homepage
Stripped spark plug hole
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
FinallygotmyGoldwing
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Mar 18th, 2008 09:31 pm1st Post
 PM  Quote  Reply
Spark plug hole #3 thread is rounded. Can I use a tap/die set to re thread the hole, or will the shavings cause problems. If no tap/die what can I do?
northwing
Goldwing: GL1500
Mileage: 36000Km ...
Status:
Offline
Mana:
  back to top
 Posted: Tue Mar 18th, 2008 09:40 pm2nd Post
 PM  Quote  Reply
Hi, your best bet is to have a helicoil done. This takes the hole back to original size by fitting a metal coil insert. It's also stronger than original threaded hole.
____________________
1988 Gl1500
1974 Batavus Go Go
1980 Batavus Bingo
1979 CB250N (superdream)
If you see a vehicle with a indicator on, the bulb works, if it flashes the relay works, if they turn......they know it's on!!!
Phils a winger at last
Very Active Member
Goldwing: GL1100 Aspencade
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Mar 18th, 2008 09:42 pm3rd Post
 PM  Quote  Reply
Had a 250 honda in the 70's and that stripped a plug thread had the thread cleaned up and ended up with a slight gas leak which at 85mph melted the plug thro the piston................
Have heard that heli coil can be used with it in situ so does not have to be stripped
p.s. now I leave my plugs alone if it runs !
Reality is an illusion caused by lack of alcohol, if this is reality for gods sake buy me a drink
C100/2(4) GT 380(6) C92 DT 175 Cz175 jawa350 XS250,650,750 CD175 CB250 tiger cub YP250(3) Z550Ltd GS500F
fatwing chris
Goldwing: GL1500
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Mar 18th, 2008 09:56 pm4th Post
 PM  Quote  Reply
Get yourself a heli-coil kit.It will come with the proper tap and coil insert.Tap it out and install the heli-coil.you can use some threadlocker on the coil when installing the coil into the head.Put grease on the tap and it will catch and hold most if not all of the cuttings.Even if it doesn't the aluminum cuttings won't hurt anything.You can also stick a long,thin blow nozzle down into the cylinder and blow the cuttings back out the plug hole.Be careful and wear safety glasses while doing this.A used head would be another option if your not comfortable with this procedure.
Fatwing Chris
Back in the sleddin mode!!!
If I'd have known it would last this long I would have taken better care of it.
exavid
Top Poster
Goldwing: GL1000, GL1100 Aspencade, GL1500 Aspencade
Mileage: 126,000
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 12:23 am5th Post
 PM  Quote  Reply
As already has been mentioned, a helicoil is the best repair. You could try a tap the size of the plug and see if you can restore the existing threads, it might just be the upper couple of turns. If you need to do a helicoil I'd recommend removing the head to do the job. Though the aluminum shavings ought not to do any damage to the steel valve, valve seat or cylinder I have seem little bits of aluminum get stuck on an intake valve seat preventing the intake valve from shutting. I've put helicoils into several heads for spark plug problems, pretty common in aluminum heads. One of the best things you can do is to put a bit of aluminum based anti-seize on your spark plug threads to prevent them from galling the aluminum threads in the head.
Ghost Rider 2
Goldwing: GL1100 Standard, GL1500 Aspencade
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 12:24 am6th Post
 PM  Quote  Reply
    Having been a drag racer for 40 years I have seen several aluminum heads with plugs stripped out.  The best way to repair is to go to a NAPA store and get a K-D brand spark plug thread restore kit.  It contains the tap and a steel sleeve insert.  A Helicoil is a spring.  Works fine for a bolt.  But I prefer the steel sleeve on a spark plug because of the comptession.  Good luck.
1981 GL1100 Std with full vetter dailey driver
1996 GL1500 Aspy. weekend rider
2004 Honda Shadow Aero 750 wife (Better Half)
2004 Kawasaki Concours sport touring
Longboater
Active Member
Goldwing: GL1800
Mileage: 2007 1800 15000 miles ...
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 01:25 am7th Post
 PM  Quote  Reply
Helicoil kit for sure.  Done all the time since the 60s any way.  Navy tested.
Also used in tooling where bolts are continually moved in and out.
Helicoils are Titanium alloy or used to be anyway.
Follow the instructions to the letter.
Rig a vaccum up to remove any shavings out.
Have the piston at TDC.  Have the exhaust valve open so the incoming air will sweep away the shavings.
It works, done all the time.
Longboater,
Be safe and have a never better day.
Past bikes:
Yamaha 65
Honda 85
Penton 125
Zuki 185
Husky 250
Honda VTX 1300
jermar
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 05:26 am8th Post
 PM  Quote  Reply
I agree with Ghost Rider 2. At least I would try that first and then if it didn't work go to the heilicoil.Good luck, let us know how it turns out.
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 03:57 pm9th Post
 PM  Quote  Reply
Thanks guys for the advice. I'll mull it over and when I get time this weekend I will attack.
Night_Train01
Goldwing: GL1100 Interstate, GL1200 Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 05:11 pm10th Post
 PM  Quote  Reply
if you have only damaged the first couple of threads then use a tool called a back-tap
I used one to repair a 14mm spark plug hole a month ago...I was amazed how easily it work.
If you choose to tap the hole then the shavings have no place to go but down into the cylinder, the back-tap prevents that from happening.
The entire repair takes approx 1 minute to do.....my plug now threads in smooth and easy....
Addicted to motorcycles
1978 Kawasaki Z1R
1981 KZ1000 J
1987 VTwin Custom
1983 GL 1100
1984 V65 Magna
1984 Interstate
1980 RD 400 Daytona Special
1981 KZ1300
ARKnapp
Senior Guru
Mileage: 97000 km ...
