homepage
Check your FREE keyrings and buttons order status HERE. Members who missed this can get details on the KEYRINGS THREAD in the General Discussion forum, and can claim their goodies using the REQUEST FORM
Timing a GL1000 with a Dynatek
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
erinfire703
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Apr 20th, 2008 02:49 am21st Post
 PM  Quote  Reply
Thanks for that info.....I would be lying if I said I fully understood it :?   When it is written out like that it is understandable.  What would be the risk or benafit of not using the balast at all if using stock coils?
____________________
1975 GL1000
nomados
Very Active Member
Goldwing: GL1000
Mileage: 175,000 ...
Status:
Offline
Mana:
  back to top
 Posted: Sun Apr 20th, 2008 03:13 am22nd Post
 PM  Quote  Reply
When I talked to Dyna last year to discuss ballast resistor requirements I got the impression that running stock coils without a resistor there was a risk in burning out the Dyna sending unit.
Some also believe that the coils can be damaged, but I'm not so sure about that now.
That said I ran a couple days like this before I sorted out what ballast to buy.  You can buy an automotive type 1.2 ohm resistor at any auto parts store that will bolt right in.  I can supply parts numbers if you need them.
1975 GL1000
If Goldwings were whiskey they'd always be served neat.
77GL1
Very Active Member
Goldwing: GL1000
Mileage: 69,000
Status:
Offline
Mana:
  back to top
 Posted: Sun Apr 20th, 2008 01:28 pm23rd Post
 PM  Quote  Reply
erinfire703 wrote: Thanks for that info.....I would be lying if I said I fully understood it :?   When it is written out like that it is understandable.  What would be the risk or benafit of not using the balast at all if using stock coils?
nomados is absolutely correct...the Dyan S will almost certainly be ruined without the ballast on even stock coils.  At least 3ohms total between the coils and extra ballast is required.   I burned one that way a few years ago.
http://www.salocal.com/parts/goldwing_parts.htm
'77 GL1000 / '76 CB836F
erinfire703
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Apr 20th, 2008 05:07 pm24th Post
 PM  Quote  Reply
Thanks for all the info guys.......couldn't keep my wing on the road without the help! :clapper:here to the best forum on the net!
1975 GL1000
larryjoe
Goldwing: GL1200 Aspencade
Mileage: 53,000
Status:
Offline
Mana:
  back to top
 Posted: Fri Apr 25th, 2008 05:04 pm25th Post
 PM  Quote  Reply
Say, is the timing same on gl1200, I am having probs with 85 Aspy se-i. Wont start, just back fires using flooded start procedures?:?:baffled:
Ed Lee & Larry Joe
nomados
Very Active Member
Goldwing: GL1000
Status:
Offline
Mana:
  back to top
 Posted: Mon Apr 28th, 2008 07:33 pm26th Post
 PM  Quote  Reply
larryjoe wrote: Say, is the timing same on gl1200, I am having probs with 85 Aspy se-i. Wont start, just back fires using flooded start procedures?:?:baffled:
Welcome to the forum larryjoe.   To answer your question, no the gl1200 has a totally different ignition system.  And the se-i may be different from a normal 1200, fuel injected.  I don't know enough about it to comment other than that.  You might want to start a new thread.  You'll get a lot of help here if you ask.
Oops, nevermind, just saw your thread... hope you get it sorted.
1975 GL1000
 Current time is 05:55 pm
Page:  First Page Previous Page  1  2
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.4092 seconds (34% database + 66% PHP). 26 queries executed.
