| 1200 teardown | Rate Topic |
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: 1 2 3 4 5 6 7 8 9 10 ... |
| Author | Post |
| Posted: Sat Aug 20th, 2005 02:22 am | 81st Post |
this one has a stain, but no pitting Attachment: goldwing rebuild 082 (Small).jpg (Downloaded 445 times)
____________________ 87 GL1200 Interstate(reborn |
| Posted: Sat Aug 20th, 2005 02:52 am | 82nd Post |
Gambler wrote: Goldwinger1984 wrote:Gambler wrote:very few cars have pistons that small. geo metro comes to mind. and honda had a 1.3l engine didn't they? maybe I will take some measurements and post them up so someone could start doing some research on that.I hope those are viewable. oh, the engine had good oil pressure. I'm looking into what it would cost for custom pistons to be built over here in Canada, once I get the price I'll compare it to Honda's stock piston and post that info. Considering the price that Honda wants for pistons and rings it may be one avenue for new pistons. The 1200 piston are approximately 75.5 mm or 2.97" in diameter. BTW, your most recent pics show up pretty good. Have you checked the cylinders for taper yet? Vic
____________________ http://www.gl1200goldwings.com/ A place for GL1200's to gather. |
| Posted: Sat Aug 20th, 2005 03:05 am | 83rd Post |
haven't checked for taper, and may not. no news is good news. if I get too deep into this I will wind up spending more than I want. the trans parts I got off ebay look primo and now just waiting for the gasket set(also from ebay).
| Posted: Sat Aug 20th, 2005 03:53 am | 84th Post |
With the tops of the cylinders still having the cross hatch, I would bet there is no taper.
____________________ John 1996 GL1500 SE Past bikes 1985 Aspencade 1200 1978 Honda GL 1000 1974 Honda 350 Four 1974 Yamaha TY 250 Trials 1973 Yamaha 360 RT3 1971 Honda SL 100 1968 Honda Trail 50 3 1/2 HP mini bike |
| Posted: Sat Aug 20th, 2005 04:07 am | 85th Post |
johnmac wrote: With the tops of the cylinders still having the cross hatch, I would bet there is no taper. well, I went back to the shop and got my dial bore gage. very minimal taper less than .001 of an inch, more like .0005,. the cylinders have good crosshatch all over so there doesn't appear to be much wear. also, it appears this bike did it's miles on long distance trips.(the previous owner had done several coast to coast trips, and I believe this was why the engine looks so good inside) (yes, I live 5 min. from the shop Last edited on Sat Aug 20th, 2005 04:10 am by Gambler ____________________ 87 GL1200 Interstate(reborn |
| Posted: Sat Aug 20th, 2005 07:44 am | 86th Post |
oil pump screen, Attachment: goldwing rebuild 087 (Small).jpg (Downloaded 419 times)
| Posted: Sat Aug 20th, 2005 07:45 am | 87th Post |
getting there. knocking off for the night. mr beam here I come Attachment: goldwing rebuild 089 (Small).jpg (Downloaded 440 times)
| Posted: Sat Aug 20th, 2005 01:25 pm | 88th Post |
You deserve a well earned rest after all that work Gambler. Vic
| Posted: Sat Aug 20th, 2005 02:59 pm | 89th Post |
Gambler... you are right about the cost of rebuilding an engine.. However, there are a lot of factors to concider when overhauling... A recip aircraft engine is completely overhauled to bring it back to either "within tolerance" or "new" condition.. M/C eingines fall into the same catagory.. It all depends on how much you want to spend and what you're going to do with the finished product.. Rebuilding is certainly not cheap, BUT, you know what you've got. The engine can be brought back to the condition it was when it left the factory, retaining the original serial numbers, performance and longevity of service.. Used, or what we call LKQ (Like Kind & Quality) engines may be cheaper, BUT, what are you getting? Possibly an engine that's had the S__T beat out of it, not properly maintained with regular oil changes, improper maintenance and repairs etc. Also, you could install it in the bike and after starting it up, find it has a problem which requires it to be pulled again.. Warranties mean nothing if you have to do the job more than once. I know it takes a lot of work to overhaul one of these engines, but the built in quality of design is worth the price of the replacement parts..By the way, the ring price from the Bike Bandit is per cylinder.. I've bought many sets to know... The gasket sets range an average of $100 for each the upper and lower sets from a company in Italy... If you do the job correctly, it may be slightly higer than a used mill, but the results are well worth it.. Above all,,,, Have Fun!!!
____________________ Old Nam Vet LZ English 66 - 67 New '08 Titanium Nav I'm old and wise, but was once young and stupid. |
| Posted: Sat Aug 20th, 2005 04:15 pm | 90th Post |
Renegade wrote: Gambler... you are right about the cost of rebuilding an engine.. However, there are a lot of factors to concider when overhauling... A recip aircraft engine is completely overhauled to bring it back to either "within tolerance" or "new" condition.. M/C eingines fall into the same catagory.. It all depends on how much you want to spend and what you're going to do with the finished product.. Rebuilding is certainly not cheap, BUT, you know what you've got. The engine can be brought back to the condition it was when it left the factory, retaining the original serial numbers, performance and longevity of service.. all true, but this is a 200.00$ goldwing, and I could see spending 1500.00$ in parts or more to replace everything just for the engine. I've been thinking, hypothetically speaking, if you roll into your local honda dealer with say 30k miles on the clock and you have a trans gear problem. and it was still under extended warranty, would the factory authorise replacing all the rings and bearings and roller bearings? I don't think so, after all these engines were designed to go more than 100k mikes with the original parts. it's a gamble
| Posted: Sat Aug 20th, 2005 06:29 pm | 91st Post |
Replace gaskets and O rings. I thing other parts will be fine to reuse.
| Posted: Sat Aug 20th, 2005 09:10 pm | 92nd Post |
You're doing a great job, replace what must be replaced, reuse the rest of the parts. Keep up the good work and keep the pictures coming.
