CLICK HERE |
Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Aftermarket fuel pump options for GL1200? |
| Aftermarket fuel pump options for GL1200? | Rate Topic |
| Author | Post |
| Posted: Wed May 25th, 2011 05:26 pm | 21st Post |
Here is one from JC Whitney: ************** Product Number: 21049G EMPI ELECTRONIC FUEL PUMPS FOR AIR-COOLED VOLKSWAGEN Customer Rating: Read 2 Reviews Priced from: $29.99 Overall Rating: 5 out of 5 . GOOD PRODUCT, June 27, 2008 By GASTON57 from N.B. CANADA Pros: SMALL AND STEADY GAS FLOW Cons: A LITTLE NOISY "INSTALLED IT ON MY 85 GOLD WING AND WORKS FINE SMALLENOUGH TO FIT AND MUCH LESS THAN A HONDA PUMP" How often do you shop at JC Whitney.com? Multiple Times a Year ******************** Thought this might help someone out, Included the review because this guy installed it on a 85 Gold Wing so that should be a 1200, $30 wouldn't be too hard on the pocketbook if it works. MikeA Last edited on Wed May 25th, 2011 05:32 pm by mikeatrain ____________________ Mikeatrain 1983 GL1100 Interstate Keeps on going and going and going and now it even stops! Then I found a 86 GL1200I to cheap to pass up. |
| Posted: Thu May 26th, 2011 05:10 am | 22nd Post |
I just happened across this. Don't know if it will help though...
____________________ "They're gonna make it look like suicide." Hunter S. Thompson, one day before his death. |
| Posted: Sat May 28th, 2011 12:33 pm | 23rd Post |
The 1986 SEI needs 34LB tp 38lbs to work with the EFI system on this bike
____________________ Ride safe my freinds... |
| Posted: Sat May 28th, 2011 12:42 pm | 24th Post |
ki0dj wrote: The 1986 SEI needs 34LB tp 38lbs to work with the EFI system on this bike ...he's got a carbed bike.
| Posted: Sat May 28th, 2011 07:30 pm | 25th Post |
No carbs on this one....
| Posted: Sun May 29th, 2011 02:03 am | 26th Post |
the fuel pressure for the 1986 efi is 34lbs to38lbs
| Posted: Thu Dec 1st, 2011 12:31 am | 27th Post |
I use an electric fuel pump for my auxilliary fuel tanks on my 1500. I burned up 2 Carters and am now using a Facet. They make several different models with different pressure levels. I got mine from Aircraft Spruce. I recommend the Facet. If the fuel pump on my 1500 ever goes bad I will figure out a way to use an inline external pump. Last edited on Thu Dec 1st, 2011 12:32 am by FeButter ____________________ Remember when using any forum that owning a keyboard and having an internet connection does not make anyone an expert. "There is no place for truth on the internet" Howard Wolowitz |
| Current time is 11:30 am | Page: 1 2 |
| Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Aftermarket fuel pump options for GL1200? | Top of Page |
