Single Carburetor - which one?  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  10  ...  Next Page Last Page
Author Post
 Posted: Sun Oct 11th, 2009 07:14 am 81st Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
What I bought is rated @ 6.7 amp current draw... 120 degree heat... with a small regulator circuit and a fairly long power cord with led indicator in a cigarette lighter power plug.... $53
I've cut out the heating element wire and separated it from the power cord. I haven't measured total length but I guess it at 50' or so.
I'm still tossing around various ideas on controlling its function, but I am leaning towards incorporating it into the fans temperature switch, making it fully automatic to the bikes temperature needs. Once a predetermined (as yet undetermined) value is reached at the switch it will shut off (but may never turn on) depending on the coolant temperature. No variable control, just on or off. Electrical input to the manifold will be at the bottom rear using a fine waterproof automotive jack like this:
Attachment: Con23.jpg (Downloaded 455 times)
____________________
"They're gonna make it look like suicide."
Hunter S. Thompson, one day before his death.
 Posted: Sun Oct 11th, 2009 01:02 pm 82nd Post
PMQuoteReply
ldwingnut
Goldwing: GL1100 Standard, GL1100 Interstate
Mileage:
Status:
Offline
Mana:
back to top
My reason was you could plug it in at night like the
diesels and be ready to go in the morning. as for the carb.
i.m useing its a new 30tict-1 for a 40 horsepower 1200cc vw.
the main jet i've change from metric to thousants of an inch
so you can go to hardware store and buy what size drill bit
you want to drill the jets,the breather is a washable life
time(if you dont hit with a air hose) offset for the vw with
hose for crancase. got to go. the leaves are falling in the smokies.
LD Wingnut
ldwingnut.com
 Posted: Mon Oct 12th, 2009 06:13 pm 83rd Post
PMQuoteReply
Cookie
Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
It wouldn't work if you were away from home but a simple electric heater pad under the maifold might get you going in the moring until your manifold got warm.
Cookie
4 76 GL 1000s and 1 75
San Mateo, CA
 Posted: Mon Oct 12th, 2009 06:24 pm 84th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Some kinda case warmer for cold mornings.
Warm up the oil, that would make a big difference.
 Posted: Mon Oct 12th, 2009 06:43 pm 85th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
There's always the programmable auto-start w/timed auto-shut-off features that some alarms have...
Could be utilized additionally for bikes left in neutral on centerstand.
 Posted: Mon Oct 12th, 2009 06:51 pm 86th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Just don't try this:
http://www.youtube.com/watch?v=csy2_65UAnc
Scary to say the least.
 Posted: Fri Oct 16th, 2009 01:38 am 87th Post
PMQuoteReply
badorderbob
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
I went today for a 30 minute ride and didn't turn on my heated plenum but I must say since I brought my maintenance up to date she ran good in 45' weather. Since my plenum is cast aluminum it holds the coolness more. On my next ride I'll posts again. I will say the coolant lines that were coming up were so hot I couldn't hold my hand on it:shock:!!  Still have to try my Weber/Holley out, to many Honey Do Stuff:(:(!!! :waving:Bob
 Posted: Sat Oct 17th, 2009 08:01 pm 88th Post
PMQuoteReply
ldwingnut
Mileage:
Status:
Offline
Mana:
back to top
Or you can buy my kit at LDWINGNUT.COM and be riding in one hour.
LD Wingnut
ldwingnut.com
 Posted: Sat Oct 17th, 2009 08:06 pm 89th Post
PMQuoteReply
freonrick
Very Active Member
Mileage: 13,500
Status:
Offline
Mana:
back to top
how is top end on your kit?:waving:
 Posted: Sat Oct 17th, 2009 08:36 pm 90th Post
PMQuoteReply
AZgl1500
Senior Moderator
Goldwing: GL1500 SE
Mileage: 61.9k on GL1500, 61.3k on ST1100
Status:
Offline
Mana:
My Gallery
back to top
freonrick wrote: how is top end on your kit?:waving:
freonrick,
ldwingnut is a member, but also a vendor.  he can't openingly reply to your request here.
