CLICK HERE |
Steve Saunders Goldwing Forums > Forums > General Motorcycle Discussion Forum > I am building a trike, 1st one but its not a honda |
Rating:
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: ... 2 3 4 5 6 7 8 9 10 |
| Author | Post |
| Posted: Sun Feb 5th, 2012 04:04 am | 121st Post |
i found out you can use a set of harley sporter pipes and put them in front of the rear end and just run pipes out the rear. they fit better for me that way. more room up front. but i've done them both ways. the black one in the pic i put them in the back and they where just too low. had to change it. Last edited on Tue Feb 7th, 2012 10:29 pm by skoto1 ____________________ just do it and ask questions later. if you never start you'll never finish. PGR # 190570 cc permit none at the present running. but looking gl 1988 1500 trike sold 2003 flhtuci sold gl 1986 1200 trike sold gl 1984 1200 trike sold first bike cb 160 honda to many to list in between |
| Posted: Tue Feb 7th, 2012 09:54 pm | 122nd Post |
Fenders are here so its time for me to get busy again, will post pics as soon as i can.
| Posted: Tue Feb 7th, 2012 10:14 pm | 123rd Post |
Looking Good !!!! keep up the good work. Try the auto parts , auto zone and advance. use to have diffrent lenghts and sizes of chrome pipe
____________________ John3:16 The Road is long winding hilly flat hot cold sun stars AINT IT FUN!!!! 1st bike 125HD in 1969 250Honda Dream 750Honda 10 HD 89aspencade 1994 GL 1500 Trike Past ------------------- 91HD Maybe Trike project |
| Posted: Wed Feb 8th, 2012 03:56 am | 124th Post |
The ones up here in ny don't carry them anymore all they have is exhaust tips and they aren't long enough. Last edited on Wed Feb 8th, 2012 03:58 am by dcryder |
| Posted: Sun Feb 12th, 2012 05:56 pm | 125th Post |
I got the exhaust on, but will have to extend the pipes at least another foot. also picked up a self sticking rubber floor mat from harbor freight and cut it to fit the floor boards. now I am stuck on how to go about attaching the fenders I got. They were suppose to have backings on them but don't and can't get them that way I was told. Here are some pics, so if anyone has any ideas I am listening. Attachment: IMAG0005.JPG (Downloaded 114 times) Last edited on Sun Feb 12th, 2012 05:56 pm by dcryder |
| Posted: Sun Feb 12th, 2012 05:57 pm | 126th Post |
another pic. Attachment: IMAG0006.JPG (Downloaded 113 times) Last edited on Sun Feb 12th, 2012 05:57 pm by dcryder |
| Posted: Sun Feb 12th, 2012 05:58 pm | 127th Post |
another pic. Attachment: IMAG0004.JPG (Downloaded 112 times) Last edited on Sun Feb 12th, 2012 05:58 pm by dcryder |
| Posted: Sun Feb 12th, 2012 05:59 pm | 128th Post |
one more pic. Attachment: IMAG0002.JPG (Downloaded 113 times) Last edited on Sun Feb 12th, 2012 05:59 pm by dcryder |
| Posted: Sun Feb 12th, 2012 06:32 pm | 129th Post |
they do sell them with the backing plate or splash shield at tractor supply, at least they do down here. you can always get you some chrome checker plate bolt it on or just a flat piece of thin sheet metal and weld it to the fender. you can just make you a couple brackets to run from the fenders to your frame. you can always bolt or strap you a trunk on the back for some storage. they have a nice size plastic black one at wal mart in automotive i almost used once. and you might want to run more oil than normal in your rear end since it's upside down now. the front bearing may be starved of oil. Last edited on Sun Feb 12th, 2012 06:41 pm by skoto1 ____________________ just do it and ask questions later. if you never start you'll never finish. PGR # 190570 cc permit none at the present running. but looking gl 1988 1500 trike sold 2003 flhtuci sold gl 1986 1200 trike sold gl 1984 1200 trike sold first bike cb 160 honda to many to list in between |
| Posted: Sun Feb 12th, 2012 11:35 pm | 130th Post |
well the tractor supply up here don't have 16 inch fenders for 16 inch tires and wheels, Croft trailer supply has the 16 inch tire size fenders without the backing only. so I have started to weld a flat piece of metal on the back side for a backing plate. I am thinking of running 1 inch wide 1/8 inch thick plate steel pieces from the new backing to the rear axle. I have a trunk that came with the bike I am going to use. Also I have the pinion tilted just a little about 3 1/2 degrees downward to help with the oil reaching the front bearing and have figured out just how much oil to put in it. Then I was thinking of making a body and frame to bolt to the frame of the bike. Another words the fenders will go up and down with the rear. Its just a thought, let me know what ya think.
