| Author | Post |
ChasW
back to top
Posted: Tue Nov 4th, 2008 01:45 pm | 21st Post |
I haven't bled my wing yet. I am going to do mine just to change the fluid. My fluid is a little foggy, want to clean it up.
However -- I changed the fluid in a CB750, that was my first time working on a bike brake system. I rebuilt the front caliper as well.
I have done many cars, what I learned from that CB750 is that it is much different then bleeding brakes systems on cars. It takes a lot of patients and time to get that air out. Sometimes, it seems as though nothing is coming out every time you crack the bleeder. Time and patients and a lot of beer. But don't let the beer screw your job up. I think I went through 6 beers before I saw any action. It was tiny skirts, I mean squirts of air and a lot of bleeder cracking, a lot different then a vehical with 4 wheels and a real brake pedal.
U must have ounagy Ole Daniel-Son, wax on, wax off, wax on, wax off, wax on, wax off.
oldtoys1961
Very Active Member
back to top
Posted: Tue Nov 4th, 2008 03:17 pm | 22nd Post |
| This is one of the reasons I switched over to Speed Bleeders. Makes it really simple and quick. JR
____________________ "Please Tell Your Boobs TO Quit Staring At My Eyes"
1983 GL1100I
tomw
Active Member
back to top
Posted: Thu Nov 6th, 2008 03:27 am | 23rd Post |
I'll try what ward said in the morning. its 10:30 est here now.just got back in town.I'm on it in the morning.
thanks for the advice everyone.
____________________ Relax,we all have a little Gomer Pyle in us.
Two things extinct in America in the 21st Century,customer service and management.
tomw
Active Member
back to top
Posted: Thu Nov 6th, 2008 07:22 pm | 24th Post |
C'mon everyone with an '83 that has been persistant enough to actually get the brakes bled tell us how many hours you have in it.
I get some fluid now but no pressure in the pedal.So I'll keep at it.
Burning away good riding weather too.Its a shame,really.
OnaWingandaPrayer
back to top
Posted: Fri Nov 7th, 2008 01:37 am | 25th Post |
Tom I am sorry to hear your having so much trouble . It can be difficult . IF your begining to get fluid your on the right path . Be sure to keep the resivoir full so as not to risk introducing more air to the system.
Can you pump up any prssure yet ? I mean with the bleeders closed off pump the brake pedal . IF you can get some pressure then bleed the front . I think it was mentioned early on, if you can raise the front caliper up ...perhaps higher than the headlight. BE sure to put a spacer in between the brake pads so the pistons dont over extend. The air will float up hill better then down . I also alternate between front and back when I am bleeding the linked system .
IF you are using a mightyvac , I find the bleeder screws need teflon tape onthe threads . If not you will be sucking air in around the threads . Not pulling as much fluid thru the system .
Another thing that some have found helps is to pull the banjo off the caliper . pinch it between your thumb and forefinger. While holding it that way , you can slowly press the pedal and the fluid will pass by your finger/thumb but you seal the air out . Once you have the lines full of fluid then put it back on the caliper. Bleed a little at the banjo bolt once its back on . Then proceed to bleed the caliper.
I am not sure what you have tried to date . Some of these thoughts might have been mentioned earlier in your thread . I didnt reread the complete thread tonight. I hope your soon past this bump in the road and out enjoying some nice fall rides. Wish I was closer and could help more.
____________________ Mike
You meet the nicest people on a Honda !
83 Interstate,daily driver
'93 1500 Aspencade , fastest color at night ! some assembley required . Thankyou Brian for the second chance.
tomw
Active Member
back to top
Posted: Fri Nov 7th, 2008 03:23 am | 26th Post |
Well thats a real nice note.Thank you for your interest.I'll keep trying.I did post one rant on the design of the system and still feel its at least deficient because no one could design a system with this kink in it and call it an advance.Too many people on here have had the same or similiar problems.Talked to the dealer today and they don't like to work on old bikes but because they know me they are willing to take a look and use their power vac on it.Of course I told them I don't want a bill for $300 to get my brakes bled.They smiled.They are so nice.They said they'd work with me.
Yes I did get some progress today.On the rear I drew about an inch and a half or close to two inches of brake fluid up the tube.No pressure on the pedal yet though.On the front I got some fluid but more wet air than anything.I did alternate front and rear and used the mityvac and the old fashioned method too.Right now the pedal is being held down with a wedge overnight so maybe that'll make some difference.Doubtful but maybe.At this point I'd take anything that moves this process forward.So tomorrow I'll be back on the brakes again.I'd say I have somewhere near 50 hours in this stupid process.Guess if I had a compressor I could use that like the dealer will.Probably would go buy one if I KNEW that'd get the job done.But I don't so I won't.I have used most of the tricks suggested by fellow members and I do appreciate their advice.So if anyone has something to add on brake bleeding an '83 lets hear it please.
Front caliper is up above the handlebars.With a stop between the pads.
Thanks for the encouragement and ideas.
chris in va
Very Active Member
back to top
Posted: Sat Nov 8th, 2008 01:58 am | 27th Post |
| Just keep us posted. I'm almost to the point of having the dealer handle it on my bike.
tomw
Active Member
back to top
Posted: Sat Nov 8th, 2008 09:33 pm | 28th Post |
OK how far have you gone yourself and what were your results.Would you let us know what the dealer charges?
My guy won't commit to even doing it.They will "look" at it next Thursday.
Davogd430
Guru
back to top
Posted: Sun Nov 9th, 2008 12:11 am | 29th Post |
| You may be getting air in the system through the master cylinder piston so vacuum and pumping the pedal will never get the air out. Find a plastic bottle with a nipple cap or something similar and fill it with fluid. Remove the reservoir from the hose to the rear MC, put the nipple in the hose, bottle upside down, open the bleeders and squeeze the bottle until fluid comes out the bleeders. The MC may hold with fluid pressure on it but not seal off good enough to keep air out when trying to bleed.
