Single Carburetor - which one?  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  ...  Next Page Last Page
Author Post
 Posted: Fri Oct 9th, 2009 09:09 pm 61st Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
I've bought a 12V electric blanket and have removed the heating wire running through it....
____________________
"They're gonna make it look like suicide."
Hunter S. Thompson, one day before his death.
 Posted: Fri Oct 9th, 2009 09:12 pm 62nd Post
PMQuoteReply
Bagmaster
Forum Toolmaster, retired
Mileage: 140,000+ ? ...
Status:
Offline
Mana:
My Gallery
back to top
CaptainMidnight85 wrote: I've bought a 12V electric blanket and have removed the heating wire running through it....
Cool, that should work too! Plus it is variable heat.
Michael
USS Saratoga, ships company
 Posted: Fri Oct 9th, 2009 09:17 pm 63rd Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
This is my primary reasoning for the PVC/Gasoline Permeation testing..... :shock:...:cheeky1:
Attachment: explosion.jpg (Downloaded 370 times)
 Posted: Fri Oct 9th, 2009 09:18 pm 64th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
The grip heater idea would make it a contained package.
Still a little warm up time.
Are you trying for warm feet or start up and ride off right away?
In cold weather I usually start the bike and let it idle while putting on my helmet and gloves. That is a minute or so.
 Posted: Fri Oct 9th, 2009 09:20 pm 65th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
I need lots of heat...
It was below freezing this morning...
Edit:
It will be contained as a unit, embedded within the manifold itself. Nothing visible or accessible aside from a electrical connection point (automotive grade) such as you would see on any sensor.
 Posted: Fri Oct 9th, 2009 09:26 pm 66th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Though I am running the Type-3 manifold on it right now, I do not like the set-up. I'm not complaining, I'm moving to something I think will be better.
 Posted: Fri Oct 9th, 2009 09:58 pm 67th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
78AZWING wrote: Don't think its possible.
Cars and trucks don't have immediate heat either, takes 5 or 6 miles before warm air starts coming out. Or warming up while cleaning snow and ice from the windows so you can see.
Actually, Jeep 2nd generation 258 6's use electrical pre-heating on their intake manifolds. I've thought of many avenues. This piece mounts to the bottom of, and through the intake directly beneath the carburetor/throttle body. Appears to be about the right size for a Type-3 manifold, but I haven't pursued one to find out. I'm going PVC.
Edit: Once engine gets to NOT, it shuts off... It's dependant on the CTS..
Attachment: p1010718yd7.jpg (Downloaded 370 times)
 Posted: Fri Oct 9th, 2009 11:54 pm 68th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Where would it go?
If memory serves right there isn't any where to mount that to the manifold.
My jeep uses the F-head 134 ci 4 cylinder. Carb is mounted directly to the head on that one. My old pickup was a '51 and had the same engine. My wagon was a 51 that some previous owner mounted a 283 in with the jeep tranny and rear end. Real fast up to 50 or so, but that was about the top end in that one. My first one was a 47 cj2a with a flat head four..
Never had one with the 258 in it so not familiar with the intakes and pre-heating on them.
 Posted: Sat Oct 10th, 2009 03:13 am 69th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Here you go. Most 2nd generation 258's came with them. I've never heard of one going bad or becoming faulty, except for the occasional vacuum leak at the O-ring.
Should be a inexpensive junker find, be it a yard or a backyard. I have not searched for one.
Edit: Chrysler/Jeep P/N J3242601 "Early Fuel EV or Evaporation" '83-'86 - no longer available. Part of Chryslers attempt at maintaining exhaust emissions compliance.
Sidenote: The recommended Weber replacement (with adapter) would've been the 32/36 @ 300 CFM or the 38/38 @ 390 CFM. Holley 2300 @ 350 CFM also. The factory Carter BBD's were prone to clogging and electrical servo failure.
