homepage
Check your FREE keyrings and buttons order status HERE. Members who missed this can get details on the KEYRINGS THREAD in the General Discussion forum, and can claim their goodies using the REQUEST FORM
1986 ASPENCADE SEI STOPS RUNNING
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
VinnyP
Goldwing: GL1200 SEi
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jun 23rd, 2008 05:52 pm1st Post
 PM  Quote  Reply
Hello to all,
I recently purchased a 1986 Goldwing Aspencade SEI with only 5400 miles.
The bike will start and rough idle but when I try to go for a ride it feels like it is not getting gas and dies on me.I keep giving it throttle but it just bogs down and dies.
It then will not start again.
I had to push it home (1/2 mile ) and I replaced spark plugs,checked fuel pump and it still will not run. Gas was drained and fresh gas with fuel injector additive was put in bike.
It starts but I cannot ride it.
ANy help is greatly apprecieted.
Thanks ,
Vinny P
wildman
Active Member
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jun 23rd, 2008 06:48 pm2nd Post
 PM  Quote  Reply
Check the fuel filter. It's on the left side of the bike near the battery (towards the front from the battery). It has a little chrome cap on it with banjo type fittings top and bottom.
____________________
'86 SE-i
There is no problem in life that a sufficient quantity of high explosives won't solve.
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jun 23rd, 2008 07:28 pm3rd Post
 PM  Quote  Reply
Thank you.
I did buy a new fuel filter and have not installed it yet.
I had removed the line off the fuel pump amd when I turn on the key I do get a steady stream of gas.
Is the fuel filter after the fuel pump line I checked?
Thanks again,
VIn P
jacmar
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jun 23rd, 2008 07:37 pm4th Post
 PM  Quote  Reply
I believe the 86 bike has a fuel shut off tap on the right side of the motor as you sit on the bike. Check and make sure the tap has not been turned toward the off position. From what you are saying it sounds like a fuel stavation problen I encountered on my 85se. Also check the fuel filter as suggested above. Start checking at the bottom right side of the tank and follow through to the filter and I think you will find the problem. My old 85 would start like a charm and then when you tried to give it the gas it would start to die. You could run it at low speed 20/25 miles per hour and anything over it would cough spit and almost die and when you let the throttle off it would start to idle normally. After it died and After sitting a few minutes enough fuel would flow and it would start like a charm again.
Jack
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Jun 25th, 2008 03:03 pm5th Post
 PM  Quote  Reply
Hi to all,
Well I put in new fuel filter and bike ran great for about 10 minutes then it  bogs down again and feels like it is not getting gas.
Styars up after stiing for awhile but I cannot ride it as it keeps stalling.
Any more suggestions are greatly appreciated.
Thanks,
VinnyP
motor22
Very Active Member
Mileage: 11,019
Status:
Offline
Mana:
  back to top
 Posted: Thu Jun 26th, 2008 12:28 am6th Post
 PM  Quote  Reply
Check the bone fuse next to the battery. As they get old they crack its hard to see. Cut out that fuse holder and replace it with a blade fuse(heavy duty). When you start the bike what voltage are you getting?
Training will keep you alive. Practice evasive and braking techniques. Please stay safe.
Scott
My Baby http://usera.imagecave.com/motor22/SE-I/
78 Suzuki GS550 (gone)
85 Yamaha 750 Seca (gone)
00 Suzuki 800 Intruder (gone)
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Jun 26th, 2008 02:51 am7th Post
 PM  Quote  Reply
When the bike starts it shows between 13.4 and 14.1 on ths batttery charge display
VinnyP
William_86
Goldwing: GL1200 Interstate
Mileage: 92,000 and counting....
Status:
Online
Mana:
  back to top
 Posted: Thu Jun 26th, 2008 03:09 am8th Post
 PM  Quote  Reply
how about the air filter?? may be rly blocked. xP would try some seafoam !
85' GL 1200 Interstate - My Picture Thread
Useful links: Manuals, Randakk's
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Jun 26th, 2008 09:57 pm9th Post
 PM  Quote  Reply
I will check air filter this weekend,
Would bike run good for awhile and then bog down with dirty air cleaner?
Also what is sea foam and where would I buy it?
As always thanks for help
VinnyP
wing on amsoil
Goldwing: GL1200 Aspencade
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Fri Jun 27th, 2008 03:33 am10th Post
 PM  Quote  Reply
Seafoam is used to remove water from the fuel in the tank the lines the carbs,it also cleans the jets and outher carb parts.you can get it at any auto store in the states.