____________________ Tony 89 GL1500 |
| Posted: Sun Aug 21st, 2005 01:57 am | 93rd Post |
if anyone needs a specific shot of something, let me know. has anyone ever spun the alternator drive while it's out of the case, mine makes a clicking noise. it's not the bearing, it's coming from inside. it was not making noise when it was in the case and the bike was running so I think it is normal. maybe a one way clutch or gear reduction inside the unit. the bike was charging, so what about the stator? looks good as far as that goes but like anything electrical it could fail at any time. I found one on ebay for 155.00 new, and may order that soon. opinions?
| Posted: Sun Aug 21st, 2005 02:00 am | 94th Post |
johnmac wrote: Replace gaskets and O rings. I thing other parts will be fine to reuse. I ordered a complete gasket set from ebay, 116.00 shipping included, hasn't arrived yet so no comment on the quality. supposed to come with all the o-rings also. where are you guys getting your water pumps from? mine has some play in the shaft so needs replaced.
| Posted: Sun Aug 21st, 2005 07:15 pm | 95th Post |
I took this shot to show the differences between the 86 and the 87, the parts I needed were the shift drum and fith gear(which has the dogs which engage second gear)(thats the broken gear on top. these are the countershafts, looks like you can only use 5th gear(lucky me Attachment: goldwing rebuild 091 (Small).jpg (Downloaded 434 times) Last edited on Sun Aug 21st, 2005 07:30 pm by Gambler ____________________ 87 GL1200 Interstate(reborn |
| Posted: Mon Aug 22nd, 2005 12:20 am | 96th Post |
Gambler, have a look here for the water pump; http://www.powersportspro.com/ Click on the big fish to open the registration page, register, then once you're in your garage on the site, select 87 Gold Wing, then look under transmission cover in the pop up menu, item number 3, the water pump is $135. If you order in August they are offerenig a 15% discount. I've dealt with these folks in the past and found them to be reliable. I wonder if you could get a little clearer pic of the differences in the gears in that last shot? The lighting and the newspaper make it hard to distinguish the differences. Vic Last edited on Mon Aug 22nd, 2005 12:28 am by Goldwinger1984 ____________________ http://www.gl1200goldwings.com/ A place for GL1200's to gather. |
| Posted: Mon Aug 22nd, 2005 01:59 am | 97th Post |
I called the local dealer the other day for a set of rings for my 76 1000,i asked for rings ,complete gasket set,primary chain and gears,primarychain tensioner and water pump and the total was just shy of 1200 canadian,thats if nothing else needs to be replaced which we won,t know until we tear it down,still debating what to do
____________________ andrew 1983 1100 interstate |
| Posted: Mon Aug 22nd, 2005 03:51 am | 98th Post |
andrewns5, why don't you try checking for better pricing on those parts over the internet? On occasion I have found it cheaper to bring parts across the border myself (and pay the duty and shipping) than it would be for my local dealer to get the same parts. I think what happens in these cases is that the local dealer doesn't have the parts I need, so he would order from the internet himself and mark up the price of the parts by 25-35% after duty, exchange and shipping to sell my something I could have bought much cheaper if I did the ordering myself without the dealers help. Vic
| Posted: Tue Aug 23rd, 2005 03:25 am | 99th Post |
Oregonwinger wrote: Rings were so bad, the crankcase loaded up with fuel, and combustion flamefront scooted past rings, everything being just right, BAMMMMMM. Quite a sight, and messy. An old Cornbinder, if I remember right. A 1965 International Carryall we had at Kotzebue, AK blew the oil pan clear off due to gas collecting in the sump. Probably more from running too cold to get the gasoline evaporated out, but it was sure spectacular. Big bang, and a bunch of smoke. Watching the four guys bail out of it was comical too. How about ServiceHonda for online parts? http://www.servicehonda.com/ Last edited on Tue Aug 23rd, 2005 03:37 am by exavid ____________________ If you can't ride, fly or sail it, why bother? 2001 Goldwing 1800 Paul W. |
| Posted: Tue Aug 23rd, 2005 05:01 am | 100th Post |
Goldwinger1984 wrote: Vic, I took some more pics, looks like you can use the 2nd, 3rd,5th from the 86 countershaft in the 87. however, I need the 4th gear which has the dogs on it for 3rd, which on my 4th are worn. the countershafts have a big difference, on the 87 the bearing on the inside bolts to the end of the shaft, on the 86 it sits in the case and the shaft slides into it. Attachment: goldwing rebuild 107 (Small).jpg (Downloaded 696 times)
| Current time is 05:35 am | Page: 1 2 3 4 5 6 7 8 9 10 ... |
| Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 1200 teardown | Top of Page |
