Steve Saunders Goldwing Forums Home
 Search       Members   Calendar   Gallery   Help   Home   Bikers Workshop   Goldwing History
Search by username
 Buyers Guide   Goldwing Tips   Owners Reports   Links
Not logged in - Login | Register
GL1800 trunk lockout
 Moderated by: wexman, tanygaer, redbaron, Patch, wingnut
 New Topic   Reply   Printer Friendly
AuthorPost
GWEddie
Guru
Goldwing: GL1500 Aspencade, GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Oct 4th, 2005 02:40 pm1st Post
 PM  Quote  Reply
Help! I locked my keys and remote in the trunk of my GL1800 and can't get in. I know someone got in before by running a wire from the battry to some connector and this popped the trunk lock mechanism, but I can't remember how it was done. To be honest I wasn't really paying attention, after all only idiots lock their keys in the trunk.
:doh: :blushing: :headbanger:
I'm hoping someone here knows how to do this as you guys always come up with the answers.
____________________
Eddie Lambert
Lucky Eddie, to have two Goldwings; GL1800 & GL1500.
Oregonwinger
Guru
Goldwing: GL1800
Mileage: 10,250
Status:
Offline
Mana:
  back to top
 Posted: Tue Oct 4th, 2005 03:48 pm2nd Post
 PM  Quote  Reply
I would suggest hiding a key somewhere, or at the very least, the key no in memory, in wallet, or somewhere. Then you can run to keyman, and get another made. Don't ask me how I come to this conclusion !!!!   LOL  ;)   Write it on back of license plate plate, (or is that the front?), with marker, or such.  Wish I knew about 1800, but don't.
Bob Anderson
http://webpages.charter.net/catmek/andysjoint.html
RollaHome camper
2006 Nav, Cabernet Red
2 Schwinn Varsitys
For Sale 90 SE engine; perfect at 41k 600.00
wingnut
Admin
Goldwing: GL1800
Mileage: 5,700 miles
Status:
Offline
Mana:
  back to top
 Posted: Tue Oct 4th, 2005 04:44 pm3rd Post
 PM  Quote  Reply
You will have to remove the saddle for this. Then locate the 14 pin grey connector block under the passenger part of the saddle. Connect one end of a wire to the + on the battery and tip the other end to the red wire in the grey connector block. A short touch is all that is needed to pop the trunk. BTW, there is a yellow wire there as well, if you tip your power wire to the yellow one it will lock the trunk (if it's already in the closed position).
Steve Saunders,
Admin and Founder Member.
GWEddie
Guru
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Oct 4th, 2005 07:36 pm4th Post
 PM  Quote  Reply
Whew, thanks Steve. The red wire did the trick. I had a job getting through the back of the grey connector without having to strip the wire, but it worked and the sound of the trunk lock tripping was like music to my ears. I had a harder time putting the saddle back on, those darned rubber spacers. I glued them in place on the saddle so I won't have this problem next time...
Thanks again, I'd have been lost without that tip. :bowing: :bowing:
Eddie Lambert
englishted
Guru
Goldwing: GL1500 SE, GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Wed Oct 5th, 2005 04:12 pm5th Post
 PM  Quote  Reply
Thats a great tip for unlocking the trunk. Another small tip, if you or anyone else needs to do this again just use a test lamp (the type with a croccy clip at one end and a pointed probe at the other). Connect the croc to the battery and just probe through the insulation on the red wire with the pointy end and this will pop the trunk without doing any damage to the wire. :waving:
Ted Kelly.
Jason
Guru
Goldwing:
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sat Oct 8th, 2005 11:29 am6th Post
 PM  Quote  Reply
englishted wrote: Thats a great tip for unlocking the trunk. Another small tip, if you or anyone else needs to do this again just use a test lamp (the type with a croccy clip at one end and a pointed probe at the other). Connect the croc to the battery and just probe through the insulation on the red wire with the pointy end and this will pop the trunk without doing any damage to the wire. :waving:
Excellent observation Ted, most people wouln't have thought of that and would have skined the wire with a blade. :waving:
Jason
Budegan
Very Active Member
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Oct 9th, 2005 04:41 pm7th Post
 PM  Quote  Reply
I think this is a thread that all GL1800 owners should keep note of, in case the worst happens. :waving:
Martin Egan.
