Downloaded 180 times)
Gambler
Guru
back to top
Posted: Sun Sep 18th, 2005 06:03 am | 207th Post |
| installed the ign. switch and self canceler too. Attachment: goldwing rebuild 296 (Small).jpg (Downloaded 169 times)
Gambler
Guru
back to top
Posted: Sun Sep 18th, 2005 06:12 am | 208th Post |
Ruaidh wrote: I've loved reading this string. Almost makes me, the biggest motard here, feel like I could do the same. you could, just take lots of pics. helps with the reassembly especially if you get interupted alot(such as work, girlfriends, fires on the freeway two streets over with embers landing on your shake roof)(that happened tonight) got a bad pic of the flames just popping over the roof of the apartments two street over. started when someone in a motorhome drove down the freeway with a tire off the rim, and the sparks from that started a stretch of the vegetation on 17/880n on fire.Attachment: goldwing rebuild 002 (Small).jpg (Downloaded 185 times)
Renegade
Guru
back to top
Posted: Sun Sep 18th, 2005 02:12 pm | 209th Post |
Suggestion.. Take that front air deflector off and paint it flat (or gloss) black.. that's how they came from the factory..
I admire your work on this bike.. My 86 Aspy looks just as clean and bright.. These old 1200's are (in my eyes) the most beautifully designed and well built of the GoldWings.
I am impressed!!!
____________________ Old Nam Vet
LZ English 66 - 67
New '08 Titanium Nav
I'm old and wise, but was once young and stupid.
Gambler
Guru
back to top
Posted: Sun Sep 18th, 2005 04:45 pm | 210th Post |
Renegade wrote: Suggestion.. Take that front air deflector off and paint it flat (or gloss) black.. that's how they came from the factory..
I am impressed!!!
thanks, you can't tell from the pic, but it's painted flat black.
Gambler
Guru
back to top
Posted: Mon Sep 19th, 2005 07:32 am | 211th Post |
| getting closer. Attachment: goldwing rebuild 306 (Small).jpg (Downloaded 196 times)
wingnut
Admin 1
back to top
Posted: Mon Sep 19th, 2005 08:19 am | 212th Post |
This has turned out to be a great thread, I don't know how I didn't get to look at it until now. Well done Gambler.
____________________ Steve Saunders,
Admin and Founder Member.
Gambler
Guru
back to top
Posted: Mon Sep 19th, 2005 02:52 pm | 213th Post |
wingnut wrote: This has turned out to be a great thread, I don't know how I didn't get to look at it until now. Well done Gambler.  thanks. should be running soon.
exavid
Top Poster
back to top
Posted: Mon Sep 19th, 2005 06:22 pm | 214th Post |
Gambler wrote: getting closer. I'm shocked, is that a rusty clamp on the engine guard?
Gambler
Guru
back to top
Posted: Tue Sep 20th, 2005 04:08 am | 215th Post |
exavid wrote: Gambler wrote: getting closer. I'm shocked, is that a rusty clamp on the engine guard? no, bad pic, thats something hanging down.
Gambler
Guru
back to top
Posted: Tue Sep 20th, 2005 04:09 am | 216th Post |
| oh.......and ........SHE LIVES........... Attachment: goldwing rebuild 319 (Small).jpg (Downloaded 173 times)
Gambler
Guru
back to top
Posted: Tue Sep 20th, 2005 04:10 am | 217th Post |
| ahhhhhhhhhhhh Attachment: goldwing rebuild 314 (Small).jpg (Downloaded 180 times)
BobbyW
Very Active Member
back to top
Posted: Tue Sep 20th, 2005 05:09 am | 218th Post |
Gambler;
Thanks for taking the effort to post your restoration. Its very inspiring.
____________________ -2007 GL1800, Audio, Blue
-1981 GL1100 Standard FOR SALE
Hondaline Luggage/Vetter Fairing
-1978 GL1000, Nekid, Black
List your Wings Model and year in your profile !!!
exavid
Top Poster
back to top
Posted: Tue Sep 20th, 2005 06:30 am | 219th Post |
Gambler wrote: ahhhhhhhhhhhh
     Man I can feel the Vibes!!
Gambler
Guru
back to top
Posted: Tue Sep 20th, 2005 06:54 am | 220th Post |
thanks for the support guys, I'm not done yet. I was just getting antsy not knowing how the motor would run, so I hung the fairing on with one bolt and connected the wires so the gauges would work. started right up, 1st and second work, so thats good news. next is rebuilding the calipers and getting the brakes to work.
also have some plastic repair to do to the trunk, and of course remove more rust and corrosion.
I will keep posting pics 'till it's done, or you guys get tired of it.
