homepage
shock rebuild, gl1200
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:24 am21st Post
 PM  Quote  Reply
screw down the topmount and then tighten the locknut against the mount.
Attachment: shock rebuild 020 (Small).jpg (Downloaded 631 times)
____________________
87 GL1200 Interstate(reborn ;) )
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:27 am22nd Post
 PM  Quote  Reply
then loosen the nuts to uncompress the springs, as soon as the topmount gets close to the body of the shock push it down and rotate it to engage the 2 keyed flats, once you seat it and engage the flats you will only be able to rotate it slightly. then loosen the nuts to release tension on the springs. wa-laa (as the french would say).
Attachment: shock rebuild 022 (Small).jpg (Downloaded 629 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:30 am23rd Post
 PM  Quote  Reply
next, install the 8mm by 1.00 thread pitch bolt in the air line hole and turn the shock upside down. remove the gray plastic guide ring and (you can grab it with pliers), fill with 10.5 ounces of atf.
Attachment: shock rebuild 024 (Small).jpg (Downloaded 631 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:34 am24th Post
 PM  Quote  Reply
next install the guide ring, then tape the bottom of the shock near the lower eye where the crimp is to prevent damage to the seal. then grease the inside of the seal and wet the outside with atf and push in into place. next install the steel seal seat and tap it down, then the circlip.
Attachment: shock rebuild 060 (Small).jpg (Downloaded 628 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:36 am25th Post
 PM  Quote  Reply
tapping the steel seal seat down to get room for to seat the circlip, wrap the damper shaft to protect it.
Attachment: shock rebuild 029 (Small).jpg (Downloaded 623 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:38 am26th Post
 PM  Quote  Reply
seal going on with the plastic guide.
Attachment: shock rebuild 061 (Small).jpg (Downloaded 626 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:39 am27th Post
 PM  Quote  Reply
I also changed the eye bushings. I used soap to slide them in. and a hammer handle to seat the lower eye sleeves
Attachment: shock rebuild 062 (Small).jpg (Downloaded 625 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:40 am28th Post
 PM  Quote  Reply
hey presto
Attachment: shock rebuild 069 (Small).jpg (Downloaded 618 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 09:40 am29th Post
 PM  Quote  Reply
thats it, any questions, post up and let me know. goodnight.
teacher
Senior Guru
Goldwing: GL1100 Aspencade, GL1200 Interstate
Mileage: 9100 ...
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 31st, 2006 12:25 pm30th Post
 PM  Quote  Reply
WOW! Excellent post! Way to go Gambler.:clapper::clapper::clapper:
~teacher~~~
~teacher~~~
~1985 GL1200I, Deep Jewel Green
litfuse
Guru
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Aug 1st, 2006 02:10 am31st Post
 PM  Quote  Reply
 That is a good post,proud to see you are willing to show the way.Litfuse
mosesm
Goldwing: GL1500 SE
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Aug 1st, 2006 03:56 am32nd Post
 PM  Quote  Reply
Excellent post. Just one question. How many hands do you have?
I see pictures with 2 hands, :shock:.
Great Job  Congratulations!
Halifax, Nova Scotia, Canada
95 Goldwing GL1500 SE
Renegade
Guru
Goldwing: GL1200 Aspencade, GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Aug 1st, 2006 04:04 am33rd Post
 PM  Quote  Reply
Gambler... You missed your calling...
Superb job.. Excellent pix..
Thanks.. Renegade
Old Nam Vet
LZ English 66 - 67
New '08 Titanium Nav
I'm old and wise, but was once young and stupid.
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Aug 1st, 2006 06:05 am34th Post
 PM  Quote  Reply
Thanks guys. Some pics were taken by she who tickles my fancy.;) Oh and there is a new addition to the household. Charlotte.... this was taken right after her operation.(fixed)
Attachment: shock rebuild 001 (Small).jpg (Downloaded 588 times)
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Aug 2nd, 2006 07:24 am35th Post
 PM  Quote  Reply
also, I got all the parts from Bike Bandit. they had to back order the rear shock springs, but they got them to me in about 8 days. I think progressive may be selling off new old stock and they may not make them anymore. I tried to buy the tool but they don't make that anymore either hence the homebuilt tool. the seals and bushings from bikebandit were original honda fwiw.
after riding for 2 days, I like the firmer ride, better control, less wallowing in sweepers. I haven't put any air in the front or rear and have not bottomed. also, the ride height is actually a little lower than stock springs with air. maybe a 1/2 inch.  I recommend them, control is everything.
goldtr6c
Goldwing: GL1000, GL1100 Standard, GL1200 LTD
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Aug 2nd, 2006 08:04 am36th Post
 PM  Quote  Reply
   Its so great to see someone using thier noggin and inprovising. Well done! Now on the next installment,,,,,, show us how ya fixed the cat. I know in the old days folks would stuff a tomcat headfirst into an old cowboy boot and "snip-em" just like a steer or hog, but with a tom, it's best to runaway quickly.
dean_3326
Goldwing: GL1200 Interstate
Mileage: 27,700
Status:
Offline
Mana:
  back to top
 Posted: Wed Aug 2nd, 2006 12:15 pm37th Post
 PM  Quote  Reply
Gambler, Thanks, that is a great job, like they say a picture is worth a thousand words.
:12red::cool:
Dean
Riding Motorcycles For over 53 Years
{My Magic Carpet Ride}
Winner of Steve Saunders Wooden Spoon
Thank you Lord for all my blessings.
84 Interstate with Ventu Craft Trailer
01 XR400R SOLD too old to cut the mustard anymore.
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Aug 21st, 2006 06:18 am38th Post
 PM  Quote  Reply
an update. I took the gf for a ride up to the mom's house and it felt like the bike was off a little. so I added 35 psi to the rear shocks and that made a major difference to the ride quality.  one up and no air it was firm(maybe a little too firm), now two up it was harsh, but with the addition of air it was much more supple. soft, but with control and no wallowing.  I hope that helps if anybody was thinking about doing the same thing.
Theron
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Jan 7th, 2007 12:56 am39th Post
 PM  Quote  Reply
Very nice! I received an extra pair of these shocks and am not sure how much oil is in them. Is it possible to empty out the old oil that is in these through the air line hole then just refill with 10.5 ozs. the same way, through the air line hole?
Theron
1982 GL1100 Interstate
2005 V-Star Silverado
Toledo, Ohio
Gambler
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Jan 7th, 2007 01:41 am40th Post
 PM  Quote  Reply
Theron wrote: Very nice! I received an extra pair of these shocks and am not sure how much oil is in them. Is it possible to empty out the old oil that is in these through the air line hole then just refill with 10.5 ozs. the same way, through the air line hole?
I believe some guys on the forum have done just that. might take a little time.
 Current time is 06:24 pm
Page:  First Page Previous Page  1  2  3  4  5  Next Page Last Page
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.7076 seconds (32% database + 68% PHP). 24 queries executed.
