3 yellow wire question  Rate Topic
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:    1  2  Next Page Last Page
Author Post
 Posted: Tue Sep 6th, 2005 01:57 am 1st Post
PMQuoteReply
wingdawg101
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
Searched 9 pages of "Yellow Wire" threads!
Question, on an 1100 since all 3 wires are yellow (not marked) I guess it doesn't matter which 2 Yellow wires you solder together out of the 6 wires, is this correct?:baffled:
I've always kept a lot of "Dilectric Grease" on mine so have not had a problem but thinking I should do it?!
Thanks!
____________________
Against the Wind !
"Patriot Guard Rider"/Nevada
GL 1100
Valkyrie "Fat Lady"
 Posted: Tue Sep 6th, 2005 02:30 am 2nd Post
PMQuoteReply
Patch
Goldwing: None at present
Mileage: NONE
Status:
Offline
Mana:
back to top
You are correct, it does not matter which 2 wires you hook together.
Just make sure to shrink wrap them well.  Some very thick walled shrink wrap or about 3 layers of regular wall shrink wrap will work nice.
Chris & April Sanders
 Posted: Tue Sep 6th, 2005 02:36 am 3rd Post
PMQuoteReply
sanfelice
Very Active Member
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
Necessary on the 1000s as well?
1979 1000 nekkid
 Posted: Tue Sep 6th, 2005 03:10 am 4th Post
PMQuoteReply
wingdawg101
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
Thanks!
Against the Wind !
GL 1100
Valkyrie "Fat Lady"
 Posted: Tue Sep 6th, 2005 03:26 am 5th Post
PMQuoteReply
johnmac
Goldwing: GL1500 SE
Mileage: 80,000 miles
Status:
Offline
Mana:
My Gallery
back to top
Yes. The same for 1000s and 1200s.
1996 GL1500 SE
Past bikes
1985 Aspencade 1200
1978 Honda GL 1000
1974 Honda 350 Four
1974 Yamaha TY 250 Trials
1973 Yamaha 360 RT3
1971 Honda SL 100
1968 Honda Trail 50
3 1/2 HP mini bike
 Posted: Tue Sep 6th, 2005 06:15 am 6th Post
PMQuoteReply
exavid
Top Poster
Goldwing: GL1800
Mileage: 79,000
Status:
Online
Mana:
My Gallery
back to top
Just make sure you connect three upgoing wires to three downgoing ones! Incestuous interconnecting won't work.:cheeky1:
2001 Goldwing 1800
 Posted: Tue Sep 6th, 2005 04:45 pm 7th Post
PMQuoteReply
ccsailor
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
You know guys   I've been giving this a lot of thought lately and I think it DOES matter which wires hook to each other. I think you should mark them and reconnect A to A  B to B and C to C
follow my maybe misguided logic
rotor is turning clockwise(or the other way for you guys that will try to correct me doesn't matter) passes A then B then C so you get "flow" with the following
A_B_C   or B_C_A   or C_B_A
BUT   if you hook up different
B_C_A  or C_B_A   OR   A_C_B  it is not in order of rotation ergo not as much O/P
Right or wrong I don't know but it seems logical to me
We need an electrical engineer to answer this one
Neil
 Posted: Tue Sep 6th, 2005 05:31 pm 8th Post
PMQuoteReply
twisty
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
wingdawg101 wrote: Searched 9 pages of "Yellow Wire" threads!
Thanks!
wingdawg101, you are correct, it really doesn't matter what yellow rear wire is hooked to what front wire as long as they are ALL isolated from each other & each wire runs from the stator to the regulator uninterrupted.. That system is 3-Phase A/C so polarity or wire matching isn't important. Once the regulator gets hold of the current it just shoves it through a series of diodes to rectify it & turn it into D/C, at that point it becomes polarity sensitive.
To help understand the principal-- (remember electricity & water act a lot alike).. You have 3 garden hoses fed from either one pump with 3 SEPARATE impellers & outputs phased 120° apart, or 3 separate pumps run from the same motor.. Those 3 hoses end up at a combining valve but pass through a one way check valve before doing so.. The combined outputs of those 3 hoses comes out of the end of the combining valve with almost 3 times the flow & the individual pulses are now one smooth flow (it doesn't really matter what hose is connected to what inlet port)..
Twisty
 Posted: Tue Sep 6th, 2005 05:34 pm 9th Post
PMQuoteReply
twisty
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
ccsailor wrote: You know guys   I've been giving this a lot of thought lately and I think it DOES matter which wires hook to each other. I think you should mark them and reconnect A to A  B to B and C to C
Neil
Neil, if your logic held correct then you would get a different voltage reading when measuring from A to B than A to C (not so)..
