| Author | Post |
jan.t
back to top
Posted: Fri Jan 25th, 2008 04:48 pm | 81st Post |
| Hi. so what is the right way to turn the crank when replacing the belts on my gl 1200. With the # 22 offset wrench , or the crank bolt in where the timing belts are. Thank You. Ron
Big E
Very Active Member
back to top
Posted: Fri Jan 25th, 2008 05:04 pm | 82nd Post |
jan.t wrote: Hi. so what is the right way to turn the crank when replacing the belts on my gl 1200. With the # 22 offset wrench , or the crank bolt in where the timing belts are. Thank You. Ron
To turn the engine over I used a socket and ratchet on the generator bolt on the back of the engine. I turned the bolt like I was tightening it.
____________________
"Whether you think you can or whether you think you can't, you're right"
Henry Ford
exavid
Top Poster
back to top
Posted: Fri Jan 25th, 2008 05:27 pm | 83rd Post |
| I prefer to turn the engine with the crankshaft bolt, since it's directly connected to the pistons without a chain it seem more likely you could feel anything like a piston valve interference better.
Paul W. 1993 Aspencade 1982 Aspencade
Big E
Very Active Member
back to top
Posted: Fri Jan 25th, 2008 05:34 pm | 84th Post |
That would be easier too. I just followed Octains instructions and everything went well.
Henry Ford
jan.t
back to top
Posted: Fri Jan 25th, 2008 06:32 pm | 85th Post |
| Hi. It must be because the bike is a gl 1000 that octain used a # 22 off set wrench to turn the crank. With my gl 1200 I should be able to use a rachet wrench. Also my 1984 gl 1200 I removed the radiator, to get at the timing belts .The belts look in real good condition .but there is a 1/2 play up and down in the belts. Why can t I just loosen the tensioners bolts and tighten the belts up so I have 1/8 slack in them. Thanks for the great advice. Ron
exavid
Top Poster
back to top
Posted: Fri Jan 25th, 2008 06:48 pm | 86th Post |
| You could do that but do you know if the extra play in the belts is from misadjustment or maybe the belts have stretched over time? They don't cost all that much from NAPA and once changed you don't have to worry about them for years.
jan.t
back to top
Posted: Fri Jan 25th, 2008 07:54 pm | 87th Post |
| Hi. I found the generator bolt and alligned all the marks up ,and actually then ,the left belt had very little play in it maybe 3/16 of a inch. But then the right belt had about 1/2 inch of play in it. I imagine if I turn the crank 360 degrees the right belt may only have 3/16 of play in it and the left belt will have more . My bike is a 1984 interstate with 37000 miles on it. Thanks for the answers. Ron
scadaman29325
Active Member
back to top
Posted: Tue Apr 22nd, 2008 02:50 pm | 88th Post |
THANKS for the help!
Let me add (or repeat) some things I learned/did on my '78 GL1000:
Requires 2 belts NAPA# 250274
Replaced the Thermostat while doing this, NAPA #101 (no gasket or sealer needed).
I didn't need an offset wrench, socket worked fine.
Replaced hoses, NAPA #7733 cut in half+/- and trimmed.
Get them hoses HOT (soft) before working with them (hair dryer, boiling water...) it will help with FORCING them back into place. If not replacing hoses, (or even if you do) then you may consider removing the bottom hose nipple from the water pump, it could save you a lot of cussing.
Put a towel over the front fender to prevent scratching.
And don't get the belts too tight, they WILL whine...
Position the timing marks carefully and take note of those postions. The LEFT and right wanted move a little on mine when the tension was released...
Now is a good time to clean the TB covers.
Later, Phil
____________________ Per my wife, "He's doing the best he can with as little as he knows!" (I'm not sure how to take that.)
'78 daily rider, Purchased May '07, always in an ongoing sympathetic restoration...
AMA# 973498, GWRRA# 291184
jeff63
back to top
Posted: Mon Apr 28th, 2008 07:12 pm | 89th Post |
| Thanks guys, What an awesome job by Octane! This is all i need! Jeff
jakegold
back to top
Posted: Thu May 8th, 2008 12:54 am | 90th Post |
Sweet tutorial. Now I'm just hoping that since the right side pulley was off by about 10 degrees of the mark, before I fixed it, I'm not going to have to get new valves.
