| 1500 trike build IRS unit |
Rating:
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: 1 2 3 4 5 6 ... |
| Author | Post |
| Posted: Sat Feb 27th, 2010 05:50 pm | 1st Post |
____________________ GL 1200 85 trike (sold) GL 1200 88 aspencade trike and trailer(sold) GL 1200 87 aspencade trike (sold) GL 1500k 89 trike build |
| Posted: Sat Feb 27th, 2010 05:54 pm | 2nd Post |
what a job im having , trying to get my photos on here , it keeps telling me there to big Last edited on Sat Feb 27th, 2010 06:20 pm by barry nunn ____________________ GL 1200 85 trike (sold) GL 1200 88 aspencade trike and trailer(sold) GL 1200 87 aspencade trike (sold) GL 1500k 89 trike build |
| Posted: Sat Feb 27th, 2010 05:59 pm | 3rd Post |
i have used a jag axel, the wishbones have been filped over so i could move the anti roll bar around to the front , as it was in the way of the shocks on the rear Attachment: forum 10 010.JPG (Downloaded 911 times) Last edited on Sat Feb 27th, 2010 06:31 pm by barry nunn ____________________ GL 1200 85 trike (sold) GL 1200 88 aspencade trike and trailer(sold) GL 1200 87 aspencade trike (sold) GL 1500k 89 trike build |
| Posted: Sat Feb 27th, 2010 06:09 pm | 4th Post |
this is the new possition of the reverse resister Attachment: skip 001.JPG (Downloaded 903 times)
| Posted: Sat Feb 27th, 2010 06:14 pm | 5th Post |
this the shock tower , with my second lot of springs as the hit the floor with the first pair , Attachment: forum 10 006.JPG (Downloaded 919 times)
| Posted: Sat Feb 27th, 2010 06:17 pm | 6th Post |
the handbrake sits under the pannier box, and it is only to one wheel , as it make this build a bit easyer Attachment: forum 10 008.JPG (Downloaded 914 times)
| Posted: Sun Feb 28th, 2010 08:14 am | 7th Post |
this is a view of the propshaft , hope the angle is not to tight , let me know what you think, I had the jag boss turned on a lathe and married it with a hardy splicer from a reliant , then bored out the center to take the bikes drive shaft ,![]()
| Posted: Sun Feb 28th, 2010 08:30 am | 8th Post |
![]() to get the box back on i have had to cut out the back , thinking of resealing the back when the build is complete, ![]()
| Posted: Sun Feb 28th, 2010 08:51 am | 9th Post |
Good work there Barry, keep those pictures coming on
____________________ John |
| Posted: Sun Feb 28th, 2010 01:43 pm | 10th Post |
Looking good. I would box the lower shock bar. You can remove the center stand & rear crash bars now, don't think you will be needing them. Use the bags & some trailer fenders, then add in the middle. The Jag is a good starting point, what is the gear ratio? Skype me at skip202 Last edited on Sun Feb 28th, 2010 01:45 pm by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Sun Feb 28th, 2010 03:04 pm | 11th Post |
this diff is 3:1 , and i think the bike was 2:9, ive had it moveing , by putting the bike on stands and letting the clutch out all seem fine , im not tolaly happy with the propshaft , think i will do as i did with the other trikes , i drilled the hardy splicer that goes on the engine and taped it to a 8mm and used a grub screw.![]() sorry it's a bad picture , i took 5 (bad light) and this is the best one
| Posted: Sun Feb 28th, 2010 03:15 pm | 12th Post |
hi skip , what did you mean , when you said you would box the lower shock bar ? it frame is under neeth the mudguard i will fibreglass the frame to the bottom of the mudguard , when it's all painted this is the mudguard on , not sure if i like it ,? may have to trim it ? these mudguards are 12" wide so the gap in between the pannier and the mudguards is around 4" the door still opens , i would be useable
| Posted: Sun Feb 28th, 2010 03:33 pm | 13th Post |
Yes it 2.93:1 By the way, I like that BIG garage you have. Are you sure the trike will fit after you put the tires on? What I did was moved the diff. over a little more in line with the driveshaft, then shorten the axle. The shock mount don't look very strong to take a good pot hole with all of those hoses in them.
| Posted: Sun Feb 28th, 2010 03:43 pm | 14th Post |
you right to laugh about the size of the garage only to relise it will not come through the door way not to worry it has to come apart to be painted , and then put back together properly, , yes i think your right i could take another piece of angle turn it upside down and weld it to the bottom shock brace , this would make a box shaped tube, good idea
| Posted: Sun Feb 28th, 2010 03:53 pm | 15th Post |
Good way to shorten the axle. You could us angle iron to help suppot axle as you weld it Last edited on Sun Feb 28th, 2010 03:55 pm by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Sun Feb 28th, 2010 04:06 pm | 16th Post |
barry nunn wrote:
LARGER Pictures are better. Last edited on Sun Feb 28th, 2010 05:00 pm by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Sun Feb 28th, 2010 04:39 pm | 17th Post |
Yeah, Barry, you need to size the pictures to about 640x480 at a minimum so that we can see the detail. Optimal size is 800x600 to fit the PC monitors that most folks have. Larger than 800 pixels wide will overlap the screens for a lot of folks.
| Posted: Sun Feb 28th, 2010 08:34 pm | 18th Post |
hope these pictures show more detail![]()
| Posted: Sun Feb 28th, 2010 08:36 pm | 19th Post |
and one with the mudguard on ![]()
| Posted: Sun Feb 28th, 2010 08:40 pm | 20th Post |
GREAT
| Current time is 08:41 am | Page: 1 2 3 4 5 6 ... |
| Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > 1500 trike build IRS unit | Top of Page |
