Steve Saunders Goldwing Forums > Forums > General Motorcycle Discussion Forum > Car tyres - why you shouldn't |
| Car tyres - why you shouldn't | Rate Topic |
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: 1 2 3 4 5 |
| Author | Post |
| Posted: Thu Nov 12th, 2009 10:58 am | 41st Post |
Its up to you of course but I think I will stay with tires that are engineered to do the job. Motorcycle tires are designed to disperse water and maintain grip while cornering where car tires are designed to disperse water in the center of the tread and not so much on the sides of the tread. Just my 2 cents.
____________________ Ride till you can't ride anymore. Yes, take that however you want. Bikes I've owned. 83 Honda Nighthawk 550 74 Honda CB450 "restored & Chopped" 86 Suzuki GS650 "restored" 82 Kawasaki Z1100 86 HD Sportster 83 Yamaha Maxim 750 "restored" 99 Honda Shadow Ace 750 99 HD Dyna Wide Glide 05 HD Road King 78 BMW R80 "restored" 84 GL1200 "My current project" I help support our Vets: http://www.navahelps.com |
| Posted: Thu Nov 12th, 2009 02:48 pm | 42nd Post |
You might want to go back and read Wexy's comment on their grip in the wet.
____________________ John |
| Posted: Thu Nov 12th, 2009 02:52 pm | 43rd Post |
On a CT if the water is dispersed from the center then where does it go if not out to the edges for dispersal? Same as a MC.
____________________ Michael Too much chrome to polish, too little time!! Have trailer, will travel!! Not all Wingers are old Wingers. PGR member. Riding in memory of my father, Clyde D. Ward, USN. WWII Myself, USN, Vietnam Vet. 68-72, 74-76 VF-194 aboard the USS. Oriskany USS Saratoga, ships company |
| Posted: Thu Nov 12th, 2009 03:39 pm | 44th Post |
Cody in MN wrote: I have seen other videos where the contact patch is much larger Ditto. This one never got up to highway speed either at which the tire "rounds out". I have an extra rear wheel now, and I am going to give it a try then make up my own mind (or what's left of it Last edited on Thu Nov 12th, 2009 03:42 pm by Geezerglider ____________________ Frank '08 GL 1800 Pearlwhite PGR Darksider #638 BT45 front 'Stone Eucopia 422 rear "You can observe a lot just by watching" Yogi Berra |
| Posted: Thu Nov 12th, 2009 03:54 pm | 45th Post |
In that video it shows a small contact patch in a lean but that can be manipulated. I can do the same thing by over inflating the tire first. Now in other post where folks have actual ran a CT they have posted that they run a lower pressure in the CT versus a higher pressure we run in a MT. CT at 36 psi versus MT at 41 psi. A CT is constructed with more belts normally versus a MT, has a higher rated load capacity and much stiffer, thicker sidewalls than a MT. Hence some's ability to actually ride a flat CT on a bike to a repair location at a reduced speed where as with a flat MT you go no where till it's repaired, replaced or trailered home. Also some of the newer CT's have a more rounded edge than others, like the Kuhmo run flat. Getting my MT's and CT's mixed up hence editing. Last edited on Thu Nov 12th, 2009 03:58 pm by Bagmaster ____________________ Michael Too much chrome to polish, too little time!! Have trailer, will travel!! Not all Wingers are old Wingers. PGR member. Riding in memory of my father, Clyde D. Ward, USN. WWII Myself, USN, Vietnam Vet. 68-72, 74-76 VF-194 aboard the USS. Oriskany USS Saratoga, ships company |
| Posted: Fri Nov 13th, 2009 01:25 pm | 46th Post |
I have been running one on my bike for over a year now.It felt weird to me a first handling wise but added a few more pounds and now it feels just like a Mc tire. Nobody has been able to mount one ona 1500? what size wheel is on the back?
| Posted: Fri Nov 13th, 2009 06:26 pm | 47th Post |
It's not so much the size of the wheel, as the sidewall clearance to the swingarm. Just not enough space. there is also differing opinions on the 1500's wheel having the correct bead retaining lip to secure a radial tire.
| Posted: Fri Nov 13th, 2009 06:34 pm | 48th Post |
I have had a car tire on my VTX for more than two years with NO ill effects and really good handling characteristics. Just my two pennies.