Twisty
 Posted: Tue Sep 6th, 2005 05:47 pm 10th Post
PMQuoteReply
ccsailor
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
not quite twisty    a-c  and a- b are the same electrically when measured separately so they will measure the same if working correctly
BUT your hose theory holds water :goofygrin::goofygrin::goofygrin:  I guess it depends on how many "pulses " are put out and when. which of course depends on how many magnets and spacing are in the rotor
 Posted: Tue Sep 6th, 2005 06:01 pm 11th Post
PMQuoteReply
twisty
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
ccsailor wrote: not quite twisty    a-c  and a- b are the same electrically when measured separately so they will measure the same if working correctly
Neil, if "a-c  and a- b are the same electrically when measured separately" that is just how the rectifier would see them.. Actually once the rectifier diodes get the stator A/C current it is pulsed D/C after that..
Twisty
 Posted: Tue Sep 6th, 2005 08:57 pm 12th Post
PMQuoteReply
mjohnson
Very Active Member
Goldwing: GL1100 Interstate, GL1500, GL1800
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Were there any issues with this problem on the 1500 series - specifically the 1989 model wing?
youth is wasted on the young
2007 midnight blue GL 1800
1976 Kawasaki KZ900 - my baby
1989 1500 goldwing
1986 Honda Rebel - wife's bike
 Posted: Tue Sep 6th, 2005 09:12 pm 13th Post
PMQuoteReply
RedWinger
Mileage:
Status:
Offline
Mana:
back to top
 Posted: Tue Sep 6th, 2005 10:31 pm 14th Post
PMQuoteReply
Patch
Mileage: NONE
Status:
Offline
Mana:
back to top
I knew I shoulda got me a 1500. :headbanger:
 Posted: Wed Sep 7th, 2005 12:37 am 15th Post
PMQuoteReply
wingdawg101
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
ccsailor,
You threw me a "Curve" Ball ?!
But "Twisty" was "Pitch Hitting" for me, ha!
Maybe "Candian Electricty is different from US electricty?!:goofygrin::goofygrin::baffled:
Against the Wind !
GL 1100
Valkyrie "Fat Lady"
 Posted: Wed Sep 7th, 2005 01:51 am 16th Post
PMQuoteReply
ccsailor
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Nah still not convinced
 Posted: Wed Sep 7th, 2005 02:37 am 17th Post
PMQuoteReply
SilverDave
Goldwing: GL1200 Aspencade
Mileage:
Status:
Offline
Mana:
back to top
CCSailor.... Your logic might just hold... if each of A-B  B-C was occuping exactly 1/3 of the winding space... and  a single brush was taking off the electricity, at a certain point, as the coil passed that point ... but...  I think the brushless effect of a stator... and the  repeated winding pattern  means that each loop   say the pink in the enclosed pic ... is giving out its current  at several times in each revolution.........                 http://www.freescale.com/webapp/sps/site/overview.jsp?nodeId=02nQXGrrlPglzQMszY                    now I know this is a three phase motor ... but the electrical effect is the same...... So I gotta disagree with you... and  I think that the order of soldering of the three Yellows makes no difference makes absolutely NO difference ... SilverDave
 Posted: Wed Sep 7th, 2005 02:52 am 18th Post
PMQuoteReply
ccsailor
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
you seem to be supporting my theory if you look at your link   it goes pink   blue    black and repeats all the way around SO in theory you SHOULD hook up in order right??????????????? then twistys "pulsed"dc prf would be less (which is good)
Unless they are interwound with each other in real time like a braided effect???????????
 Posted: Wed Sep 7th, 2005 03:12 am 19th Post
PMQuoteReply
wingdawg101
Senior Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
back to top
Then how come everyone who has randomly wired the yellow wires have had no problems?:baffled:
Against the Wind !
GL 1100
Valkyrie "Fat Lady"
 Posted: Wed Sep 7th, 2005 03:34 am 20th Post
PMQuoteReply
johnmac
Goldwing: GL1500 SE
Status:
Offline
Mana:
My Gallery
back to top
If it did make a differance, then 3 phase motor wiring would have the same problem with phase sync., I would think.  Switching two wires on a 3 phase motor only reverses the direction.
My vote is: it doesn't matter.
1996 GL1500 SE
Past bikes
1985 Aspencade 1200
1978 Honda GL 1000
1974 Honda 350 Four
1973 Yamaha 360 RT3
1971 Honda SL 100
1968 Honda Trail 50
3 1/2 HP mini bike
 Current time is 04:32 am Page:    1  2  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > 3 yellow wire question Top of Page
