1200 teardown  Rate Topic
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  10  11  ...  Next Page Last Page
Author Post
 Posted: Tue Aug 23rd, 2005 05:03 am 101st Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
this is the 4th gear, and it is not the same for 86-87, the inside diameter is different.
Attachment: goldwing rebuild 097 (Small).jpg (Downloaded 525 times)
____________________
87 GL1200 Interstate(reborn ;) )
 Posted: Tue Aug 23rd, 2005 05:04 am 102nd Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
this is the damage to my dogs on the 4th gear which engages 3rd gear.
Attachment: goldwing rebuild 101 (Small).jpg (Downloaded 420 times)
 Posted: Tue Aug 23rd, 2005 05:19 am 103rd Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
the mainshafts appear to be the same, and as mine is still good, I will reuse the original one. but now I'm looking for the 4th gear, or should I reuse it. hard choice, car transmissions don't use these kind of dogs to engage gears so I can't base the decision on experiance. not to metion I need a final drive, drive flange, and rear wheel.:action::(
Attachment: goldwing rebuild 108 (Small).jpg (Downloaded 886 times)
 Posted: Tue Aug 23rd, 2005 07:27 am 104th Post
PMQuoteReply
exavid
Top Poster
Goldwing: GL1800
Mileage: 79,000
Status:
Offline
Mana:
My Gallery
back to top
Gambler, any chance of a picture of the spring loaded damper on the final shaft?
2001 Goldwing 1800
 Posted: Tue Aug 23rd, 2005 07:47 am 105th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
exavid wrote: Gambler, any chance of a picture of the spring loaded damper on the final shaft?this?
Attachment: goldwing rebuild 113 (Small).jpg (Downloaded 450 times)
 Posted: Tue Aug 23rd, 2005 12:46 pm 106th Post
PMQuoteReply
Goldwinger1984
Senior Guru
Goldwing: GL1200 Aspencade
Mileage:
Status:
Offline
Mana:
back to top
If you need to replace the rear gears and wheel you might want to consider an upgrade to the heavier unit from a GL1500, http://pete-marge.us/Rebuild/
I believe that a couple of fellows from this site have converted their rear drive units as well.
Vic
http://www.gl1200goldwings.com/
 Posted: Sat Aug 27th, 2005 11:45 pm 107th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
block halves finally joined.
Attachment: goldwing rebuild 116 (Small).jpg (Downloaded 433 times)
 Posted: Sat Aug 27th, 2005 11:45 pm 108th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
another view
Attachment: goldwing rebuild 115 (Small).jpg (Downloaded 429 times)
 Posted: Sat Aug 27th, 2005 11:47 pm 109th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
these are the piston holders I made from 3 layers of 1/8" cardboard taped together. worked well, and easier then making them from wood.
Attachment: goldwing rebuild 114 (Small).jpg (Downloaded 430 times)
 Posted: Sat Aug 27th, 2005 11:51 pm 110th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
fwiw, I wound up reusing the 4th gear after stoning the dogs. also, I think the clymer manual illustration is incorrect for the 87 'wing trans countershaft. mine did not have as many circlips on it as the ilustration. other then that the clymer is light years better then the haynes(I have both).
 Posted: Sun Aug 28th, 2005 12:25 am 111th Post
PMQuoteReply
exavid
Top Poster
Goldwing: GL1800
Mileage: 79,000
Status:
Offline
Mana:
My Gallery
back to top
Thanks Gambler for the torsion damper picture. I took the liberty of lightening it up a bit to show the cam and ramp setup a little clearer. I think this is the source of the 'clunk' some members are reporting when first starting out from a stop. If the cam rides up the ramp it will snap down the moment the torque pressure is eased a bit. It's only supposed to move a very small amount, but should the spring lose a little of it's stiffness over the years this might allow the action of the damper to become a bit exaggerated. Don't know if I can get the picture to work, for some reason I've had a problem with it. Thanks for your effort in documenting the engine rebuild, it's been very interesting and an enjoyable saga. I'm just about as eager as you to hear about the first running of the mill when you get it back together.
Attachment: damper.jpg (Downloaded 421 times)
2001 Goldwing 1800
 Posted: Sun Aug 28th, 2005 04:52 am 112th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
your pic looks better then mine, if you need more shots of it let me know.
 Posted: Sun Aug 28th, 2005 07:48 am 113th Post
PMQuoteReply
hammer
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
You guys amaze me, how in the heck have you learned so much about this stuff lol???????
Who said that god gave only the angels wings??????
 Posted: Sun Aug 28th, 2005 05:10 pm 114th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
hammer wrote: You guys amaze me, how in the heck have you learned so much about this stuff lol???????necessity.:D
 Posted: Sun Aug 28th, 2005 05:13 pm 115th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
valve seats, note the pitting on the exhaust valve seat.
Attachment: goldwing rebuild 129 (Small).jpg (Downloaded 398 times)
 Posted: Sun Aug 28th, 2005 05:14 pm 116th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
valves looked good, plenty of margin
Attachment: goldwing rebuild 127 (Small).jpg (Downloaded 787 times)
 Posted: Sun Aug 28th, 2005 05:18 pm 117th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
seats cleaned up well after hand lapping with the intakes with fine valve lapping compound, and doing the exhaust valves and seats with coarse and fine.
Attachment: goldwing rebuild 139 (Small).jpg (Downloaded 422 times)
 Posted: Sun Aug 28th, 2005 05:20 pm 118th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
there is some minor pits left, but I think they will seal fine. they don't span the whole width of the seat and I have seen worse seal on car engines.  valve seals were still soft and pliable, but I replaced them anyway. the guides passed my clearence test, and the valve stems look good too.
 Posted: Sun Aug 28th, 2005 07:28 pm 119th Post
PMQuoteReply
Goldwinger1984
Senior Guru
Mileage:
Status:
Offline
Mana:
back to top
Gambler wrote: there is some minor pits left, but I think they will seal fine. they don't span the whole width of the seat and I have seen worse seal on car engines.  valve seals were still soft and pliable, but I replaced them anyway. the guides passed my clearence test, and the valve stems look good too.
Looking great so far Gambler.  Anxious to see it all together.
Vic
 Posted: Sun Aug 28th, 2005 08:47 pm 120th Post
PMQuoteReply
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
exavid wrote: Thanks Gambler for the torsion damper picture. I took the liberty of lightening it up a bit to show the cam and ramp setup a little clearer. I think this is the source of the 'clunk' some members are reporting when first starting out from a stop. If the cam rides up the ramp it will snap down the moment the torque pressure is eased a bit. It's only supposed to move a very small amount, but should the spring lose a little of it's stiffness over the years this might allow the action of the damper to become a bit exaggerated. Don't know if I can get the picture to work, for some reason I've had a problem with it. Thanks for your effort in documenting the engine rebuild, it's been very interesting and an enjoyable saga. I'm just about as eager as you to hear about the first running of the mill when you get it back together.
I agree, I just checked mine, it has some wear on the upper part of the u channel, not much, just evidence that it has rotated up the ramp. could be a possible clunk, but ths spring is pretty substantial. I think if I had too I could take it apart with the press at work. but it has no play and I think I will use it as is.
 Current time is 05:18 am Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  10  11  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 1200 teardown Top of Page