____________________ Currently working on:
1973 Honda CB350
1978 Honda Goldwing GL1000
1983 Honda CB650SC Nighthawk
Mechanic at night...computer engineer during the day, and lots and lots of coffee.
exavid
Top Poster
back to top
Posted: Thu May 8th, 2008 01:38 am | 91st Post |
| How many teeth off was the belt? Normally one either way won't cause mechanical damage but 10 degrees sounds like a lot. Be sure to hand turn you engine to feel for any problems before you hit the starter. Hand turning slowly won't do any damage if you made an error but hitting the starter would bend valves. The best place to turn the engine over is really on the crankshaft pulley bolt. Since it's connected a lot closer to the pistons with only a connecting rod between the crank and disaster you'll get a lot more sensitive feel. You'll also have less leverage so it's less likely damage will occur if there's an error in timing. Be sure to remove the spark plugs too so you won't be fighting compression which will make the engine stiffer to turn over. Last edited on Thu May 8th, 2008 01:41 am by exavid
jakegold
back to top
Posted: Thu May 8th, 2008 01:48 am | 92nd Post |
It was 2 off I think, there wasn't any hangups or pinging when I was just trying to get it running earlier when I was hand turning the engine over before I started messing with the timing.
Now I'm just trying to tune it up and overcome backfires out the exhaust.
Next step will be to adjust the timing on the points and make sure it's correct.
Then make sure the carbs are synced up.
And if this fails....I'm thinking maybe the valves are leaking a little too much on the exhaust stroke.
For a 1978 GL1000 that's been sitting for several years that I just got a week or so ago it's coming along.
1973 Honda CB350
exavid
Top Poster
back to top
Posted: Thu May 8th, 2008 05:58 am | 93rd Post |
| If the backfiring is occuring when you back off the throttle it could be the air cut off valve(s) if the 1000 has them similar to the 1100 and 1200. Their purpose is to prevent backfiring with decelleration.
Slow_Hand
back to top
Posted: Sat May 10th, 2008 06:07 pm | 94th Post |
Octane wrote:
This thread is for a 77 GL1000
Just out of curiosity since I'll be changing the belts on my 81 in the next couple of days, is the changing procedure for the GL1100 different or include something I need to watch out for?
____________________ '81 GL1100 Interstate
'08 KLR650
scadaman29325
Active Member
back to top
Posted: Mon May 12th, 2008 02:22 pm | 95th Post |
(bump)
I do not think there is much (or any) differences in the process...
Later, Phil
Cloud9
Active Member
back to top
Posted: Wed May 21st, 2008 07:14 pm | 96th Post |
| does the belt change apply to the 1500 also, any changes????
____________________ so much i can't even give it away george strait proud member of 2be1ask1 elkahare shrine kansas patriot guard proud founding member of the wild rinos WHAT A LONG STRANGE TRIP IT'S BEEN
Slow_Hand
back to top
Posted: Wed May 21st, 2008 09:00 pm | 97th Post |
(bump)
Later, Phil
Thanks Phil, you were right. Just like the instructions showed in here.
'08 KLR650
sonnyboy
back to top
Posted: Wed May 28th, 2008 09:15 pm | 98th Post |
| Thank for a big hand in keeping the old girl going.
Redwing
Senior Forum Greeter
back to top
Posted: Wed May 28th, 2008 09:52 pm | 99th Post |
sonnyboy
Wed May 28th, 2008
Hey sonnyboy
Welcome to The Worlds Greatest Goldwing Forum.
Please update your profile and insert your LOCATION.
____________________ *****"REDWING"*****"
RED HONDA 50 AND MY NEIGHBOURS RED 1800
///////"RIDER OF THE FASTEST COLOUR"///////
////EVERYONE IS ENTITLED TO MY OPINION////
john s h
back to top
Posted: Sun Jun 15th, 2008 08:59 pm | 100th Post |
just read that post on timing belts puts my mind at rest knowing that i can do the job(when i get my hands on one)
cheers john s h
____________________ shumi all you wingers my name is john and i used to own a 1500 six ten years ago but sold it for a motto guzzi lemans mk1 but its time to come back to the fold and i am looking for a gl1000 so any tips what to look for will be grate full
cheers
 Current time is 11:52 pm | Page: 1 2 3 4 5 6 |