____________________ If I had know grankids were this much fun, I would have had them FIRST!!!!!!!!!!! |
| Posted: Fri Nov 13th, 2009 06:45 pm | 49th Post |
AZgl1500 wrote: It's not so much the size of the wheel, as the sidewall clearance to the swingarm. Just not enough space. There's also the problem that the 15 inch rims on just about all motorcycles are not a true 15 inch. This includes the GL1500's. Over on the sidecar forums they discuss this in more detail and also about folks have actually been killed trying ti fit a 15" CT on the 1500's 15' rims. Too much air pressure needed to get the bead to set.
| Posted: Fri Nov 13th, 2009 07:06 pm | 50th Post |
Michael, I had forgotten that important point. Thanks for bringing that one up.
| Posted: Fri Nov 13th, 2009 07:16 pm | 51st Post |
AZgl1500 wrote: Michael, I had forgotten that important point. Thanks for bringing that one up. You're welcome.
| Posted: Fri Nov 13th, 2009 08:21 pm | 52nd Post |
A while back there as either a link or an image posted. it was a contact patch chart, and it showed that with a car tire on a motorcycle when you lean the bike for cornering the contact patch does not shrink, it simply elongates. It showed that the car tire had a far larger contact patch than an mc tire when at the same angle. The only car tire you want to put on a bike is a run flat. Run flat tires have very strong reinforced sidewalls.
____________________ P.G.R. Member ID: 88374 http://www.patriotguard.org Our Soldiers are what make us strong. Without them there would be no USA. |
| Posted: Fri Nov 13th, 2009 09:06 pm | 53rd Post |
Lots of information on the Darkside forum if anyone is interested.
| Posted: Sat Nov 14th, 2009 01:43 am | 54th Post |
Broke Winger wrote:
Actually that is not completely correct, A Z rated tire has almost as stiff sidewalls but not so stiff that it you can feel it when leaning like with a run flat. Handles much more like a motorcycle tire. I was really going to leave this thread alone but couldn't help myself.
____________________ I am a motorcyclist, not a biker. I do not hang out in bars wearing a sleeveless T shirt and a leather vest and brag about my scooter. Nor do I refuse to wear a helmet claiming it impairs my hearing while riding something that would drown out the sound of an atomic bomb. I ride. Honorary Wild Rhino Darksider #304 |
| Posted: Sat Nov 14th, 2009 10:04 am | 55th Post |
The weather forcast for this Sunday here in Ireland is horrendous ,so it may be next week before I get the Camera mounted on the bike ,Wingnut is making up a bracket to mount the camera to the tow hitch and then I will take the bike on a good fast run on a very twisty road ,, But so far I am delighted with the grip and comfort of the tyre , Ciaran Attachment: tow bar 1.jpg (Downloaded 99 times)
____________________ http://www.shinywing.com ...An Irish based online Goldwing shop .. worldwide shipping RUDY NEEDS OUR HELP CLICK ON THE LINK BELOW .. http://www.goldwingfacts.com/forums/forum3/129204.html CIARAN (pronounced Keeron) |
| Posted: Sat Nov 14th, 2009 02:29 pm | 56th Post |
Can't wait to see the video Ciaran. Maybe it'll help those who don't know grow a better understanding.
____________________ Mike Kramer "Learn from the past, set vivid, detailed goals for the future, and live in the only moment of time over which you have any control: Now." Denis Waitley |
| Posted: Sat Nov 14th, 2009 02:54 pm | 57th Post |
Well at least it might put to bed once and for all the fears of having a car tyre on a 1800 wing (not any other motorcycle just an 1800)
| Posted: Sat Nov 14th, 2009 03:16 pm | 58th Post |
Well, you know that as long as the world is flat, those fears will never be put completely to bed. Too bad nobody here remembers the days when putting a gas motor on a common bicycle was considered pure madness.
| Posted: Sat Nov 14th, 2009 03:44 pm | 59th Post |
I made my mind up to go over to the dark side a while ago. Soon as these, over priced, MC tires are worn out.......I'm making the move. That video looked good to me.
| Posted: Sat Nov 14th, 2009 05:55 pm | 60th Post |
Ciaran, that particular tire on your bike almost has the same radius curve as a MC tire, (oops tyre).
| Current time is 06:17 am | Page: 1 2 3 4 5 |
| Steve Saunders Goldwing Forums > Forums > General Motorcycle Discussion Forum > Car tyres - why you shouldn't | Top of Page |
