Honda GL1500 Se Trike Build  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  4  5  6  7  ...  Next Page Last Page
Author Post
 Posted: Sun Oct 18th, 2009 04:25 am 21st Post
PMQuoteReply
snow
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
bought mine from a guy who used a ford ranger rearend and a mustang driveshaft. only thing a need to do is rake out the forks.
 Posted: Sun Oct 18th, 2009 07:20 pm 22nd Post
PMQuoteReply
skip20
Goldwing: GL1500, GL1500 SE
Mileage:
Status:
Offline
Mana:
back to top
Don't know why, but it's been cold here already down to the lower 30's.
Today I just moved the trike setup back some so I could walk around it better.
Got the IRS rear end centered to bike & worked (brain power) on how to mount it.
Will be a bracket to the rear crash bar area , cardboard template as in picture.
The 2 lower bars will mount to the center stand area.
Then from the rear shock mounts will have tubing back to the rear frame mounting bolt.
That should do it good.
Will build a aux. gas tank to sit on top of rear end about 22"x 10" x 8" & mount a GoldWing gas pump & sending unit. It will be controlled with a switch up front using a Chevy dual tank switch.
Wheel base came in at 75" & outer tires is 65"
Pictures are below, you can see all my pictures at this link:
http://community.webshots.com/user/skip20
Skip20
____________________
GWRRA 78111
PGR 255645
1st Bike Honda Dream 150 Dream Bought in '68
1st GoldWing GL1100
1993 Gl1500A Trike Build SOLD
To many projects to finish
 Posted: Mon Oct 19th, 2009 11:35 pm 23rd Post
PMQuoteReply
plainmech
Goldwing: GL1200 Aspencade
Mileage: 70000 ...
Status:
Offline
Mana:
back to top
very cool pics of your projects. i'd like to see more of that subaru, that's neat. couldn't tell. did you put hot tub in there?:action::waving:
87 Aspencade Use it up, wear it out, make it do, or do with out
Proud member of Texas Wild Rhinos
 Posted: Mon Oct 19th, 2009 11:53 pm 24th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Which Subaru?
The Bradley GTII has a mid-engine 2.7 Subaru 6 cyl in it.
The 3 Wheel car "RAKOONS" has a front wheel drive 2.7 Subaru 6 cyl in it.
The super mini Subaru Outback "RAKOONS' DEN" camper. No 2.7!
Was thinking of putting in a 2.7 Subaru 6 cyl  in the " RAKOONS' TOY" GoldWing Trike build, but the insurance would kill me.
How bout a mid-engine GoldWing?
SUBARU " Best Kept Secret"
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Thu Oct 22nd, 2009 04:55 pm 25th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
:dude:Well, here's the latest.
Found a diff. at "Pull-A-Part" for $66.00.
It's from a BMW 325i with 2.93:1 gearing, same as the Goldwing.
So I also had to change the axle to the older type with bolt on flange.
Should have just bought the 95 Miata rear end to begun with instead of the 2000 with the new slide in axles.
Installed the axles & now figuring how to mount the diff.
2 Picures show the rear end & last picture shows what parts I changed.
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Sat Oct 24th, 2009 07:46 pm 26th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
:dude:
OK, got the side brackets made today & welded them in.
Tacked welded the side tubing to rear end frame & made wood shock supports.
Forgot to mention that the diff. is mount to frame , but still need to make axle adp. & drive shaft.
It's up on 3 wheel & rolling around
See pictures below or all pictures here:
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Sun Oct 25th, 2009 07:02 am 27th Post
PMQuoteReply
AZgl1500
Senior Moderator
Goldwing: GL1500 SE
Mileage: 61.9k on GL1500, 61.3k on ST1100
Status:
Online
Mana:
My Gallery
back to top
Looking good. I miss having a shop to work in.
 Posted: Sun Oct 25th, 2009 05:52 pm 28th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Today used the lathe to cut the bushing holder for the rear support which are mount to the shock upper mount back to the rear end.
The back section will be bolted down using weld nut.
This way I will be able to remove this brace so & can remove the rear end section.
Skip
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Wed Oct 28th, 2009 01:25 pm 29th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Got the rear air shocks mounted, still need to hook up to compressor.
Started to make rear axle adp.
Lathe in a recess for the inner axle, now to get them hele arc welded.
Then back on the lathe to smooth out the back side, cut recess for Miata axle, drill & tap holes on both.
Last picture shows the disc brake setup after I removed the axle .
Updated as I get things done. Hope to drive around soon, then into storage for the winter & back to work on the Bradley GTII Kit Car
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Thu Oct 29th, 2009 01:43 pm 30th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Got the diff. axle adp. plate welded & machined the other side for the axles.
Have one drilled & tapped & should have them on by this evening.
Machined the drive shaft adp. on the lathe & will get it welded up today & get it
installed also. Couldn't use the one's I got waterjet cut due to the shorter wheel base.
Be ready for 1st drive soon.
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Thu Oct 29th, 2009 04:18 pm 31st Post
PMQuoteReply
SpiderBob
Goldwing: GL1500 Aspencade
Mileage: 150,000... and counting ...
Status:
Offline
Mana:
My Gallery
back to top
Skip, what are you using as your base metal for your machining
Spider Bob
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
"If a man does not keep pace with his companions, perhaps, it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away."
Patriot Guard Rider
 Posted: Thu Oct 29th, 2009 11:51 pm 32nd Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Will the night mare begins!!
LAST HOLE broke the tap.
I tell you, it no fun drilling through a hardened hub axle & a weld.
Wiped out the drill on every hole & had to use the "Drill Doctor" to resharpen.
