Single Carburetor - which one?  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  10  11  ...  Next Page Last Page
Author Post
 Posted: Thu Oct 22nd, 2009 12:20 am 101st Post
PMQuoteReply
flatfour
Goldwing: GL1000
Mileage: 29,000
Status:
Offline
Mana:
back to top
I dont disagree with you Captain.The initial expense may be far cheaper going one barrel vs two.I was just looking at that article and thinking it was pretty right on in the respect of the suggestions made that a little larger than a 26/27 would be a good start.
It sure had my attention.With what ive experienced thus far with the 28/30 Weber on my 77 GL,its caused me to scan the web for another setup to equip my naked 75 with the same setup.
It will be a lot easier the second time around.The cam difference between the 2 years are my only concern.
Flatfour.
 Posted: Fri Oct 23rd, 2009 06:03 am 102nd Post
PMQuoteReply
badorderbob
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Hello Gentlemen, It sounds like 2 of you are using the 28/30 Weber!! I'm sure using a single barrel will be simpler ( like my Holley 1940 carb ) which has been for me very easy to maintain over the years. The only draw back (for me) is somewhat the lack of power for passing but at least it's been established a 32/36 works well once it's set up properly! Cap what does your bike idle at, .. I have to keep mine set at about 1100rpm?  All most at the end of the month, how's your conversion coming!!        Don't know about cams but my understanding is if you have a racing cam ( I guess ) it has difficult idling:shock:,.... Still learning!!! Had to put mine conversion on the back burner,..... Piggy Flu:X,..... need some updates!!!!:pumpkin::waving: Bob
 Posted: Fri Oct 23rd, 2009 09:06 am 103rd Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Hey, Bob.
Hope you are feeling better.
Did you go and get the shot or did you come down with the flu on your own?
I won't get the shots or the nose snort or what ever they are pushing here. I always get sick from them. I figure I would rather save the money for gas or something else useful. I can always get the flu on my own. Usually I don't.
Took my Wing out for a few short mile, mile and a half rides yesterday. Never left the developement, cause I don't have the headlight and turn signals on yet. Do that today, I think.
May change the name to Raped Ape.:cooldj: Definitley a fast bike!:action:
Cut two 36" long tubes of inch and three quarter exhaust I bought from NAPA. Sure it's loud , but my neighbors don't seem to object yet.
More later on it, unless I'm riding. Then it might take a while to get back to anyone.
Pics when I can.
 Posted: Sat Oct 24th, 2009 12:01 am 104th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Hello AZ, Got my usual seasonal shot and was doing ok but then:shock:,........ thanks to my G-children one of those had pig flu and gave it to me!! I've just had terrible headaches and nausea:(, no energy whatsoever!! I have heard some like you get a reaction to the shots,.. sure would love to work on bike though. Been raining too much to even do anything!!! Later:waving:Bob
 Posted: Sat Oct 24th, 2009 12:03 am 105th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Give it a little time.
Then it will be snowing!
 Posted: Sat Oct 24th, 2009 12:42 pm 106th Post
PMQuoteReply
kb0ou
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
I finally got my LDWINGNUT manifold and Solex 30 Pic carb. put on the ole 79.
Had to advance the timing a lot to get it to run. No wonder it did not like to start good on the old carbs!!!!!!!!
I still have a bog situation when I hit the throttle hard. I drilled out a main jet to .060" and will see how that runs.
I checked the spark plugs and they were very clean with some tan color, so it is not running rich. This was running a .050 main jet.
Any ideas on the bogging situation will be appreciated.
John kb0ou
____________________
John C
My Rides; 1979 Goldwing, 1996 Dodge Cummins 400K miles Plus, 2005 Toyota Prius.
Previous Rides, lots of Hondas, 1972 BMW R75/5, SSBN Submarine.
Iron Butt Association #27222
HAM RADIO KB0OU
 Posted: Sat Oct 24th, 2009 01:09 pm 107th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Could be a bit of fuel starvation while at higher revs at speed when the throttle is hit hard. I would check-in with LD for tips...
"They're gonna make it look like suicide."
Hunter S. Thompson, one day before his death.
 Posted: Sun Oct 25th, 2009 10:36 am 108th Post
PMQuoteReply
kb0ou
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Captain,
I can adjust the throttle and it pulls good, no problem getting rpm up. I put a drilled out main jet in, drilled to .060" will see if that helps. May need to advance the timing some more.
John C
HAM RADIO KB0OU
 Posted: Sun Oct 25th, 2009 04:54 pm 109th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
The CI manual might cover you on this problem, too.
 Posted: Mon Oct 26th, 2009 07:52 am 110th Post
PMQuoteReply
kb0ou
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
78azwing,
Got the CI manual, I need to check timing, have it advanced a lot, not sure how much. Need to check my wieghts behind the plate and make sure they are working properly.
Time to break out the ole timing light, have not used that thing for a long time.
