homepage
shock rebuild, gl1200
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
GW82I
Goldwing: GL1100 Aspencade
Mileage: not enough
Status:
Offline
Mana:
  back to top
 Posted: Sat Apr 28th, 2007 05:01 pm61st Post
 PM  Quote  Reply
Thanks for the welcome guys, I'm still going through old posts and finding info I wish I'd read before attempting some of the work I've done. Being of the philosophy that if you take every nut and bolt off, the problem is sure to show itself, has got me in trouble a few times.
Right now I'm staring at the shock air compressor, lying on my garage floor, and wondering if it would be worth just pulling all the air-assist components and swapping the existing shocks with a couple of standard Progressives? Any thoughts?
Thanks,
____________________
Kerry
'82 GL1100A
Kingston, Ontario
exavid
Top Poster
Goldwing: GL1000, GL1100 Aspencade, GL1500 Aspencade
Mileage: 126,000
Status:
Offline
Mana:
  back to top
 Posted: Sat Apr 28th, 2007 05:54 pm62nd Post
 PM  Quote  Reply
I wouldn't recommend going to a spring shock on an Aspencade. The main reason for the air shock in the rear was so that you could adjust the suspension for changes such as solo and two up riding. If you go to a spring shock it's difficult to get at it to adjust the preload cam for differing loads due to the saddlebags. If the air shocks you have are the problem you can replace the seals or install Progressive 416s which is a combination air/spring shock. Not cheap but excellent shocks.
You might try looking into the air dryer on your compressor setup, I found the desiccant pretty well broken down and turned half to powder when I rebuilt an 1100 last year. Plugged up the compressor's source of air. I got new desiccant beads on eBay, cleaned the thing all up and it came back to life nicely. If you have the Helm Inc. service manual for the 1100 it gives good information with pictures and drawings on the air system. It's the best $36 you can spend on your bike.
Click Here
GW82I
Mileage: not enough
Status:
Offline
Mana:
  back to top
 Posted: Mon Apr 30th, 2007 03:07 am63rd Post
 PM  Quote  Reply
Thanks Exavid,
    I took the compressor apart, the beads were fine but I did think the spring-loaded buttons for the front/rear and increase air were a bit sticky (maybe leaving the system open for air to escape). So I cleaned those up and it seems better. The shocks still compress more than I think they should (not enough oil in them from my last attempt?) but it'll do for now. I ordered that manual so I'll wait for it to arrive and in the meantime the weatherman say's it should be a reasonable week for riding.
Thanks again,
Kerry
'82 GL1100A
Kingston, Ontario
Devil_Dog
Active Member
Goldwing: GL1200 LTD
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Fri Jul 27th, 2007 08:48 pm64th Post
 PM  Quote  Reply
I've been reading and looking through the posts.
Can anyone point me to a set of replacement springs for the rear?
I've got a 85 LTD, and I need to replace the rear springs.
Based on cost, I think I'm going to replace them with OEM or standard instead of progressive.
Anyone know where I can order the springs?
Do I need special tools to replace them?
If we were supposed to talk more than we listen, we would have two mouths and one ear.
-Mark Twain
Redwing
Senior Forum Greeter
Goldwing: None at present
Mileage: More Every Day = My Neighbours 1800.
Status:
Offline
Mana:
  back to top
 Posted: Fri Jul 27th, 2007 10:28 pm65th Post
 PM  Quote  Reply
Come on you Experts (Guru's):3sum:  Devil_Dog has a problem with the rear springs on his '85Ltd  :12red: lets get some help to this guy
:leprechaun: :18red: :leprechaun:
*****"REDWING"*****"
RED HONDA 50 AND MY NEIGHBOURS RED 1800
///////"RIDER OF THE FASTEST COLOUR"///////
////EVERYONE IS ENTITLED TO MY OPINION////
Snorebaby
Mileage: 48,310 as of 1/7/09.....42 Since 1/3/09.....18,765 Since Purchased 11/3/06
Status:
Offline
Mana:
  back to top
 Posted: Sat Jul 28th, 2007 12:19 am66th Post
 PM  Quote  Reply
devil_dog,
http://www.mawonline.com/progress.htm#Shock%20springs
(76515) $49.95 Progressive Shock Spring Kit Mfg.#: 001172
Scroll down to the Shock Spring Kits.  This is the springs you need.  I put these on mine and LOVE them.  Best money I have spent yet!!:waving:
:12ltd:'85 GL1200 LTD:12ltd:
'86 CMX450 Rebel
PGR#137660 http://www.patriotguard.org
SERRASJ Ride Photos http://annualssgwrally.us/coppermine
Give & Get help traveling: http://glhelpers.com/members
Devil_Dog
Active Member
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Jul 28th, 2007 04:26 am67th Post
 PM  Quote  Reply
Snorebaby wrote: devil_dog,
  Thanks for the info.
I think this will do the trick on mine also. I have to run them about 80 PSI, or the bottom out VERY easily. The compressor doesn't seem to want to run it that high.
I believe I have other issues, as in the air lines, for the rear. The springs will make things much easier.
I hope they're not hard to put in.
-Mark Twain
Devil_Dog
Active Member
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Jul 28th, 2007 05:15 am68th Post
 PM  Quote  Reply
I read through the whole thread. It would seem a bit much for me to tackle.
