| Author | Post |
ob1quixote
Very Active Member
back to top
Posted: Tue Mar 18th, 2008 12:40 am | 21st Post |
Looks just like my '84.
The other one pictured in this thread has a much different 2nd color of the 2-tone.
Whitey
back to top
Posted: Wed Mar 19th, 2008 06:23 am | 22nd Post |
Dusty wrote: Dose the tape deck work if so how much and also to ship to 78520 . Can you put a pic of the bike up so I can see what kind of extra lights you have on the bike ?
Thanks,
Dusty
Hey Dusty,
Sorry I haven't got back to you. I was checking on the tape deck. I need a schematic to put power on it. This bike has the standard Aspy lights, were you looking for more? I'll send a PM too. Thanks, Wayne
____________________ '83 Goldwing Interstate
'01 Kawasaki KLR 650
Sly
back to top
Posted: Thu Mar 20th, 2008 01:53 pm | 23rd Post |
Wayne,
When I got back from AK, exavid let me use his shop to change my rear tire and we noticed that my final drive and driven flange were getting worn. One day I'm going to have to replace them. Do you know if the splines on the flange/drive on your bike are in good shape? If so, I might buy them. They probably weigh nearly 20 pounds so shipping might cost a lot.
Thanks,
Sly
PS - I also need a speedo cable
____________________ '86 GL - Interstate
http://www.iridefar.blogspot.com
Ride to Live... and vice versa
mikef
Guru
back to top
Posted: Thu Mar 20th, 2008 03:03 pm | 24th Post |
| Wayne has an Aspy and, according to your profile, you have an Interstate. If so, the cables are different, and not interchangeable.
____________________ Mike
Retirement . . . is when you stop living at work and begin working at living.......Ok, I'm starting to get bored.
http://goldwingtech.info
http://northamericangoldwings.com/
Buy & Sell your stuff: http://RudysBackyard.com/
Whitey
back to top
Posted: Thu Mar 20th, 2008 09:16 pm | 25th Post |
mikef wrote: Wayne has an Aspy and, according to your profile, you have an Interstate. If so, the cables are different, and not interchangeable.
mikef, are the final drives and flanges the same?
Sly, Like mikef says, speedo cable is different but I will check the final drive and flanges and let you know. I will be out of town for a few days but you have 1st dibbs, ok?
mikef
Guru
back to top
Posted: Thu Mar 20th, 2008 11:52 pm | 26th Post |
| They will bolt up, but I'm not sure if there is a difference in gearing, or not.
Sly
back to top
Posted: Fri Mar 21st, 2008 01:44 pm | 27th Post |
mikef - Thanks for the speedo info.
Wayne - Great, PM me at your convenience about the drivetrain parts. I'm in no hurry; I've put nearly 15k on the bike with the worn parts so a few more thousand shouldn't leave me stranded. No plans to do the swap until my rear tire loses grooves.
I'll take my chances with the gearing. If the gears are a bit taller, a bit of performance as a trade for fuel economy and lower cruising rpm's are fine with me.
Thanks. Glad you're parting it out here on the forum. A lot of guys need plastic parts that are hard to find. I'm lucky as my bike's body parts are still functioning, worn perhaps, but functioning. The worn flanges are my fault, not Mother Honda's
Cheers,
Sly
Bigndn
back to top
Posted: Sat Mar 22nd, 2008 12:09 am | 28th Post |
| I sure could use the two small pieces that go aroung the tunnel at the top of the fairing, one above the glove box, the other on the other side. should be black and not very big, any idea how much to send them to New Brunswick Canada????
PTK502
back to top
Posted: Sat Mar 22nd, 2008 02:02 pm | 29th Post |
Hello ,
I was wondering if you still have the Front Fairing..
I would need the inside pieces and outside pieces... No electronics needed
But would need the complete fairing itself
please PM or Email me thanks!
PTK502
____________________ If It Ain't Broke, Dont Fix It...
Just Make It Faster!!!