Please give him a PM, or better yet, go to his website and conduct your business there.
Thanks,
 Posted: Sun Oct 18th, 2009 04:13 pm 91st Post
PMQuoteReply
flatfour
Goldwing: GL1000
Mileage: 29,000
Status:
Offline
Mana:
back to top
This is an article someone wrote at the GL1200 sight called "is your single carb too small"?
Today I had a Solex 31 PIC 7 tested on a carb flow bench.
A small company 200 miles from here has simulated the GL1000 engine by some data they have gathered somewhere (61kW, 1000ccm, cam angle, valve diameter etc...)
The result:
The carb is far too small:
At high rpm the speed of the air is too high, so there are some saturation effects and the main jet stops working properly. The full throttle enrichment jet cannot compensate this effect properly. Even with different jetting the maximum horsepower to be reached is 45kW.
The man said that this must also happen on CI setups with Holley, when the carb has about the same size. Enlargening jets is a poor compromise. The results are too high idle rpm, too rich cruising range and too weak top end mixture. And a bad mpg.
He said the minimum size for a GL1000 single carb is 36mm, but he would never recommend this. He said the best way is a Weber carb 2bbl where the secondary opens mechanically after the primary having comletely opened.
We call this "register carb", don't know the english word.
The reasons: Webers are mechanically solid, available everywhere, easy to adjust and jets can be exchanged from above. A small primary brings low and stable idling, a lot of low end torque and good cruising mpg. The bigger secondary together with the primary can even increase horsepower to calculated 70kW.
The man is 60 years old and was tuning carbs all his life.
He developed carbs in former times at the Pierburg plant.
So lets think about concentrating on 2bbl carbs or injection, I will finish my tests with my carbs, but will use also the carb the man recommended:
Weber 34DMTR, 25/27 or even a little larger.
Sorry, Ron, that I cannot bring better news.
Ray(end article)
I can attest to the Weber 28/30 working very well in a GL1000.It has all the low end power you need and extra boost when the secondary is opened.
Warmup time is very close to the stock units.I never ran a choke cable into the Weber.I reach under and hold it open for about 10 seconds and turn the cruise control/throttle lock to run the engine at a higher idle,then let choke off completley.
The throttle lock is just like pulling the choke nob because the Weber doesnt need a long choke cycle but needs help with a slightly opened throttle until engine warms some.
This is a really sweet setup once you get all your ducks in a row and understand the differences of the Weber and the stockers warmup characteristics.
Throttle response is superb and idle is very steady.
The setup could probably be moved into many different model years in little time with minimal jetting changes.It fits up nice in the GL1000(no frame cutting)and the VW manifold sits close to the water tubes,so there is some heat exchange though not too much immediate effect.
Cheers,
Flatfour
 Posted: Sun Oct 18th, 2009 05:22 pm 92nd Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
This report has been around for a while. Valid... probably, but where's the flow data? If someone took the time to set-up a flow machine to a GL 1000s specification, why was the flow data never shown for this carburetor. This has done nothing but create speculation, as too many noobs take the written word for gospel and stories evolve from opinion to fiction to fact. The data would end that.
Still, this for some is not a major concern, as the reported info assumes a owner wants 7k+(?) RPM with total efficiency. Many just want simplicity instead. Don't get me wrong as I would love to find a rebuildable 28/36 for the joy of simply just having it, let alone using it.
Hey, if one rides hard then a two barrel is the way to go, IMO.
If one just rides, then a single barrel is adequate.
If one wants simplicity, depending on the individual, a single barrel is the only option that makes sense.
Many carburetors for many reasons, yes, but its the claims I question.
 Posted: Sun Oct 18th, 2009 06:51 pm 93rd Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
I have the 28/30 on my '78 now. I can also attest to the short choke cycle and quick warm-up. Mine is on the CC manifold with the water heating/cooling jacket. I haven't had it out yet to ride, cause my mufflers are shot and I just have the headers mounted with nothing after the collectors.