I'm  little short on space to accomplish some of this, and lack some of the tools.
What would anyone think is a fair price if I took it to someone else to have it done?
-Mark Twain
Snorebaby
Status:
Offline
Mana:
  back to top
 Posted: Sat Jul 28th, 2007 11:29 am69th Post
 PM  Quote  Reply
Devil_Dog wrote: I read through the whole thread. It would seem a bit much for me to tackle.
It is not really hard to do, just time consuming.  The hardest part was getting the bags and trailer hitch off to get to the springs, and that wasn't too bad.  As far as space goes, I did mine in my driveway.  Just put it on the center stand and remove, rebuild, replace one shock at a time.
As far as cost.....about an arm and a leg (figure about a minimum 4hr labor @ $65/hr for a shop to do it) compared to about $100 - $150 for you to do it yourself.
'86 CMX450 Rebel
bruceabryan
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Aug 26th, 2007 04:31 am70th Post
 PM  Quote  Reply
Hey, we used your most excellent directions to fix our rear shock for our 85 LTD. Thanks a lot.
Bruce
GG1947
Goldwing: GL1200 Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Nov 10th, 2007 12:23 am71st Post
 PM  Quote  Reply
Great article, I decided to do the rebuild on my 85 Interstate, however the rear shocks (original) do not have a lower circlip but a thin wire retainer for the seal. Anyone have any ideas on how to remove it, thanks
Geoff
exavid
Top Poster
Mileage: 126,000
Status:
Offline
Mana:
  back to top
 Posted: Sat Nov 10th, 2007 01:50 am72nd Post
 PM  Quote  Reply
:waving::waving: Welcome to the World's Greatest Goldwing Site GG1947!  :waving::waving:
If you can compress the shock a small amount to take the pressure off the snap ring you should be able to get one end of the ring pried out of the slot a bit with a small screwdriver or machinist's scriber. Once you get an end pried up just slip a small screwdriver between the ring and the slot. Then just keep working it around, prying a bit up each time and using the screwdriver to hold it from going back into the groove.
Redwing
Status:
Offline
Mana:
  back to top
 Posted: Sat Nov 10th, 2007 06:47 pm73rd Post
 PM  Quote  Reply
Hey bruceabryan and GG1947  :waving:  You are Both Very Welcome to The Worlds Greatest Goldwing Forum.
:clapper::clapper::clapper::clapper:
Would Both of you please update your profile and insert your LOCATION:weightlifter:
GG1947
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Nov 10th, 2007 07:48 pm74th Post
 PM  Quote  Reply
Thanks, will give it a try this weekend and advise how I made out. I have been working on my own bikes for years and just recently discovered this site, excellent place for help and information. I have attached a picture of the wire circlip in case anyone else runs into this system.
Geoff
Attachment: IMG_1726-1.jpg (Downloaded 242 times)
GG1947
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Nov 12th, 2007 12:14 am75th Post
 PM  Quote  Reply
Worked just as advertised, by compressing the shock I could tap the retaining washer down slightly and pry out (carefully!) the spring circlip. Thanks for the tip. Now on to finishing the rebuild.
Geoff
Attachment: IMG_1727-1.jpg (Downloaded 228 times)
GG1947
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Nov 17th, 2007 03:18 pm76th Post
 PM  Quote  Reply
Finished the rebuild following the pictures by Gambler and Progressive's instructions and all worked fine. Couple of items worth mentioning - the Progressive replacement damper is now sealed and therefore does not require the same amount of fluid as the stock one, they say only 2 ozs are needed. Also the position of the circlip holding the springs is about 1/4 inch higher than stock. Other than this not difficult to do. In my previous post I mentioned having to compress the shock to get at the seal retaining circlip, not a problem when reassembling as the seal will go far enough into the shock body when there is no air pressure to seat it. Gambler's "home-made" shock compressor works great.
nivek24
Goldwing: GL1100 Standard
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Dec 4th, 2007 05:09 pm77th Post
 PM  Quote  Reply
what a great post gambler, i have a 1980 gl1100ka and when checking the pressure in the rear units i get a gold coloured fluid spitting out of the schrader valve, only a small amount, it clears itself till the next time i come to check the pressure. is this normal or do i have a problem. i have only had the bike for 2months and no service  history came with it .
                       thanks kevin
exavid
Top Poster
Mileage: 126,000
Status:
Offline
Mana:
  back to top
 Posted: Wed Dec 5th, 2007 05:26 am78th Post
 PM  Quote  Reply
No problem, you're just getting a bit of the shock's oil that works it's way into the air lines. Sometimes a good bump can get oil into the air lines as the shock compresses suddenly.
nivek24
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Dec 5th, 2007 02:14 pm79th Post
 PM  Quote  Reply
Thanks for the info exavid.
cromagjeff
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Mar 29th, 2008 05:39 am80th Post
 PM  Quote  Reply
Thank you for the outstanding post!!!  It really helped in my shock rebuild.:clapper:
Thats my opinion and you know what they say about opinions.
 Current time is 06:32 pm
Page:  First Page Previous Page  1  2  3  4  5  Next Page Last Page
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.9761 seconds (10% database + 90% PHP). 25 queries executed.