Lollylu
back to top
Posted: Sat Mar 22nd, 2008 02:13 pm | 30th Post |
Hey, looking for a starter motor for an '85 asp, would the starter motor from the '84 you have do?
Lorraine
UBarW
Graphics Guru
back to top
Posted: Sat Mar 22nd, 2008 03:16 pm | 31st Post |
Lollylu wrote: Hey, looking for a starter motor for an '85 asp, would the starter motor from the '84 you have do?
Lorraine
My understanding is that the 84 starter motors are different than the 85-87's.
____________________ My bucket list-http://www.robsnet.com/destinations.asp
http://www.bikepics.com/members/ubarw/84gl1200/
Whitey
back to top
Posted: Fri Mar 28th, 2008 09:59 pm | 32nd Post |
Bigndn wrote: I sure could use the two small pieces that go aroung the tunnel at the top of the fairing, one above the glove box, the other on the other side. should be black and not very big, any idea how much to send them to New Brunswick Canada????
Hi Bigndn,
Sorry it took a while to get back to you, I was out of town, then site went down. I'm not sure if I have those intact. The right side of fairing was badly damaged. I will get back to you on pieces. Thanks, Wayne
Bigndn
back to top
Posted: Fri Mar 28th, 2008 10:07 pm | 33rd Post |
| Not a problem, just if you have the pieces I might be interested for sure. Keep in touch Brian
Whitey
back to top
Posted: Fri Mar 28th, 2008 10:09 pm | 34th Post |
UBarW wrote: Lollylu wrote: Hey, looking for a starter motor for an '85 asp, would the starter motor from the '84 you have do?
Lorraine
Hi Lorraine,
I do also have an '87 engine too. I'll have to check out the starter motor on it for you. I'll get back to you........ Wayne
Whitey
back to top
Posted: Sun Mar 30th, 2008 10:55 pm | 35th Post |
Bigndn wrote: Not a problem, just if you have the pieces I might be interested for sure. Keep in touch Brian
Bigndn,
Sorry, I don't see those pieces you're looking for. Anything else? Thanks, Wayne
teacher
Guru
back to top
Posted: Sun Mar 30th, 2008 11:07 pm | 36th Post |
Are you looking for the left and right fairing cover inserts like below? Click HereAttachment: Fairing cover inserts.jpg (Downloaded 116 times)
____________________ ~teacher~~~
~1985 GL1200I, Deep Jewel Green
~1980 GL1100I, Black
b679995
back to top
Posted: Mon Mar 31st, 2008 01:52 am | 37th Post |
Hi Wayne, I am looking for the square/rectangle plastic plate with 4 smaller square holes in it for the adjustment air buttons to fit through, on my 84 Aspy it's located on the right side of the dash/fairing around knee level, and has the graph that tells the amount of air to use in the AIR ride suspension, If you have it you can send ma a PM
Thank You
Steve-O
____________________ JESUS IS MY LORD, AMEN !!!!!!!
ALL ANGELS HAVE WINGS !!
1984 GL1200 Aspencade
teacher
Guru
back to top
Posted: Mon Mar 31st, 2008 11:32 am | 38th Post |
Like this b679995
Attachment: Air.jpg (Downloaded 110 times)
b679995
back to top
Posted: Mon Mar 31st, 2008 02:26 pm | 39th Post |
That is INDEED the piece, it was on there but it dissapeared during the trailer ride home, approx. 35 miles. No use tracing the route, she's just GONE. Is that one for sale? if so shoot me a price, and I'll get a postal Money Order!
Blessings
Steve-O
teacher
Guru
back to top
Posted: Mon Mar 31st, 2008 04:27 pm | 40th Post |
| No, no. I don't not have one. This one is a pic off ebay sometime back. Trust me when I say you need to take the 35 mile trip back to see if you can find it. They are very , very , very hard to find. I had to make mine from that pic.
 Current time is 05:34 pm | Page: 1 2 3 4 5 6 7 |
