CLICK HERE |
| 1200 teardown | Rate Topic |
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: ... 4 5 6 7 8 9 10 11 12 13 14 ... |
| Author | Post |
| Posted: Mon Sep 5th, 2005 01:35 am | 161st Post |
after. Attachment: goldwing rebuild 224 (Small).jpg (Downloaded 402 times)
____________________ 87 GL1200 Interstate(reborn |
| Posted: Mon Sep 5th, 2005 01:38 am | 162nd Post |
I also took apart the starter and found the brushes worn out, so I have some coming. since I was putting the rear cover on without the starter I test fitted it several times and found it hard to get the splines to mesh. so I took a triangular needls file and cleaned up the start of the splines on the starter drive gear, it made it easier to slide the starter in to the gear. Attachment: goldwing rebuild 213 (Small).jpg (Downloaded 378 times)
| Posted: Mon Sep 5th, 2005 01:38 am | 163rd Post |
this is what it goes into(in case you don't have a service manual and have to do this )this is without the cover on, once it's on you don't get to see the gear. from the other side you slide the starter in to the gear. Attachment: goldwing rebuild 211 (Small).jpg (Downloaded 741 times) Last edited on Mon Sep 5th, 2005 01:40 am by Gambler ____________________ 87 GL1200 Interstate(reborn |
| Posted: Mon Sep 5th, 2005 01:48 am | 164th Post |
This is "insanely great" stuff. Thanks. I second the suggestion at making a web page for those about to attempt this in the future. Thanks again - mana to you!
____________________ 1979 1000 nekkid |
| Posted: Mon Sep 5th, 2005 07:51 pm | 165th Post |
sanfelice wrote: This is "insanely great" stuff. Thanks. I second the suggestion at making a web page for those about to attempt this in the future. Thanks again - mana to you!thanks. I hope I don't bore anyone. and I hope I'm not wasting space. here is the engine after she who tickles my fancy taped it off. I did the spraying. Attachment: goldwing rebuild 225 (Small).jpg (Downloaded 372 times) Last edited on Mon Sep 5th, 2005 07:52 pm by Gambler ____________________ 87 GL1200 Interstate(reborn |
| Posted: Mon Sep 5th, 2005 07:54 pm | 166th Post |
mostly done, just wainting for the water pump. Attachment: goldwing rebuild 229 (Small).jpg (Downloaded 371 times)
| Posted: Mon Sep 5th, 2005 07:54 pm | 167th Post |
another Attachment: goldwing rebuild 231 (Small).jpg (Downloaded 389 times)
| Posted: Tue Sep 6th, 2005 09:22 am | 168th Post |
Just letting you know that you are not boring anyone and you are definately not wasting space. All the pics and info you have posted so far are valuable resources on this site and your efforts are very much appreciated. Vic
____________________ http://www.gl1200goldwings.com/ A place for GL1200's to gather. |
| Posted: Tue Sep 6th, 2005 02:07 pm | 169th Post |
Gambler: I have been following this thread every day with great anticipation of your next post. It is exactly the sort of thing that I too enjoy doing and will undoubtedly be doing in the future. Your pictorial essay will be totally invaluable to anyone doing such a project. Keep it going and I sincerely thank you for your great effort. Hawker22
____________________ Hawker22(Ken) Per Ardua Ad Astra 1997 GL1500SE--White Cloud 2001 GL1800----Blue Yonder |
| Posted: Tue Sep 6th, 2005 03:03 pm | 170th Post |
....that engine is sooooooo beautiful !!
____________________ 1985 Aspy Pinstriped Powder Blue & Matching blue Trailer. "Mathematics is the Music of the Mind" Gray-haired bikers don't get that way from pure luck. |
| Posted: Tue Sep 6th, 2005 08:21 pm | 171st Post |
I've always felt real good when an aircraft engine is overhauled and repainted, so pretty and pristine, just love 'em. Those rocker covers same out nice, I like the paint better than the orginal aluminum, they look more business like. Keep it coming, you're not wasting anyone's time, best thread on the forum, even better than the deer whatsits!
____________________ If you can't ride, fly or sail it, why bother? 2001 Goldwing 1800 Paul W. |
| Posted: Tue Sep 6th, 2005 11:42 pm | 172nd Post |
thanks for the good words guys. I like doing this stuff, and this being my first goldwing I wanted to snap alot of pics and then I thought someone else might restore an old wing and could use them as reference. more to come.
| Posted: Wed Sep 7th, 2005 04:52 am | 173rd Post |
did the forks tonight after work. used forks off ebay seller, my forks were too pitted to use. plenty of blowups in the manual. but I thought I'd show why it's a good idea to clean them up on the inside once in a while. Attachment: goldwing rebuild 237 (Small).jpg (Downloaded 377 times)
| Posted: Wed Sep 7th, 2005 04:53 am | 174th Post |
also, this spring was in the wrong position. Attachment: goldwing rebuild 235 (Small).jpg (Downloaded 366 times)
| Posted: Wed Sep 7th, 2005 04:54 am | 175th Post |
this is what it should look like Attachment: goldwing rebuild 236 (Small).jpg (Downloaded 364 times)
| Posted: Sat Sep 10th, 2005 06:34 am | 176th Post |
steering head bearings. the manual is wrong, it says to put this seal on the stem and install after you have the races in. put this one in the frame neck before the bearing race, then put the bearing races in. Attachment: goldwing rebuild 241 (Small).jpg (Downloaded 348 times)
| Posted: Sat Sep 10th, 2005 06:34 am | 177th Post |
the big seal goes under the lower race. Attachment: goldwing rebuild 243 (Small).jpg (Downloaded 346 times)
| Posted: Sat Sep 10th, 2005 07:40 am | 178th Post |
Just really great info and photo's. Who are you using to host your pictures. Gambler, you're way too modest. This post is going to save many somebody's a lot of grief. Great Job.......
____________________ For those who've never fought for it, the price of freedom shall never be known.... "Shooter" 1986 Interstate |
| Posted: Sun Sep 11th, 2005 04:24 am | 179th Post |
Shooter wrote: Just really great info and photo's. Who are you using to host your pictures.thanks. I just post them here.
| Posted: Sun Sep 11th, 2005 04:43 am | 180th Post |
ok, so I put new brushes in the starter, the old one were about half gone(or a little more) the new ones are about 12.5mm wide. notice the positive one has more wear. Attachment: goldwing rebuild 245 (Small).jpg (Downloaded 363 times) Last edited on Sun Sep 11th, 2005 04:46 am by Gambler ____________________ 87 GL1200 Interstate(reborn |
| Current time is 03:22 am | Page: ... 4 5 6 7 8 9 10 11 12 13 14 ... |
| Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 1200 teardown | Top of Page |
