Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > This just keeps getting better and better
This just keeps getting better and better  Rate Topic
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:    1  2  Next Page Last Page
Author Post
 Posted: Sun Mar 15th, 2009 11:53 pm 1st Post
PMQuoteReply
RB
Mileage: 125,500 miles
Status:
Offline
Mana:
back to top
So I finally got all the electrical issues worked out I think, new coils, new battery, reconnected everything..I had previous turned the engine over several different times with the kick starter. I figured it was Ok as to timing and belts etc.  valves set correctly.
So I hit the starter button and over she turned for a few seconds..I let up and was going to try again..and it locked..on the second try..now I can't turn it over with the kick starter. So off come the belt covers and what a mess in there; all rusted up, white power stuff all over too.  But the timing looks right..I can't turn the engine to line things up but it stopped just a bit off the arrows and the marks and both sides are just off the marks so I figure if I could move the crank they would line up just about right. I also checked the valves for the loose ones..and the 1/3 side is loose on the three that should be loose at TDC and one on the 1/4 is loose like it should be....
So it doesn't seem like it hit a valve unless one got hung up because of bad valve guide sticking.
I did pull the plugs to make sure it wasn't locked due to fuel..and it wasn't; note I am running it form a temporary gas "tank" and I only put enough in the fill the carbs bowls. The rear wheels spins freely so it's not in gear.
So any other ideas besides a stuck valve that kissing a piston???
And any ideas how to get all the rust of the front end while it's in place..everything is rusty..cam wheels, tensioners, the back plates it's a mess.  Pics later maybe..but it's hard for me to look at it..I want to :crying::crying::crying:
____________________
1981 GL1100I Daily rider
1979 GL1000 parting out PM if you're looking for something
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 Apsy sold
FAIR WINDS,
RB
 Posted: Mon Mar 16th, 2009 12:00 am 2nd Post
PMQuoteReply
Silicon Sam
Senior Guru
Goldwing: GL1100 Interstate, GL1100 Aspencade, GL1500 SE
Mileage: 63K on Interstate 46K on Aspencade 40K on ...
Status:
Online
Mana:
My Gallery
back to top
Does the engine turn in either direction, or just plain not at all?
1983 GL1100 Interstate
1983 GL1100 Aspencade
1997 GL1500 SE
 Posted: Mon Mar 16th, 2009 12:57 am 3rd Post
PMQuoteReply
RB
Status:
Offline
Mana:
back to top
With the crank I can't move it clockwise and if I try counterclockwise wise the bolt loosens up before it moves the crank. I assume the same would be true if I tried it at the stator bolt..
the covers one brushed off a little the other as I found it..
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 Apsy sold
FAIR WINDS,
RB
 Posted: Mon Mar 16th, 2009 01:24 am 4th Post
PMQuoteReply
Bagmaster
Forum Toolmaster, retired
Mileage: 140,000+ ? ...
Status:
Offline
Mana:
My Gallery
back to top
Heck, looking at that makes even me want to cry!! You just know the owner that allowed that to happen wasn't a dedicated winger.
I'd go ahead and pull those belts and trash them first thing, then popped the heads off and see what gives with the valves. I bet one of them is stuck in.
Know anyone with a bead blaster cabinet?
Michael
USS Saratoga, ships company
 Posted: Mon Mar 16th, 2009 01:31 am 5th Post
PMQuoteReply
shade tree
Mileage:
Status:
Offline
Mana:
back to top
do you know the history of this bike? it lookes like it sat in water with that much rust in frount. witch could lead to a lot of problems. ( i hope not ) can you put it in gear and move the wheel backwards to get the moto to turn? you could be 180 off on the timing marks. i wish you the best of luck. JIM
 Posted: Mon Mar 16th, 2009 01:36 am 6th Post
PMQuoteReply
Wingnumberone
Goldwing: GL1500
Mileage: 86k+
Status:
Offline
Mana:
My Gallery
back to top
Up to you, of course, but I wouldn't even try to start that thing.  With my luck, one or both of those tensioners would lock up or fail.  Then things get expensive.
6'-2", 210, old Geezer Glide and a big dumb grin.
Goldwings. . . if you're gonna have something between your legs, it might as well be enormous and smooth.