| Posted: Tue Feb 14th, 2012 12:18 am | 131st Post |
does anyone have any ideas what I could use for lights on the back of this trike when I get that far to put a set on?
| Posted: Tue Feb 14th, 2012 11:01 am | 132nd Post |
My trike kit came with lights styled after a 1930 Ford. They fit the curve of the fender quite nicely, and are an LED light. The kit is a Triwing. I don't have time to look them up now, leaving for work shortly.
____________________ Doug Home Security System designed by Bill Ruger '94 Bermuda Green Pearl SE With Tri-Wing Trike conversion The more I try to keep my Trike clean, the less I like Chrome. |
| Posted: Fri Feb 17th, 2012 04:29 am | 133rd Post |
Thanks for the tip on the lights. I just need some feedback on what I am thinking of doing, pics will explain better so here goes. Attachment: IMAG0009.JPG (Downloaded 76 times) Last edited on Fri Feb 17th, 2012 04:30 am by dcryder |
| Posted: Fri Feb 17th, 2012 04:30 am | 134th Post |
Another pic. Attachment: IMAG0008.JPG (Downloaded 75 times) Last edited on Fri Feb 17th, 2012 04:31 am by dcryder |
| Posted: Fri Feb 17th, 2012 04:31 am | 135th Post |
Last one. Attachment: IMAG0011.JPG (Downloaded 74 times) Last edited on Fri Feb 17th, 2012 04:31 am by dcryder |
| Posted: Fri Feb 17th, 2012 09:21 am | 136th Post |
Can't see photo to well as I am looking on my phone But have you left clearance for full suspension travel.I am liking the style but its just not right yet. Can you post a picture with a full side view and I will see if I can help Ps please don't take this the wrong way I'm only trying to help Glennuk Last edited on Fri Feb 17th, 2012 10:59 am by glennuk ____________________ Glenn/uk Germany,Poland,Holland,Slovakia,Croatia,Slovenia,Austria,USA,Hungary,Ireland, chec rep,Estonia,Latvia,Lithuania,Romania on a 1988/1500 115.000 miles and rising/new 1800 start again,Italy,Switzerland,Belgium,France,Nurburgring ,Bosnia ,Montenegro ,Luxembourg , |
| Posted: Fri Feb 17th, 2012 03:01 pm | 137th Post |
No problem will take some more pics and post them later this afternoon.
| Posted: Fri Feb 17th, 2012 09:04 pm | 138th Post |
here are some more pics. Attachment: IMAG0012.JPG (Downloaded 68 times) Last edited on Fri Feb 17th, 2012 09:05 pm by dcryder |
| Posted: Fri Feb 17th, 2012 09:05 pm | 139th Post |
I hate this camera. Attachment: IMAG0013.JPG (Downloaded 65 times) Last edited on Fri Feb 17th, 2012 09:07 pm by dcryder |
| Posted: Fri Feb 17th, 2012 09:07 pm | 140th Post |
more pics. Attachment: IMAG0014.JPG (Downloaded 65 times) Last edited on Fri Feb 17th, 2012 09:08 pm by dcryder |
| Current time is 10:54 am | Page: ... 2 3 4 5 6 7 8 9 10 |
| Steve Saunders Goldwing Forums > Forums > General Motorcycle Discussion Forum > I am building a trike, 1st one but its not a honda | Top of Page |
