gl1100 brake upgrade  Rate Topic
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2
Author Post
 Posted: Mon Apr 13th, 2009 06:44 pm 21st Post
PMQuoteReply
Mike Toon
Very Active Member
Goldwing: GL1100 Standard
Mileage: 31,912
Status:
Offline
Mana:
back to top
Several different compounds are offered. Some metallic pad stop better than organic, but with quicker rotor wear. It's a trade off. EBC copper sintered work well.
Read more here... http://www.babcox.com/editorial/bf/bf100636.htm
____________________
1981 GL1100 Naked
2001 DR650 Dual Sport
2004 KLR650 Dual Sport
 Posted: Mon Apr 13th, 2009 09:53 pm 22nd Post
PMQuoteReply
Jason m
Very Active Member
Goldwing: GL1100 Interstate
Mileage: 56000 ...
Status:
Offline
Mana:
back to top
The brakes will not lock up the frt wheel on dry pavement. I rebuild all three calipers, both master cylinders and installed the EBS pads called for for an 82 standeard frt and back. The rear will lock up if I want it to, but the frt never has seemed strong enough. the rotors are not glazed, I have no air in the system, I see no evidence of any brake lines swelling and both frt lines are steel braided. What I have is a bike that is running at the top of the weight range when loaded. Is this all I can expect or are there different pads i should be using?
1982 Int with Vetter V w/lowers
 Posted: Mon Apr 13th, 2009 09:53 pm 23rd Post
PMQuoteReply
Jason m
Very Active Member
Mileage: 56000 ...
Status:
Offline
Mana:
back to top
 Posted: Mon Apr 13th, 2009 09:53 pm 24th Post
PMQuoteReply
Jason m
Very Active Member
Mileage: 56000 ...
Status:
Offline
Mana:
back to top
 Posted: Mon Apr 13th, 2009 10:46 pm 25th Post
PMQuoteReply
Bike...and Dennis
Goldwing: GL1200 Interstate
Mileage: 265,000+ ...
Status:
Online
Mana:
back to top
Jason m wrote:  installed the EBS pads
I have tried aftermarket pads on two different bikes and was very dissapointed in their performance. I think if you just pony-up the pennies for OEM pads, you will be surprised at how much better your brakes work.
Just my opinion, but I have a right to it.
http://members.toast.net/BikesPage/
 Posted: Mon Apr 13th, 2009 11:05 pm 26th Post
PMQuoteReply
GSMacLean
Senior Guru
Goldwing: GL1100 Aspencade, GL1500 SE
Mileage: 57,366 (GL1100) 62,210 (GL1500)
Status:
Offline
Mana:
back to top
The front should definitely be able to lock up - I locked the front up on my 1100 during the MSF ERC course I took last year - didn't drop it, but came close. And that was BEFORE I rebuilt my brakes and put stainless lines on it. So if you have put stainless lines on it, and rebuilt the caliper and master cylinder, and still are unable to threshold brake or lock the front wheel, then there's something else still wrong.
http://www.goldwingdocs.com
Read my illustrated How To guides!
 Posted: Mon Apr 13th, 2009 11:18 pm 27th Post
PMQuoteReply
Jason m
Very Active Member
Mileage: 56000 ...
Status:
Offline
Mana:
back to top
I will get OEM pads and see if they improve, thaks.-
 Posted: Mon Apr 13th, 2009 11:59 pm 28th Post
PMQuoteReply
Bike...and Dennis
Status:
Online
Mana:
back to top
Jason m wrote: I will get OEM pads and see if they improve, thaks.-
Good man, keep us posted as to your progress.
I'm goin' ridin' now! :action:
 Posted: Tue Apr 14th, 2009 12:27 am 29th Post
PMQuoteReply
Jason m
Very Active Member
Mileage: 56000 ...
Status:
Offline
Mana:
back to top
im stuck at work till 8pm. have fun
 Posted: Wed Apr 15th, 2009 09:27 pm 30th Post
PMQuoteReply
Jason m
Very Active Member
Mileage: 56000 ...
Status:
Offline
Mana:
back to top
okay not going with OEM they want $105.00 for the frt brakes alone. Does anyone know of a more aggressive pad thru aftermarket. I have the EBS pads for 1982 on it now.-
 Posted: Thu Apr 16th, 2009 02:05 am 31st Post
PMQuoteReply
dvjac
Very Active Member
Mileage: 18.5k now 140k+ all
Status:
Offline
Mana:
back to top
I am not trying to get in the improvement discussion but I want to add my two cents. I quit riding for 20 yrs and started again with an '83. My last was an '80. I have a really hard time with the brakes as a beginning ABS design.....  I rebuilt my brakes completely with lines, calipers, master cylinders and OEM pads.  I think "my" problem is a mental block to not press the rear brake hard enough for the combined proportioning valve braking...... In the "old days" I only used the rear for light drag in certain slick conditions to supplement the front. I depended on the front dual caliper to stand it on its nose in hard braking..... On the '83, the front brake or the rear/front combo used individually will not "stop"  my bike only slow it. I am diligently workin on building confidence on the necessary use of both brakes but it is hard to break old habits. dj
'73 450k,'79 CBX,'80 GL1100S new,'83 GL1100A now
 Posted: Thu Apr 16th, 2009 01:39 pm 32nd Post
PMQuoteReply
rgbeard
Location: Bonsall., CA, Phx AZ, Ensenada, MX, California USA
Goldwing: GL1200 Interstate, GL1200 LTD, GL1500 SE
Mileage: More than a few
Status:
Offline
Mana:
back to top
Jason m wrote: okay not going with OEM they want $105.00 for the frt brakes alone. Does anyone know of a more aggressive pad thru aftermarket. I have the EBS pads for 1982 on it now.-
Got this info from BikeBandit.com
EBC Sintered Double-H Brake Pads
YOUR PRICE $35.25 MSRP $37.11
"Product as advertised. Shipped quickly and fit like OEM but stops way better."
"I just put these in my 929RR to replace the worn out OE pads, and all I can say is WOW!! Went on a spirited ride today and can't believe how hard they grab. I may have to adjust my riding style slightly due to how much better the initial bite is. Very, very good upgrade at a very reasonable price."
Rusty. Enthusiast of things that ride, drive & fly.
No one had seen Tigger since the 6:10 Southbound Freight. He was last heard to say: "Tiggers can do anything!"
 Posted: Thu Apr 16th, 2009 03:47 pm 33rd Post
PMQuoteReply
Bike...and Dennis
Status:
Online
Mana:
back to top
Seems like your Honda dealer is some kind of thief. Try this site. The way I read it, they want $60 & change for the 4 front pads.
http://www.westernhonda.com/fiche_section_detail.asp?section=145979&category=Motorcycles&make=Honda&year=1982&fveh=3439
Do what you want but Honda has already done all the testing, under all kinds of conditions, and decided this was the most effective compound for your bike. It's not a generic compromise.
 Current time is 08:05 am Page:  First Page Previous Page  1  2
 Steve Saunders Goldwing Forums > Forums > Goldwing Technical Forum > gl1100 brake upgrade Top of Page
