homepage
Check your FREE keyrings and buttons order status HERE. Members who missed this can get details on the KEYRINGS THREAD in the General Discussion forum, and can claim their goodies using the REQUEST FORM
Cheap Alternative for GL1000 Mufflers
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
axelwik
Senior Guru
Goldwing: None at present
Mileage: 81921 ...
Status:
Offline
Mana:
  back to top
 Posted: Thu Sep 9th, 2004 05:25 am1st Post
 PM  Quote  Reply
A few weeks ago I was in a dilemma.  I needed a new exhaust for my ’77 GL1000.  New one’s are no longer available from Honda, and aftermarket is still pretty expensive.  Expensive to me because I’m a full-time student and money is certainly not a thing I have in abundance.
In abundance, however, is my ability (willingness) to turn a wrench.  I was an Air Force aircraft mechanic for 21 years.
There sure are a lot of very noisy Harley Davidson motorcycles on the road these days.  Most of them didn’t come from the factory that way – the owners took the stock mufflers off and replaced them with aftermarket pipes to make them belch even louder.  They call them “slip-ons.”
The Harley model that is probably most common, is the Sportster.  Sportster stock mufflers, with a little tweaking, will fit pretty well on a GL1000 (maybe others too).  Since the owners of these Sportsters no longer have a use for their OEM stock mufflers, the mufflers end up on ebay.
I got a pair from a 2001 Sportster with 350 miles on them for $26 + shipping.  When buying them, make sure that the original baffles are still installed – some Harley guys punch them out for more decibels.  Also make sure they have mounting tabs welded on the sides… I think some don’t.
Here’s what I did.
The stock GL1000 header pipes are not an exact fit for the Sportster mufflers.  I took stainless steel sheet metal .010” thick and made shims to fit between the mating surface of the muffler and the mating surface of the header.  I used three .010” shims per side.  If I were to do it again I would use one shim of .028”.  Make sure the entire mating surface is covered (for a good air seal and clamping strength).  The sheet metal can be found at art supply and hardware stores.
For clamps I used standard Harley parts.  I got a pair for $5 from a Harley mechanic who had them sitting in his toolbox from all those “slip-ons” he installed.  New they are $8.50 apiece.
To support the weight of the muffler, I used some galvanized steel ¾ inch wide and about 3/16 inch thick and cut and drilled to size.
Re-jetting… maybe.  I re-jetted a little richer to compensate, but mostly to eliminate the off-idle glitch common with the early wings.
Attachment: Side View.jpg (Downloaded 383 times)
____________________
Marco,
Albuquerque, NM
'77 GL1000 (sold)
'08 Suzuki V-Strom DL650
Jason
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Sep 9th, 2004 03:25 pm2nd Post
 PM  Quote  Reply
Thats brilliant Axel. I like to see people using their heads to get around problems and your is a great solution.
Jason
FitzAl
Guru
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Thu Sep 9th, 2004 10:06 pm3rd Post
 PM  Quote  Reply
Very god thinkking axelwik, and the mufflers look very nice on the Wing as well. Well done on a good idea.
Alan Fitzpatrick.
axelwik
Senior Guru
Mileage: 81921 ...
Status:
Offline
Mana:
  back to top
 Posted: Fri Sep 10th, 2004 01:32 am4th Post
 PM  Quote  Reply
Thanks
Marco,
Albuquerque, NM
'77 GL1000 (sold)
wingnut
Admin 1
Goldwing: GL1800
Mileage: 5,700 miles
Status:
Offline
Mana:
  back to top
 Posted: Sat Sep 11th, 2004 03:00 pm5th Post
 PM  Quote  Reply
I'm a bit late on this but very well done axelwik. Nice to see a fellow Wing owner coming up with new ideas. Nice job.
Steve Saunders,
Admin and Founder Member.
BRowan
Guru
Goldwing: GL1200 Interstate
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Sep 11th, 2004 07:28 pm6th Post
 PM  Quote  Reply
Does anyone know if this would work with the GL1200?
Brian Rowan
Goldwinger1984
Senior Guru
Goldwing: GL1200 Aspencade
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Sep 12th, 2004 08:01 am7th Post
 PM  Quote  Reply
You could possibly adapt these mufflers to work on a 1200, but, since the 1200 pipes sweep up(1000's go straight back) you would have to fabricate an angled adaptor or cut off and reweld the back part of the head pipe.