John C
HAM RADIO KB0OU
 Posted: Mon Oct 26th, 2009 10:03 am 111th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
You will need one of those screw in sight glasses, CrescentMoon.com has them.
And in some of my reading somewhere on one of the multitude of sites I've been to trying to garner information on doing my conversion, I read that if you do an oil change at the same time and leave it a quart or so low for the timing session, that the lines are easily seen in that little hole.
Other wise the oil just covers the marks and makes it extremely difficult to see any of the markings.
 Posted: Mon Oct 26th, 2009 05:52 pm 112th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
John, just curious on a few thing things, what did LD say? And how old are your plug wires and plugs,; what are they gaped per LD's recommended settings?? Being that I run the CI conversion on my 81, I do know I had to replace spark plug wires/boots, new plugs(set to their recommended gap. Mine had a flat spot too, but I'm trying to remember what caused it:(!  Also what is your idle set at and when does the flat spot occur; cold or warm, rpm, taking off etc.....  Just trying to help, just need a little more info;). Can you go back to the recommended 50 main jet if you want? I know these may be silly questions but are also maybe more enlightenment on the cause of the problems;)!! Let's us know:coollep:Bob:bat:
 Posted: Mon Oct 26th, 2009 06:29 pm 113th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Hey Bob,
How is yours running?
Mine is imitating a raped ape! It is nice to have a running motorcycle again. If it wasn't so hot around here in the summer making it difficult to do anything, it would have been done back in June.
On the other hand ( I have three, don't you? ) My riding season is a lot longer, but then so is the distance for getting anywhere.
 Posted: Tue Oct 27th, 2009 01:42 am 114th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
:(Actually,..... still on the back burner and fighting "piggy flu", anything I've been doing I about puck,.....! It's sad every time I go out and look at the bike in the garage I can't even work or ride it:(:(! Energy,.... what energy:X!! So did you get your idle problem taken care of!!Later:pumpkin::waving:Bob
 Posted: Tue Oct 27th, 2009 01:52 am 115th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Workin' on it.
Just fine tuning now.
 Posted: Tue Oct 27th, 2009 08:16 am 116th Post
PMQuoteReply
kb0ou
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Badorderbob2,
I am running dyna coils and automotive type wires and boots, Iridium spark plugs.
Plugs gapped about .025. Flat spot is just off idle. It idles nice at 800 to 1100 or so, set a little over 1000 now.
Bog is warmed up, operating temp. or cold. bog occurs at any speed, fast or slow. I have tried all kinds of setting on the idle mix.
I have 2 main jets, the .050 and the one I drilled out to .060 that I just put in. It was raining so I have not run it with it in yet. Plugs were very clean with a little tan color.
John C
HAM RADIO KB0OU
 Posted: Tue Oct 27th, 2009 12:40 pm 117th Post
PMQuoteReply
78AZWING
Very Active Member
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
I understand that you don't want to run with the plugs white.
That is too lean. The .060 should give you more color. Tan is good, White is bad, Black and sooty is too rich.
Read that somewhere.
 Posted: Tue Oct 27th, 2009 01:21 pm 118th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
Maybe: step-up to a hotter plug with a bit more gap and double check that the secondary voltage is supplying enough down to the strap.... The tan(ish) color says you're in the appropriate heat range, but there are many areas of the plug(s) that can break it down even further...
Studying them plugs with a magnifying glass on all fronts is like studying your favorite textbook, sometimes clarity comes with repetition.
 Posted: Tue Oct 27th, 2009 08:34 pm 119th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
These are just my own thoughts,..... If you are running the carbon filled type wires I'd change to copper unless this is what is called for ( not familiar with Dyna but if you mean Acell they're a good coil) with that coil your running. I was also thinking you may have to go back to square one and check settings on your carb from air mixture to main jet size (Back to the 50) , set the timing ahead according to the CI instructions. Have you also set your points properly? Also check to make sure you are getting enough fuel, (fuel filter may need to be changed)! Things just to think about, not trying to steer you the wrong way but just giving options like the rest!! Hope this helps;):pumpkin::bat::waving:Bob
 Posted: Wed Oct 28th, 2009 03:13 pm 120th Post
PMQuoteReply
CaptainMidnight85
Goldwing: GL1000
Mileage:
Status:
Online
Mana:
back to top
CaptainMidnight85 wrote: badorderbob2 wrote: ...when we were testing over at GoldWings BackYard
For whatever reason, they won't let me join over there.
I tend to pave my own way anyways, but teamwork has a mutual benefit for those involved. It's also mutually destructive if allowed.
So, with that being said, I choose to post my thoughts here and thank Steve for the opportunity to continue doing so.
Months later.... This morning I've received my acceptance into this outfits site.
Need I start a rant about this? ... I think ... NOT!
Fortunate for all involved .. I'm sure... (:~0
 Current time is 08:35 am Page:  First Page Previous Page  1  2  3  4  5  6  7  8  9  10  11  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Single Carburetor - which one? Top of Page