 Posted: Mon Mar 16th, 2009 01:43 am 7th Post
PMQuoteReply
Gofastandfalldown
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
You need to pull the heads and have a look inside.  Could this be a Katrina bike?  It  looks like it has been submerged in water.
One area for engine seizure that is usually overlooked is the alternator rotor.  The magnets are attached to the outside of the rotor and one can come loose and get jammed between the rotor and stator.  If that happens, there is no way the engine will budge.
 Posted: Mon Mar 16th, 2009 01:45 am 8th Post
PMQuoteReply
cycleman
Goldwing: GL1000
Mileage: 37000 ...
Status:
Offline
Mana:
My Gallery
back to top
This engine clearly looks like its been under water. I've never seen a picture like you posted from any goldwing no mater how bad it's been serviced. There are drain holes in both of the covers over the belts so no moisture can accumulate.
Looks like it might have been in New Orleans or at least somewhere it flooded.
I think the best plan is to look for another engine or bike. No matter what you do to get it running its always going to have issues.
1977 GL1000 Restoration - Now up & running.
Previous bikes - 1980 XJ650, XT500, GS550, 77 GL1000 & a few more.
 Posted: Mon Mar 16th, 2009 02:02 am 9th Post
PMQuoteReply
ThFireman
Very Active Member
Goldwing: GL1800
Mileage: 300 and building. ...
Status:
Offline
Mana:
My Gallery
back to top
I bet the bearings are rusted and seized too. Cut you loses and sell it for parts if you cant fix it quickly. I agree, it looks like a flood bike. :(
Slow Ride, Take it easy....Yea Right!
2012 GL1800 Gold Wing
GWRRA NC-L2, Lake Norman Wings
http://www.freewebs.com/gwrranc-l2/
 Posted: Mon Mar 16th, 2009 02:49 pm 10th Post
PMQuoteReply
RB
Status:
Offline
Mana:
back to top
Gee, I hadn't thought of that..not too many floods in AZ unless it got caught in a wash during a down pour.
What gets me is I did turn it over at least a dozen times with the kick starter and it turned over easily and freely..but when I used the starter..it jammed.
I'll try the wheel in reverse and see if it will move back a little..then I'll pull the heads..and see what I have. If I have to part it out I'll be pulling it apart anyway..
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 Apsy sold
FAIR WINDS,
RB
 Posted: Mon Mar 16th, 2009 03:03 pm 11th Post
PMQuoteReply
cycleman
Goldwing: GL1000
Mileage: 37000 ...
Status:
Offline
Mana:
My Gallery
back to top
Take the timing plug out & see what you can see on the flywheel. I would think that there would be some rust on the flywheel if any amount of water got into the bike, also take off a cam cover & see what you've got. The inside parts of the bike are sealed from the outside ie: oil & water can't get out ( so considering the reverse they can't get in ) except in certain locations ie: carb/exhaust.
The starter seizing up indicates to me that it engaged but won't release. Could have got wet. If bike turned over with kickstarter its not seized. The starter has locked the engine up.
It willl be interesting what you find. You might get lucky. It has to happen once & a while.
 Posted: Mon Mar 16th, 2009 03:06 pm 12th Post
PMQuoteReply
Whiskerfish
Senior Guru
Goldwing: GL1000
Mileage: 160,000 ...
Status:
Offline
Mana:
My Gallery
back to top
I think you need to pull the starter and check the clutch. Inspect the chain that the starter sprocket goes in and then check it for rotation. I believe it is supposed to turn freely one way and have resistence the other.
Have you done a oil change yet? I would think the condition of the oil drained would give you some indication as to weather or not the engine is worth persuing.
Whiskerfish
1975 Nekid Noisy and Nasty
1975 Nekid in pieces parts
 Posted: Tue Mar 17th, 2009 03:27 am 13th Post
PMQuoteReply
RB
Status:
Offline
Mana:
back to top
The oil was black and low and seemed to be all oil, just not much of it..I flushed the system once with some solvent and got some of the old residue out it now has new oil in it I figured to run it 100 miles or so and change it again.
When I pull the covers off I found that the 2/4 side was 3 teeth off..but how could I turn the engine over several times with the kick starter with it like that???
The fly wheel shows no signs of rust.
I was also able to rotate the engine back a bit before I loosened the valves with the wheel in 5th.