Then had to tap a 10mm threads. 7 out of 8 ok, it's always the last one.
It's in a good 1/2" & won't come out! Any ideas????
HEY GOT THE TAP OUT!!!
There was some sticking out the bottom that I was able to get small vice grip on & slowly remove it, OH HAPPY DAYS.
2nd picture shows the Mill/Drill I have, the lathe is in the basement.
This was supposed to be a picture of it finished
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Fri Oct 30th, 2009 12:01 am 33rd Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
I would like to thank the many members which have helped me get the project up & running with body panels & parts needed, some of which listed below.
skoto1
SpiderBob
AQUAMAN
tybme
zimmerleemark
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Fri Oct 30th, 2009 12:45 am 34th Post
PMQuoteReply
SpiderBob
Status:
Offline
Mana:
My Gallery
back to top
You might try heating it, had to do that with a tap that sheared off in my axle housing on the jeep. Heated it until it was really hot and stuck in a pointed vice grip until I could turn it out (1//2" tap). The only other way is to burn it out, and put in a plug. Can't think of any other way, you sure can't drill them out. Oh, how about those places that remove studs, etc. professionally. Once I sheared off the bolt in the end of my crankshaft, had to take it in and have it professional removed. I hate doing that, as I want to know how. But they had a machine that was made for that kind of work. No choice.  The machine was lined up with the bolt and a special drill (grinding type) was pushed slowly into the bolt in a reverse direction until it actually did two jobs, came out finally on it's own but had to grind about 1/2 of it away first.
Spider Bob
Patriot Guard Rider
 Posted: Fri Oct 30th, 2009 12:59 am 35th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
SpiderBob wrote: You might try heating it, had to do that with a tap that sheared off in my axle housing on the jeep. Heated it until it was really hot and stuck in a pointed vice grip until I could turn it out (1//2" tap). The only other way is to burn it out, and put in a plug. Can't think of any other way, you sure can't drill them out. Oh, how about those places that remove studs, etc. professionally. Once I sheared off the bolt in the end of my crankshaft, had to take it in and have it professional removed. I hate doing that, as I want to know how. But they had a machine that was made for that kind of work. No choice.  The machine was lined up with the bolt and a special drill (grinding type) was pushed slowly into the bolt in a reverse direction until it actually did two jobs, came out finally on it's own but had to grind about 1/2 of it away first. Thanks for the info but got lucky & was able to get it out. Boy did I get lucky!
Heat was my second idea but didn' want to pull out the torch outfit which I haven't used in a long time
Will install Friday.
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Fri Oct 30th, 2009 04:47 am 36th Post
PMQuoteReply
skoto1
Goldwing: GL1500
Mileage: 34000 ...
Status:
Offline
Mana:
My Gallery
back to top
sorry you couldn't use them but at least you got the idea. i see um in the back ground of your fix. man that rear sure looks wide is there anyway you can cut some of the center of the frame out to narrow the width some. or not. i think mine ended up being 52 outside of tires 47 to the backing plate. just a thought. i'm starting my new 1200 trike this week and i'll take tons of pics this time and step by step it. so everyone can see. lots of 1200s running around on 2 that want to be on 3. keep up the good work and pics.
just do it and ask questions later. if you never start you'll never finish.
PGR # 190570
cc permit
gl 1988 1500 trike sold
2003 flhtuci
gl 1986 1200 trike sold
gl 1984 1200 trike sold
first bike cb 160 honda
to many to list in between
 Posted: Fri Oct 30th, 2009 11:34 am 37th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
:(It is wide, about 68" outside of tires even with the offset rims.
   I would need to narrow the rear axles & build shorter A-arms.
Maybe some day.
Let me know if you need the drive shaft adp. for your new 1200.
Looking forward to seeing the pictures.
Maybe next year I could drive out to Nashville & met you,
Let me know if your in the Knoxville area.
Sorry, sent PM instead  of Reply
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Fri Oct 30th, 2009 09:49 pm 38th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Got the axle adp. finished & installed.
Hooked up the drive shaft.
Added air to the shocks.
Finished up some welding.
Backed it up & took it on a short trip up & down the street.
Loss pressure in rear master, need to see why.
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Fri Oct 30th, 2009 11:22 pm 39th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
Just did about a 2 mile mile trip around the block.
Runs good, tracks good, hard to steer.
Hey,not bad for 3 1/2 weeks work with a few cold days off.
Waiting for parts is the hardest part!
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Posted: Sat Oct 31st, 2009 12:14 am 40th Post
PMQuoteReply
skip20
Mileage:
Status:
Offline
Mana:
back to top
skoto1 Had sent me a PM which got me thinking and maybe into more work (trouble).
I figured you could cut some out of the middle of the frame without having to change anything you would have to cut the axles but not the a arms you could make a sleeve to put the axles back togeather looks like you maybe could loose 6 in pretty easy?
My reply:
Wish you had said something earlier before I just finished all of the welding.
However due to the BMW diff rear mount it would be a little hard to do.
But you had me down there stitching my head about it.
Sounds do-able
After doing some measuring I figure I could cut the right sub-frame 3" which would center the drive shaft, then shorten the upper & lower A-arms 2".
Having to cut, weld & sleeve the axles 5" on right side & 2" on left would shorten the wheel tread 7" bring it down to about 57"
I would also have to make new frame mounts to the bike.
Let me hear what you think of all of this addition work to lose 7"
Skip20
GWRRA 78111
PGR 255645
1st GoldWing GL1100
 Current time is 09:12 am Page:  First Page Previous Page  1  2  3  4  5  6  7  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Honda GL1500 Se Trike Build Top of Page