Wife says it isn't too loud - she could still hear the tv, with just one door and a short hallway between her and the garage.
Idle settled in at 1050 on the tach, no loading for the time I had it running - about 5 minutes, maybe ten. and would pick right up to 6500 or so with the throttle twisted.
I did have the Junkyard Wing out twice. The 28/30 ran up fine through the gearing with not stutters or bogs. Not having plates on the bike, however I couldn't take and run down the highway. It did have plenty of GO! in first and second up to redline though.
I expect the '78 will be the same.
Attachment: GoldWing4.jpg (Downloaded 348 times)
 Posted: Sun Oct 18th, 2009 06:58 pm 94th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
What did you have on before?... the 32/36?... I can't remember.
If so, I think you'll be happier with that carb once it's set-up.
This is opinion though, as I've not tried anything other than my 32/36, so I'm interested in your findings 78.....
 Posted: Sun Oct 18th, 2009 06:59 pm 95th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Hi Guys, when we were testing over at GoldWings BackYard, the way was just putting some carbs on and hoping for the best:D! Which I can say was probably not the best way but fun,...some few knew how to jet a carb properly and others like myself kinda learned along the way. That's backyard thinking:cheeky1::cheeky1:!! Any way we shared what we thought we knew and some also came up with some neat stuff;). But like in anything you have to do a little experimenting. I guess we never thought of using flow charts, I still don't know how to even understand one:(! But it was fun,.. all I can say is we tried:cool:.  I too also agree about the simple way is a single barrel, have run my CI set up for going on ten years now. But would also like the 2 barrel, just to say I could:D. I will say I did test the 26/27Weber, but found that it made the bike run hotter and could never get the jets right for a good read on the plugs. Once I thought I had every thing dialed in , then the carb would run rich and foul out the plugs:shock:. I finally went back to my original CI and rode instead of testing!! Wife is giving be the Evil eye, gotta go back latter and keep up the Good Work,....:waving:Bob
 Posted: Sun Oct 18th, 2009 07:00 pm 96th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
You guys type too fast:D:waving:,.. I gotta go:shock::shock:
 Posted: Sun Oct 18th, 2009 07:21 pm 97th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
badorderbob2 wrote: ...when we were testing over at GoldWings BackYard
For whatever reason, they won't let me join over there.
I tend to pave my own way anyways, but teamwork has a mutual benefit for those involved. It's also mutually destructive if allowed.
So, with that being said, I choose to post my thoughts here and thank Steve for the opportunity to continue doing so.
 Posted: Sun Oct 18th, 2009 07:45 pm 98th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
There is not a lot of activity on BackYardGrill anymore for some reason.
However, if you go back to the end of the archives and work your way forward, there is an awful lot of information in the different threads.
I had the stockers on the '78. Wouldn't hold an idle - removed and cleaned.
cutting out at 50 mph - removed and cleaned.
ran good, but #3 started to flood at idle - removed and replaced by 28/30 webber.
Hah! Runs Good!
 Posted: Tue Oct 20th, 2009 02:20 am 99th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Sorry for the mishap CapMid:(,...but hope you might use any information found there:cool:!!! But for now in the next few days I'm planing to mount my Weber/Holley :) and was hoping someone might have an idea where to buy some Main Jets; 136, 137, 138. Since I don't have excess to a Dyno, I'll have to read the plugs and try to get spot on; unless someone else has another useful method/idea???  Any help will be most appreciated :waving:!!! :coollep:Bob
 Posted: Tue Oct 20th, 2009 06:43 pm 100th Post
PMQuoteReply
Cookie
Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
There was an interesting bit that came up today on NGW. They were talking about vacum signal and generating enough vacum to properly draw fuel out at idle. Since thae later cams give a fair bit more vacum this might be the way to go if you had idle problems.
Cookie
San Mateo, CA
 Current time is 06:14 am Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  10  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Single Carburetor - which one? Top of Page