____________________ Gone to the dark side and lovin' it. Maxxis 205/55 ZR16
David
usta haves:
64 150 dream 66 CL160 74 CL360
72 Suz TM400 74 Husky CR400
76 Suz RM250 77 Suz RM 370
82 Kaw 750 84 Kaw KDX 250 88 Kaw KX250
83 VT500 81 std 83Interstate
tomw
Active Member
back to top
Posted: Sun Nov 9th, 2008 12:45 am | 30th Post |
| Now this could be interesting.Thanks Davo.I'm trying this tomorrow. Last edited on Sun Nov 9th, 2008 03:09 am by tomw
wing ding
Active Member
back to top
Posted: Sun Nov 9th, 2008 12:39 pm | 31st Post |
Burning away good riding weather too.Its a shame,really. 15 minutes! Including the time it takes to clean and put away the bleeder gun!  Last edited on Sun Nov 9th, 2008 12:42 pm by wing ding
____________________ If you can't fix it with a hammer, You have an electrical problem!!
OnaWingandaPrayer
back to top
Posted: Sun Nov 9th, 2008 02:21 pm | 32nd Post |
| Another thought Tom . How about start at the begining. Disconnect the pressure line right at the rear master. Holding a finger tip on that port , bleed the master . Then put the line back and move to the pressure spliter . just keep moving away from the master , working out the air in each section .
tomw
Active Member
back to top
Posted: Sun Nov 9th, 2008 03:32 pm | 33rd Post |
| Well the pressure splitter is a problem because I can't get the nuts loose and you know how easy they strip.So I have to go get some line wrenches to get them loose.I'm not saying I won't do it but I just haven't yet...gotten the wrenches I mean.
ChasW
back to top
Posted: Mon Nov 10th, 2008 03:21 am | 34th Post |
Hi Tom, hopefully will catch you before you bring your bike to the dealer. I just did my front brake, just flushing the old fluid out and replacing it with new.
Something that I forgot to mention and only remembered because it just happened to me. My bleeder was 98% plugged. I put a vacuum system on it that I made up and I couldn't get any flow. Sqeezed the brake, only got a little wetness around my bleeder.
I pulled out my bleeder, took a small piece of wire cleaned it out from the top and bottom (or I should say from the side hole on the bottom), hit it with compressed air, cleaned out nice, now flushing is working like a champ.
SO, check your bleeders to make sure they are clean. I hope this helps. My bleeder had a rubber cap protecting it as well but still corrided the ports 98% shut.
tomw
Active Member
back to top
Posted: Mon Nov 10th, 2008 03:46 pm | 35th Post |
Thank you ChasW.I did as you suggested and found the port to be clean.Although I do not have a compressor so no compressed air was used.
Here is what I did this morning.I put the rear caliper up front and bled it.
Here is the pic of that result.Even with that much fluid drawn up I can't get any pressure in the pedal.I also swapped out the line from the reservoir to the rear master cylinder as suggested in this thread.I never got that much brake fluid showing when I tried to bleed the correct front caliper.The brake lines are all clear.I had them off and drew fluid through all of them.Does this lead me to believe the correct front caliper is defective?The dealer rebuilt it for me two weeks ago.He also rebuilt the rear caliper...the one showing in the pic.Its not brain surgery to rebuild a caliper.But why can't I still get any pressure in the pedal? What controls the pressure at the pedal?A full caliper and a full brake line,right?Then close the cover to the reservoir and I should be done.Right? Please correct me...anyone?Attachment: Brake bleed pics 002.jpg (Downloaded 69 times) Last edited on Mon Nov 10th, 2008 03:55 pm by tomw
ChasW
back to top
Posted: Mon Nov 10th, 2008 10:50 pm | 36th Post |
Just to be clear, on the bleed, you checked the little port on the side towards the bottom of the bleeder and blew through the bleeder to make sure it was clear.
Are your master cyclinders O.K.? Have you done anything to make sure there doing there job?
tomw
Active Member
back to top
Posted: Thu Nov 13th, 2008 11:16 pm | 37th Post |
Well,well,well boys.Its done.Yes it is!DONE!As in I have pressure in the brake pedal and movement of the pistons both front and rear.
A member of this board went way out of his way to be of assistance to me.I mean out of his way like five time zones and an ocean away.
I got a phone call from agnogel in Ireland and in it he gave me the two minute lesson on either brake fluid or air in a closed system.Told me to disassemble the master cylinder and check the primary cup because he suspected it was either worn or damaged and therefore not making contact with the cylinder walls.Correct he was.So I did as instructed and replaced it with another I had in a box of brake parts that came with the bike and I had pressure right away.Bled the front and rear caliper.
May have to bleed somemore but thats for tomorrow.
So is it true then..."you meet the nicest people on a Honda"?
ChasW
back to top
Posted: Fri Nov 14th, 2008 01:03 am | 38th Post |
WOW, Great!
TIME TO DO THE HOOPA HOOPA DANCE!
tomw
Active Member
back to top
Posted: Fri Nov 14th, 2008 01:08 am | 39th Post |
Yep.Those emoticons are exactly how I felt when I got pressure in the brake pedal.
Another ressurection and soon to be on the road again.Like tomorrow if I can do it.
What a place.
tomw
Active Member
back to top
Posted: Fri Nov 14th, 2008 01:12 am | 40th Post |
All y'all should take an attaboy for getting this old bike running again.
Thank you everyone and especially thank you to agnogel.
 Current time is 12:05 pm | Page: 1 2 3 |