Vic
http://www.gl1200goldwings.com/
axelwik
Senior Guru
Mileage: 81921 ...
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 12:52 am8th Post
 PM  Quote  Reply
Hi all,
UPDATE;
After riding the bike for awhile, I noticed that I was dragging the center stand on the pavement while cornering more than it should.  The Sportster mufflers were keeping the centerstand from retracting completely into its stowed position.
My solution was to add an s-shaped exhaust extention between the header pipes and mufflers.  Any good automotive muffler shop can do this... I just took one of the header pipes and mufflers to them and told them to make the extention with about a 2-inch offset.  Twenty dollars and 30 minutes later I had my extentions.
When mounting them, I rotated the mufflers and extentions to the point where the top of the mufflers were about where the top of the OEM mufflers would sit.  Now the centerstand rotates fully up and out of the way, and no more problems with dragging.
Also, with the extentions in place there is no longer a need for the shims that I described in the first post.
The mufflers now look much better and are further back where they should be.
Marco,
Ashland, OR
Attachment: Side 0f bike.jpg (Downloaded 1222 times)
Marco,
Albuquerque, NM
'77 GL1000 (sold)
exavid
Top Poster
Goldwing: GL1000, GL1100 Aspencade, GL1500 Aspencade
Mileage: 126,000
Status:
Online
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 01:22 am9th Post
 PM  Quote  Reply
Looks great, how do they sound?
axelwik
Senior Guru
Mileage: 81921 ...
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 01:35 am10th Post
 PM  Quote  Reply
They're certainly louder than stock, but sound much better than most of the aftermarket exhaust systems I've heard.  The mufflers are high quality and made with heavy materials which, I think, contributes to this.
It's very cost-effective because the Sportster mufflers can be found on ebay for $10-$50.
Marco
Marco,
Albuquerque, NM
'77 GL1000 (sold)
exavid
Top Poster
Mileage: 126,000
Status:
Online
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 05:44 am11th Post
 PM  Quote  Reply
Could you post a close up of your offset joint?
Renegade
Guru
Goldwing: GL1200 Aspencade, GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 01:01 pm12th Post
 PM  Quote  Reply
Sweeeeett!!!   ;)
Old Nam Vet
LZ English 66 - 67
New '08 Titanium Nav
I'm old and wise, but was once young and stupid.
axelwik
Senior Guru
Mileage: 81921 ...
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 03:49 pm13th Post
 PM  Quote  Reply
As requested, here's a closeup of the extention/offset
Attachment: Closeup.jpg (Downloaded 1192 times)
Marco,
Albuquerque, NM
'77 GL1000 (sold)
FitzAl
Guru
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 04:51 pm14th Post
 PM  Quote  Reply
That's nice work axel, well done.
Alan Fitzpatrick.
exavid
Top Poster
Mileage: 126,000
Status:
Online
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 05:15 pm15th Post
 PM  Quote  Reply
Thanks axelwik, that looks good.  I might give that a try.
axelwik
Senior Guru
Mileage: 81921 ...
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 05:49 pm16th Post
 PM  Quote  Reply
If you do it, as with any exhaust work, be certain to balance the carbs afterwards and take care of any tune-up issues.
I don't think re-jetting is necessary, but I re-jetted a little richer mostly to get better throttle response.
Marco
Marco,
Albuquerque, NM
'77 GL1000 (sold)
corneo
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Nov 23rd, 2004 08:29 pm17th Post
 PM  Quote  Reply
Nice job thinking out side of the box:clapper::clapper:
Take baby steps first when checking a problem. Check the fuses first then go to the big stuff.
jimchristiansen
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Nov 24th, 2004 12:55 am18th Post
 PM  Quote  Reply
Really nice looking... I could have saved a ton of money going this route!
Jim
Budegan
Very Active Member
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Nov 24th, 2004 08:09 am19th Post
 PM  Quote  Reply
Thats what I call using your head Jim. Nice work.
Martin Egan.
Heffo
Very Active Member
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Nov 28th, 2004 09:47 am20th Post
 PM  Quote  Reply
Its great to see another old Wing saved from the scrapper by using your head to adapt other parts. Top marks for your efforts. :clapper: :clapper: :clapper:
Dave Heffernan.
 Current time is 04:38 am
Page:    1  2  Next Page Last Page
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.5818 seconds (18% database + 82% PHP). 23 queries executed.