I loosened all the valves and was able to turn the engine over with the kick starter,
When I backed off the valves all of them moved out as I released the pressure..so maybe I haven't bent anything.
I have removed the cam wheels the 1/3 side was much worse then the 2/4 side and the back of the cam wheels showed very little rust..so I doesn't seem like it's been under water..maybe in the way of a sprinkler??? or under a down spout..just guessing here.
I plan to put it back together, set the valves and turn it by hand again.
I have cleaned it up and she looks fairly good..all the rust and white deposits came off fairly easily..the belts were toast. I could actually see the fibers coming loose on the teeth.
I'll give taking the starter off a try..no pipes on her right now anyway so it's easy enough.  But how can I turn the sprocket to move the chain///any tips on an easy way to do that...Whisker..anybody???  I actually have an old starter that I took the guts out of  maybe sticking the end in with body off would give me something to turn the sprocket with???
Keep your  fingers crossed!!!
Oh yeah, happy St. Pat's day to all you green people...
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 Apsy sold
FAIR WINDS,
RB
 Posted: Tue Mar 17th, 2009 03:55 am 14th Post
PMQuoteReply
neoracer
Goldwing: GL1200 Aspencade, GL1200 LTD, GL1200 SEi
Mileage: Aspy 99K+ SEI 73K +LTD 34K ...
Status:
Offline
Mana:
My Gallery
back to top
i would hope that u dont have a whole lot of money in this bike,because it sounds and looks like a used "ebay" motor would be worth persuing
 Posted: Tue Mar 17th, 2009 04:16 am 15th Post
PMQuoteReply
cycleman
Goldwing: GL1000
Mileage: 37000 ...
Status:
Offline
Mana:
My Gallery
back to top
Keep plugging away. Sounds like your making progress.
 Posted: Tue Mar 17th, 2009 01:53 pm 16th Post
PMQuoteReply
Whiskerfish
Senior Guru
Goldwing: GL1000
Status:
Offline
Mana:
My Gallery
back to top
You should be ablt to rotate the starter chain with your fingers.
Whiskerfish
 Posted: Tue Mar 17th, 2009 03:26 pm 17th Post
PMQuoteReply
RB
Status:
Offline
Mana:
back to top
Now that I can rotate the engine with the valves backed off completely doesn't that eliminate the starter jam and or the stator plate issue as a potential issues??? or not???
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 Apsy sold
FAIR WINDS,
RB
 Posted: Tue Mar 17th, 2009 03:38 pm 18th Post
PMQuoteReply
terry_208
Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
I wouldn't worry about replacing the motor until you've chased down all the gremlins and determine that this motor is toast. As far as missing teeth on the timing belt, strange things can happen. I believe you are doing great. The timing belts needed changed anyway. Buy new ones. You'll need them even "if" that motor is toast, to replace the ones on the next engine. Keep at it. Be certain that the cams are timed properly when turning it again. Heck, you may not have damaged anything, but If you've bent "a" valve, it may be still clear the piston. Unless you're very "flush", I would see what the actual problems are with this motor. Probably just a matter of putting this one back into service. Terry
 Posted: Tue Mar 17th, 2009 04:00 pm 19th Post
PMQuoteReply
RB
Status:
Offline
Mana:
back to top
Well, that's the plan for now maybe this A.M. I can get her put together and set the valves and she if I can turn her over with the kick starter..I have new belts, the tensioners are good spin freely and no noise.
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 Apsy sold
FAIR WINDS,
RB
 Posted: Tue Mar 17th, 2009 05:42 pm 20th Post
PMQuoteReply
Whiskerfish
Senior Guru
Goldwing: GL1000
Status:
Offline
Mana:
My Gallery
back to top
RB wrote: Now that I can rotate the engine with the valves backed off completely doesn't that eliminate the starter jam and or the stator plate issue as a potential issues??? or not???
Yea they should be ok.
On the tensioners I might play with them in the shop but no matter what I would not let those go on the road.  Do all your tests and work getting the engine running and maybe get a couple of hours of running time in the shop but if you determine that the engine is salvagable before buttoning up and going on the road the first time I would replace those. With that much corrosion inside the covers those bearings are going to be pitted and they will not last.
Whiskerfish
 Current time is 04:34 am Page:    1  2  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > This just keeps getting better and better Top of Page