Status:
Offline
Mana:
  back to top
 Posted: Wed Mar 19th, 2008 06:19 pm11th Post
 PM  Quote  Reply
1 way:  use a spark plug as a tap.  May have to cut across threads of plug of plug to form starting V notch.  Or with patience and force on the extension  it might cut into existing remnants of thread.  Time saver if it works. Good luck
adeswas
Goldwing: GL1200 Aspencade
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 02:03 am12th Post
 PM  Quote  Reply
I hate to be the stick in the mud, but what happens if the filings don't get cleaned out and stay in the cylinder?  Time for a new engine...
Pull the head off and do it right.  Don't drill or tap anything until the head is removed!!   Remember the mechanic's adage..."never time to do it right, but always time to do it twice"
exavid
Top Poster
Mileage: 126,000
Status:
Offline
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 02:29 am13th Post
 PM  Quote  Reply
It wouldn't be safe to let iron chips get in a cylinder as they might if you were tapping an iron head but aluminum is soft enough that they won't scratch the steel valves and seats or the cylinder or rings. Unless a bit of aluminum gets caught under a valve which is admittedly low probability there really isn't much damage that the small particles can cause. They can't get in the bearings because there's no access from the cylinder to the bearings.
ARKnapp
Senior Guru
Status:
Offline
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 03:04 am14th Post
 PM  Quote  Reply
http://www.back-tap.com/  C heck this site out for a tap that traps cuttings and then some.
redbaron
Mileage: 97,000 plus speedo broken....
Status:
Offline
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 03:38 am15th Post
 PM  Quote  Reply
Heli-coils are the best way to go. I had an old ford T-Bird engine I rebuilt for an old 56 Ford F-100 panel truck. I had every head bolt drilled and heli-coils inserted, also did all the main bolts and spark plugs at the same. This engine was a 1957 312 T-Bird engine, when we got it put together it pumped out over 450 hp. Had it not had the heli-coils it would have blown up at the first time we took it to its red line.
If I ever have to build an engine for my wing all bolt holes will be heli-coiled....spark plugs too...
Claude
1982 GL-1100 Goldwing Interstate
http://www.RudysBackyard.com
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 03:53 am16th Post
 PM  Quote  Reply
ARK for some reason your link didn't get me there but I just typed in the web address and whow awesome stuff. I watched the video and am sold. What size do I need? Guessing 12mm. I have an 81 gl1100i.
And is the size I need a standard size for motorcycles, so I can get my money out of it in the future.
Thanks a lot, And thanks Night :grinner: for the recommendation
Mohawk
Guru
Location: Baldwinsville, Just Outside Of Syracuse, New York USA
Goldwing: GL1500 Aspencade
Mileage:
Status:
Online
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 11:01 am17th Post
 PM  Quote  Reply
I have had quite a bit of luck with helicoils in spark plug holes.
But I always have to Pre drill the hole and tap to the new Helicoil size.
In the kits I bought were the proper sized Drill and Tap with a cheap insertion tool to help install the Helicoils.
I also use a shop Vac with the narrow attachment placed near the hole I am drilling and tapping and have not had ANY chips get into the cylinder.
Works for me. Plus I give it extra sucking right at the plug hole while turning the engine over to be sure.
And I inserted the smooth Helicoils with a thread Locking compound rather than the locking helicoils that have the deformed octagon thread midway down to lock the helicoil into the hole.
I find that the locking type of helicoil will eventually lock itself to the plug and come out with the plug or drive itself further into the head where it becomes a real bitch to remove.
Good Luck to all.
Mohawk
95 Aspencade
"Dressed to the Nines"
Live to Ride - Ride to Live
My 4th Wing & 40 Years in the Wind
"The Native Americans found out what happens when you don't control immigration."
Davogd430
Guru
Goldwing: GL1800
Mileage:  21141 a/o 1/1/09 bought new 2/9/08 ...
Status:
Offline
Mana:
  back to top
 Posted: Thu Mar 20th, 2008 11:52 am18th Post
 PM  Quote  Reply
I agree with Ghost Riser 2, get a spark plug repair insert, not a helicoil. The helicoil has the little tab on the end that has to be broken off when it's installed and chances are good it will fall into the cylinder and it is going to damage the cylinder wall. The insert kit has a tool that cuts the hole and threads it at the same time. Put grease on it to catch the cuttings and there won't be enough get into the cylinder to worry about. Make sure the intake valve is closed and the piston down so the tool doesn't hit them.
Gone to the dark side and lovin' it. Maxxis 205/55 ZR16
David
usta haves:
64 150 dream 66 CL160 74 CL360
72 Suz TM400 74 Husky CR400
76 Suz RM250 77 Suz RM 370
82 Kaw 750 84 Kaw KDX 250 88 Kaw KX250
83 VT500 81 std 83Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Fri Mar 21st, 2008 01:26 am19th Post
 PM  Quote  Reply
Just found a 14mm back tap on ebay:
http://tinyurl.com/3e59xg
mucha betta cost--edit, mucha betta url
Davogd430
Guru
Goldwing: GL1800
Status:
Offline
Mana:
  back to top
 Posted: Fri Mar 21st, 2008 01:42 am20th Post
 PM  Quote  Reply
The problem there is your plugs are 12mm.
You need to learn about TinyURL.com - shorten that long URL into a Tiny URL
so when you post a link it doesn't make the page so wide, I'm new to this stuff too so don't take it the wrong way, just trying to help.:)
David
usta haves:
 Current time is 11:12 am
Page:    1  2  Next Page Last Page
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 2.0719 seconds (11% database + 89% PHP). 23 queries executed.