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Jul 3rd, 2008 04:10 pm11th Post
 PM  Quote  Reply
I installed new fuel filter and bike ran great for awhile in my garage but it started to bog down again and still feels like it is not getting gas.
lesgwyn
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Jul 3rd, 2008 07:17 pm12th Post
 PM  Quote  Reply
You mentioned earlier about a steady stream of gas. The EFI system should carry 36PSI in the fuel line. This isn't what you would call a 'steady stream', more of a good squirt. Its worth checking the fuel pressure regulator and even the fuel pump - may have become tired. Les
roscoepc
Very Active Member
Goldwing: GL1200 LTD
Mileage:
Status:
Online
Mana:
  back to top
 Posted: Thu Jul 3rd, 2008 10:14 pm13th Post
 PM  Quote  Reply
Being as that's low milage 23 year old bike and you say she'll run good for about 10 minutes before taking a dump, I'd check the fuel tank for rust as it sound's like the fuel filter is becoming plugged.
Mine had set for about 7 years when I got her and the fuel tank was garbage! Take a flashlight and take a look inside the tank. That might be the problem.
pauln
Guru
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Fri Jul 4th, 2008 04:59 am14th Post
 PM  Quote  Reply
Vinny,
What you need to try to do is to either confirm or rule out fuel pressure as the issue.  The best way to do that is to monitor the fuel pressure while you ride it.  I did it on my LTD a couple of years ago.  You need to get one of those fuel pressure guage kits from Harbor Freight or on ebay (like the one in the attached pic).  There is a six millimeter bolt (10 mm head) on the right side fuel rail (behind the shiny CFI cover).  The fuel pressure tester has a six millimeter attachment hose and you can zip tie/tape the gauge to the right side of the fairing (over the locking pocket cover.  You can then watch the pressure as you ride.
The pump or the pressure regulator may be fine when cold, but once things get warmed up, they can act weird.  You could also have junk in the fuel tank that is plugging things up, even with a new fuel filter.  The only way to know for sure is to check the pressure.
If the fuel system checks out, there are several other possibilities, but we can worry about those once the fuel supply checks out.
Let us know what you find out.
Attachment: 20080703-235200.jpg (Downloaded 88 times)
Paul from Ohio
85 GL1200 LTD
nobbie
Very Active Member
Goldwing: GL1200 Interstate, GL1500 SE
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Fri Jul 4th, 2008 05:06 am15th Post
 PM  Quote  Reply
VinnyP wrote: Hello to all,
Thanks ,
Vinny P
Check the bikes history. Was it ever owned by Bill Gates? :cheeky1::cheeky1::cheeky1:
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Jul 8th, 2008 05:48 pm16th Post
 PM  Quote  Reply
I will be checking gas tank and fuel regulator this week.
Ill let all know what I find.
Thanks again
Vinny P
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Jul 22nd, 2008 08:18 pm17th Post
 PM  Quote  Reply
Bike was picked up today by well established Honda dealer.
I tried all suggestions above but bike just wont take gas once it is warmed up.
I will let all know what the dealer discovers.
Again thanks to all for the help
VinnyP
Oregonwinger
Senior Guru
Goldwing: GL1800
Mileage: 15,250
Status:
Offline
Mana:
  back to top
 Posted: Tue Jul 22nd, 2008 09:02 pm18th Post
 PM  Quote  Reply
Even though it has low miles, that sounds like the typical "dying crank sensor". It just depends on the environment it's been exposed to the last 20+ years. You should have an error on ecu while cranking. Did you look at the led's on the ecu, under trunk, on the left side while cranking? If it's the crank sensor, good luck finding one. The supply dried up cpl. years ago. A dealer search may turn one up, or a used one may be available from 123Whitey on ebay. I wouldn't trust a used one at all, tho. I wish I had my LTD back, so I could experiment with an exact replacement. I often wondered if 1 of the 2 crank sensors from a 1500 would work. If that's the problem, and you find a replacement, be aware that the leads may have to be reversed or it still won't run right. Reverse the leads in the plug body at end of sensor, using a tiny pin, drill bit, jewelers screwdriver, or something skinny to bent the little tabs on the wire end.
Bob Anderson
http://webpages.charter.net/catmek/andysjoint.html
2006 Nav, Cabernet Red
RollaHome camper
Schwinn Varsity
Schwinn Collegiate
For Sale 90 SE engine; perfect at 41k 600.00
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 28th, 2008 01:19 pm19th Post
 PM  Quote  Reply
To all,
Honda dealer has found rust in the gas tank. They are in process of removing tank and flushing the system.
Bike came with a brand new fuel pump assembly and dealer will be installing it as well....They are cleaning injectors and hope to have bike ready for pick up tomorrow.
Thanks to all for the hep.
Vinny P
VinnyP
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Fri Aug 29th, 2008 05:55 pm20th Post
 PM  Quote  Reply
To all,
Bike is finally home and running great.
Tank had significant rust and the fuel pump assembly was bad.
Thanks to all.......... One other question
How do I turn on fog lights on bike??
Thanks again
Vin P
 Current time is 06:26 pm
Page:    1  2  Next Page Last Page
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 1.2748 seconds (15% database + 85% PHP). 24 queries executed.