Big Wing
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Oct 10th, 2005 04:33 pm8th Post
 PM  Quote  Reply
GWEddie wrote:   Help! I locked my keys and remote in the trunk of my GL1800 and can't get in. I know someone got in before by running a wire from the battry to some connector and this popped the trunk lock mechanism, but I can't remember how it was done.
Dick Elwood did the same at the Blackpool Light Parade - I got in his trunk in 10 seconds using just a piece of coat hanger! Understandably, I've been asked not to disclose the method I'm afraid.
Nigel Mackintosh
Webmaster, North Wales Wings http://www.NorthWalesWings.org.uk/
Webmaster, Blackpool Light Parade http://www.goldwings.org.uk/
03Silver
Very Active Member
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Oct 10th, 2005 06:39 pm9th Post
 PM  Quote  Reply
Why the secret Nigel? I thought we were all out to help one another out. If odd methods had to be used (like big hammers or lots of tugging and swearing) then that's understandable of course. :waving:
Ambrose Renehan.
GL1800, 2003 silver.
exavid
Top Poster
Location: Tacoma, County Of Franklin Pierce, Washington USA
Goldwing: GL1000, GL1100 Aspencade, GL1500 Aspencade
Mileage: Quite a bit
Status:
Online
Mana:
  back to top
 Posted: Mon Oct 10th, 2005 07:39 pm10th Post
 PM  Quote  Reply
Big Wing wrote: GWEddie wrote:   Help! I locked my keys and remote in the trunk of my GL1800 and can't get in. I know someone got in before by running a wire from the battry to some connector and this popped the trunk lock mechanism, but I can't remember how it was done.
So what's the point of mentioning it in the first place? I suspect it's a variation on this method anyway.
http://home.comcast.net/~rkekeis/lockedtrunk.html
Paul W. 1993 Aspencade 1982 Aspencade
03Silver
Very Active Member
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Oct 10th, 2005 09:17 pm11th Post
 PM  Quote  Reply
exavid wrote: Big Wing wrote: Dick Elwood did the same at the Blackpool Light Parade - I got in his trunk in 10 seconds using just a piece of coat hanger! Understandably, I've been asked not to disclose the method I'm afraid.
Yes, why post what you did and not tell us? It's hardly a state security issue. You could use the coat hanger on the GL1500 and no-one kept that a secret.
I didn't kno wyou could use the copat hanger on the GL1800 trunk, it would be nice to know how.
Ambrose Renehan.
GWEddie
Guru
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Oct 11th, 2005 01:21 pm12th Post
 PM  Quote  Reply
wingnut wrote: I'm not sure at the moment if there is a wire nearer to the fuseboard that can be accessed without pulling the saddle or trunk cover. I'll have a look at the wiring diagram and maybe experiment on one of wexmans 1800's tomorrow. ;)
Looking at the wiring diagram Steve, it doesn't seem likely. The plug under the saddle is as close as you can get, the other side of thered wire goes to a relay, so obviously you won't be able to trigger the lock from the battery side of the relay. Pity though, it was well worth a try. Hope you didn't blow anything up on wexmans 1800. :waving:
Eddie Lambert
wingnut
Admin
Goldwing: GL1800
Status:
Offline
Mana:
  back to top
 Posted: Sat Aug 11th, 2007 02:55 pm13th Post
 PM  Quote  Reply
Update on this. One of the guys locked his keys in the trunk this morning at the Killarney meet n greet. It's an 07 Euro spec GL1800 and the red wire didn't work, neither did the yellow one. It's the BLUE wire that you need to tip the feed to on this year and model. The odd thing was that when I tipped the feed to the red wire I could still hear a click coming from the trunk but it wouldn't pop. I took a photo of the connector block and I'll post that here when we return home after the weekend.
Steve Saunders,
Broke Winger
Goldwing: GL1000, GL1100 Standard, GL1100 Interstate
Mileage: 61,000+
Status:
Offline
Mana:
  back to top
 Posted: Sat Aug 11th, 2007 06:07 pm14th Post
 PM  Quote  Reply
Well, for me it was a very useful thread. I work in road side assistance and one of the services I provide is unlocking. Now I can unlock GoldWings too. Thanks guys.
