homepage
carb sync on 93 1500SE
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
Kit Carson
GL1800 Guru
Goldwing: GL1800
Mileage:
Status:
Online
Mana:
  back to top
 Posted: Sun Nov 16th, 2008 09:26 pm21st Post
 PM  Quote  Reply
I was not even aware they had an electronic device like that. I think it would be a good tool.  And cheaper too.  Most likely better than some of the old ways.  The Carb Tune like I have with shipping and a set of brass adapters(the plastic ones last about three times) the cost would be like $150 dollars or more.
Looks like the internal part of the little device measures the vacuum pulses and lights up the green light when you have the carbs matched up.  Seems to me it would be better than our old stuff.  Be easier to read and not be subject to having to be held perfectly in the vertical position.
Yes you can use the Carb tune or a device like this electronic one on any machine that has two or more carbs, so long as you can find adapters it will work, many bikes like Yamaha and or snowmobiles you just pull the vacuum lines off and slip the tubes over the built in ports.
Technology is always better, new things always work better.
Kit
____________________
GPS GURU (NOT)
The Goldwing GL1800 is by far the best motorcycle ever designed in the world. Just to take a test ride on one is a dangerous thing, as you will just have to have one.
Returned to the Darkside, Khumo Run Flat 195/55/16
Test pilot days are over. The Khumo is the real deal.
Winger77
Very Active Member
Goldwing: GL1500 Aspencade
Mileage: 69,000
Status:
Offline
Mana:
  back to top
 Posted: Sun Nov 16th, 2008 09:32 pm22nd Post
 PM  Quote  Reply
Kit Carson wrote: I was not even aware they had an electronic device like that. I think it would be a good tool.  And cheaper too.  Most likely better than some of the old ways.  The Carb Tune like I have with shipping and a set of brass adapters(the plastic ones last about three times) the cost would be like $150 dollars or more.
Kit
Thats all I needed to know,,,,,,,,,, Thanks a bunch Kit,,,,,,,, your top notch on this forum.
Foosman(5)
Very Active Member
Goldwing: GL1500
Mileage: 40,000
Status:
Offline
Mana:
  back to top
 Posted: Mon Nov 17th, 2008 12:50 am23rd Post
 PM  Quote  Reply
Guys, are we going to make this into a science project or what.
Is this a big deal or not, and is it a simple or complex task?
There were those that even wanted to make their own manometer.  Why don't we just tell the everyone to put their bike in the shop?  The dealer would be the best for having the latest greatest tools, right.
Here is another poor mans sync tip.  Rebuild the carbs or take them off, and manually set the linkages playing with the sync and idle screw.  Make this initial adjustment to mimic a solid shaft as closely as possible as I stated in the previous post.  Look at them plates very closely to get them to operate in unison.  Worked for me, and after two years later, I saved enough money (~$12) and bought the HF gauge, ha.  Then, in checking the sync, I really only made a minor adjustement.  My other gauge was a glyserin guage that would have required more setup, and I had it for several years - to this day, I still have not use it.
My point is that it is not really that difficult.
Texas _Foosman
1988 GL1500
TwoWings
Goldwing: GL1200 Aspencade, GL1500 SE
Mileage: 1200 Aspy 68000K, 1500 SE 124000K ...
Status:
Offline
Mana:
  back to top
 Posted: Mon Nov 17th, 2008 02:41 am24th Post
 PM  Quote  Reply
Another method I have used for bench syncing carbs is by finding a number drill with the correct diameter of the master carb butterfly gap, and use this as a gauge to bench set the other carbs for gap. Used this quite often on older KZ900's before you use a vacuum gauge.
Fairly accurate and quick.
Winger77
Very Active Member
Mileage: 69,000
Status:
Offline
Mana:
  back to top
 Posted: Mon Nov 17th, 2008 02:45 am25th Post
 PM  Quote  Reply
Foosman(5) wrote: Guys, are we going to make this into a science project or what.
Thank you for your support.
 Current time is 01:13 pm
Page:  First Page Previous Page  1  2
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.3533 seconds (28% database + 72% PHP). 25 queries executed.