Attachment: manifoldheater.jpg (Downloaded 363 times)
 Posted: Sat Oct 10th, 2009 04:15 am 70th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Weatherman was right... it's snowing.
 Posted: Sat Oct 10th, 2009 06:01 am 71st Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
recomended replacement for my carter is a solex one barrel. Don't remember the number, but I can get one for something like 90 to 120 depending on which reputable dealer you use.
Reputable IS open to interpretation.
67 degrees here. Actually good mechanicing weather now.
 Posted: Sat Oct 10th, 2009 02:27 pm 72nd Post
PMQuoteReply
ldwingnut
Goldwing: GL1100 Standard, GL1100 Interstate
Mileage:
Status:
Offline
Mana:
back to top
I am using a 30 tict- 1 round bowl VW carb.on the kit that
I sell. I going with heat tape they put on water lines to keep from frezing 110/115 volt,going to wrap the water lines
on top of engine. As you can tell by looking at my web site
ldwingnut.com ,I have plenty of room.
LD Wingnut
ldwingnut.com
 Posted: Sat Oct 10th, 2009 04:08 pm 73rd Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Low temperature throughout the night: 21 degrees
Current temp: 26 degrees
Snow covered ground... but roads are clear. Not much snow really.
RR bike prep set for 2:00 pm this afternoon in unheated garage...
Bought a big kerosene heater and its out there cooking now. :)
We're living like Vikings them RR's and I...
But we love it.
 Posted: Sun Oct 11th, 2009 01:25 am 74th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
So, is it still snowing?
http://www.appletreeauto.com/carburetors-c-347.html
the round one is $156, it says here. You have a different/better source? And one of those on each side would probably be a good dual outfit. Looks tall, though, like the solex for '60 Willys CJ5s
 Posted: Sun Oct 11th, 2009 02:16 am 75th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Stopped snowing.. but ...C O L D... out there.
Why not just get a couple of used ones and rebuild them? $20-$30 each via Samba and kits are cheap...
You're going with duals?
 Posted: Sun Oct 11th, 2009 02:24 am 76th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Might try that with my junkyard wing, along with some solid struts on the back in place of the broken rear shocks and springs. Build some kinda spring setup under the seat.
 Posted: Sun Oct 11th, 2009 06:17 am 77th Post
PMQuoteReply
badorderbob
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
LD, Not trying to sound smart, but I'm curious:shock:!! Why the 110 tape?? Also Guys, on your electrical heat set ups for heating, will there be very much pull to heat from the battery? I do like the hand grip idea, variable heat and the 12v blanket idea!! CapMid, will that have a rheostat on it also??                                   And for the snow:tongue: :D, will get ours soon enough;)!!! This morning I was sitting on a cold aluminum wet bleacher at my Grandsons football game 39', so dang foggy you could hardly see the field:cheeky1::cheeky1:!! During Half time, I went to the truck and warmed my feet up:shock::shock:!! Could have used a heat blanket then :gunhead:!!! :waving: Bob    (Man I love Spellcheck:D)
 Posted: Sun Oct 11th, 2009 06:28 am 78th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
I've got winter riding weather and you have The Indie 500 and the Brickyard 500. Fair trade I think.:action:
 Posted: Sun Oct 11th, 2009 06:44 am 79th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
:shock: Funny you should mention those Events, lived here all my life and never been too them,.......... OK, I'll trade:D:waving:BOB
 Posted: Sun Oct 11th, 2009 07:13 am 80th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
I have been out to Phoenix International Raceway twice for Nascar races. Don't really care for crowds that much, and there is absolutely NO padding on those seats. They really limit what you can bring in, so you are stuck with little cushions that will fit into see-through plastic packs, plus maybe two bottles of water. Any thing else you have to buy.
Only good thing is our seats were at the west end under that big metal awning that the spotters stand on, so we had shade most of the day. Would not have been able to stay otherwise. A hundred and such in the shade with no shade is not an experience I pay to endure.
 Current time is 08:28 am Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Single Carburetor - which one? Top of Page