P.G.R. Member
http://www.patriotguard.org
Our Soldiers are what make us strong, are what keeps us free. Freedom has a high price, and our soldiers are the ones footing the bill. Without them there would be no America.
wingnut
Admin
Goldwing: GL1800
Status:
Offline
Mana:
  back to top
 Posted: Mon Dec 3rd, 2007 09:43 pm15th Post
 PM  Quote  Reply
Here is that GL1800 picture I promised. The blue wire you see near the top right of the connector block is the one you need to tip a wire from the battery + to;
Steve Saunders,
Flyone
Forum Greeter
Goldwing: GL1800
Mileage: 25,700 as of 5/28/08
Status:
Offline
Mana:
  back to top
 Posted: Tue Mar 4th, 2008 10:51 pm16th Post
 PM  Quote  Reply
wingnut wrote: You will have to remove the saddle for this. Then locate the 14 pin grey connector block under the passenger part of the saddle. Connect one end of a wire to the + on the battery and tip the other end to the red wire in the grey connector block. A short touch is all that is needed to pop the trunk. BTW, there is a yellow wire there as well, if you tip your power wire to the yellow one it will lock the trunk (if it's already in the closed position).
This is the very reason why we pay Steve the "big bucks"!!!! :cheeky1::cheeky1::cheeky1:
2002 GL1800 (Fastest Color)
2001 Cycle Mate CM2000 Trailer
Founding Member of the Wild Rhinos, Founding Member of KANWINGS, Kansas Patriot Guard, 2B1ASK1, AOPA and this fine website!!
"Just remember, wherever you go, there you are!"
Big Bri
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Apr 14th, 2008 08:25 pm17th Post
 PM  Quote  Reply
Hi all,
I just joined and I'm in need of some assistance.  I also locked my keys in my trunk (2002 GL1800).  I used a test lamp probe and when I tried the blue wire I get a click from the trunk, but it doesn't open.  I then tried the red wire, but nothing happened.  I then tried all the wires on the gray 14-pin connector and still nothing.  The only action was from the blue wire and that was an audible click, but no trunk popping open.
I ordered another remote (FOB) and a blank key.  Besides paying $100 plus for a lock smith to come out, do any of you have some ideas?
Thanks!
Brian McWethy
2002 GL1800
andy1800
Very Active Member
Goldwing: GL1200 Aspencade, GL1500 Aspencade, GL1800
Mileage: gl1800 17k, gl1500 44k, gl1200 61k, all miles.
Status:
Offline
Mana:
  back to top
 Posted: Mon Apr 14th, 2008 08:32 pm18th Post
 PM  Quote  Reply
Big Bri wrote: Hi all,
Thanks!
Welcome to the board Brian. the trunk lid doesn't actually pop open when you tip the wire, it just pops the lock and you then use the lever as you normally would to open it.
Big Bri
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Apr 14th, 2008 08:43 pm19th Post
 PM  Quote  Reply
Thanks Andy, I'll try it again once I get home.  If I hit it twice does it re-lock?  What if the actual key lock on the outside of the trunk is in the locked position?  Will the levers still work?  If it doesn't work, I'll post a picture of my 14-pin connector.  It does look different then the one Steve posted as it should since the bikes have different options and are different model years.
Thanks again for the quick response!
Brian McWethy
2002 GL1800
Redwing
Senior Forum Greeter
Goldwing: None at present
Mileage: More Every Day = My Neighbours 1800.
Status:
Online
Mana:
  back to top
 Posted: Mon Apr 14th, 2008 09:27 pm20th Post
 PM  Quote  Reply
Howdy Big Bri  :waving:
You are Very Welcome to The Worlds Greatest Goldwing Forum.
:clapper::clapper::clapper::clapper:
:leprechaun: :18red: :leprechaun:
*****"REDWING"*****"
RED HONDA 50 AND MY NEIGHBOURS RED 1800
///////"RIDER OF THE FASTEST COLOUR"///////
////EVERYONE IS ENTITLED TO MY OPINION////
 Current time is 12:26 am
Page:    1  2  Next Page Last Page
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.6593 seconds (29% database + 71% PHP). 31 queries executed.
