Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Rebuild the Timing Belt Tensioner - DIY for about $20-$25
Rebuild the Timing Belt Tensioner - DIY for about $20-$25  Rate Topic
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  Next Page Last Page
Author Post
 Posted: Wed Oct 29th, 2008 03:46 am 21st Post
PMQuoteReply
Mill Rat
Goldwing: GL1500
Mileage:
Status:
Offline
Mana:
back to top
phatty of 2 wrote: thanx for the info ,  this place just keeps gening better and better
DITTO !!!!
 Posted: Wed Oct 29th, 2008 11:47 am 22nd Post
PMQuoteReply
dean_3326
Goldwing: GL1200 Interstate
Mileage: 34,400 not even broken in.
Status:
Offline
Mana:
My Gallery
back to top
Thanks for sharing that sandiegobrass:waving:.
:12red:
Dean
____________________
Riding Motorcycles For over 55 Years
Thank you Lord for all my blessings.
"Life is simpler when you plow around the stump"
84 Interstate with Ventu Craft Trailer
 Posted: Mon Dec 8th, 2008 01:23 am 23rd Post
PMQuoteReply
Big E
Very Active Member
Goldwing: GL1200 Aspencade
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
On my way to NASSIR 1 I stopped at Jim's place and got to see the tensioner prototypes first hand.
Jim has spent some time and money on this and I will not hesitate to use his quality tensioner's when the time comes.
Thanks Jim
 Posted: Sat Feb 14th, 2009 01:48 am 24th Post
PMQuoteReply
keithg64
Goldwing: GL1500 SE
Mileage: keep's going and going and going and going
Status:
Offline
Mana:
My Gallery
back to top
Just wanted to let you know I changed the timing belts and tensioners and the job turned out great. I used Jim's "editor's choice" custom hex bolt method with a 12mm bolt and the Gates T42015 pulley that I got from Rockauto. Followed the directions step by step and had absolutely no problems.
Thanks Jim
It's not what you buy, it's what you build.
Victory Riders CMA Road Captain:
http://www.cmausa.org/default.asp
http://stronger.startlogic.com/index.html
Illinios Chapter Wild Rinos Member
 Posted: Mon Feb 16th, 2009 12:09 am 25th Post
PMQuoteReply
sandiegobrass
Senior Guru
Goldwing: GL1100 Interstate, GL1500 SE
Mileage: 1983 GL1100I: 63,000 ; 2000 GL1500SE: 22,000 ...
Status:
Offline
Mana:
My Gallery
back to top
keithg64 wrote: Just wanted to let you know I changed the timing belts and tensioners and the job turned out great. I used Jim's "editor's choice" custom hex bolt method with a 12mm bolt and the Gates T42015 pulley that I got from Rockauto. Followed the directions step by step and had absolutely no problems.
Thanks Jim
Glad to hear it gets some use... and it worked.. I was re-reading that after reading your post, and it looks like I need to edit it again... the basics are correct, but some of the details are a little messed up as I cut and pasted from method to method..
The T42015 is my favorite of the two as far as a bearing.. If you used a 12mm bolt (instead of a 10mm) I guess you had to drill out the bearing hole from 10mm to 12mm?... That works!!...I also remember that you have access to a lathe, so I presume that is how you did it??  I am guessing you had less than $50 in the pair??.. (Just for info..would have been more than $135 OEM).... Jim
Please consider helping Rudy at the link... LINK TO HELP RUDY
Have a Gold Wing? Please take the AGE POLL HERE !
SDB/Jim
2000 GL1500SE in CA
1983 GL1100I in SC
But formerly San Diego and now "temporarily" Aiken, SC
 Posted: Mon Feb 16th, 2009 03:00 am 26th Post
PMQuoteReply
keithg64
Goldwing: GL1500 SE
Status:
Offline
Mana:
My Gallery
back to top
sandiegobrass wrote: Glad to hear it gets some use... and it worked.. I was re-reading that after reading your post, and it looks like I need to edit it again... the basics are correct, but some of the details are a little messed up as I cut and pasted from method to method..
I sorry,I did use the 10mm stainless bolt and then turned down the head of the bolt in a lathe, per your instructions, and pressed that into the flange and bolted the bearing to the flange, it work real good. The bearing is hardened so drilling it out would have been difficult. I tried to drill out the bearing to accept a 7/16 bolt but that didn't work thats when I changed to a 10mm bolt, when you use the 10mm bolt all you have to do is turn the head down to fit into the flange that you drilled out before. Worked great, thanks again.
 Posted: Fri May 22nd, 2009 12:23 am 27th Post
PMQuoteReply
perrymedic
Mileage: 82,000
Status:
Offline
Mana:
back to top
any change anyone have pictures of the before and after of a rebuild?
 Posted: Fri May 29th, 2009 05:08 pm 28th Post
PMQuoteReply
sandiegobrass
Senior Guru
Status:
Offline
Mana:
My Gallery
back to top
perrymedic wrote: any change anyone have pictures of the before and after of a rebuild?
I'll take some of the versions I have... (although the sketches in the referenced stuff should give a good idea)
SDB/Jim
2000 GL1500SE in CA
1983 GL1100I in SC
 Posted: Fri May 29th, 2009 05:44 pm 29th Post
PMQuoteReply
perrymedic
Mileage: 82,000
Status:
Offline
Mana:
back to top
sorry, I was a touch confused from the sketches which is why I asked about pics.  I just thought I'd get a better idea of which I should do from both image methods.  thank you as always sandiegobrass, i've been using your knowledge to gain 10-fold of what I knew before.
 Posted: Sat Jun 6th, 2009 06:44 pm 30th Post
PMQuoteReply
Wingle
Goldwing: GL1500
Mileage: 118612km ...
Status:
Offline
Mana:
back to top
Hi SDB, thanks for your very thorough and excellent repair of the Timing Belt Tensioner. When I get around to doing them on my GL1500 in the next month or so and if they need to be replaced, I'll take photographs and submit them to one of the moderators to tag on if you don't mind. I think the 10mm Stud version will work for me.
I'm just going to check out the price differences here in Canada for comparison.
Thanks again Colm
<-----------Zoe and Duff
Doing nothing is very hard to do ... you never know when you're finished. - Leslie Nielsen RIP
Metallic Blue Green is the new Black!
 Posted: Sat Jul 18th, 2009 05:15 pm 31st Post
PMQuoteReply
Goldwinger1984
Senior Guru
Mileage:
Status:
Offline
Mana:
back to top
Terrific info Jim, thanks for posting.
Vic
http://www.gl1200goldwings.com/
 Posted: Thu Oct 22nd, 2009 12:57 am 32nd Post
PMQuoteReply
sandiegobrass
Senior Guru
Status:
Offline
Mana:
My Gallery
back to top
Goldwinger1984 wrote: Terrific info Jim, thanks for posting....Vic
thank YOU.. and I still owe some more pictures..
SDB/Jim
2000 GL1500SE in CA
1983 GL1100I in SC
 Posted: Fri Oct 23rd, 2009 05:33 am 33rd Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Thanks for Help Jim, about 500 miles no problem:clapper:! Pictures are of tensioner rebuild; forgot to take some installed on bike:gunhead:, Hope the Help!! :waving:Bob
 Posted: Sat Oct 24th, 2009 05:08 pm 34th Post
PMQuoteReply
4lablover
Goldwing: GL1800
Mileage: 25,000
Status:
Offline
Mana:
back to top
I recently purchased a GL1500 with 80k miles.  I'm working through the maintenance procedures and began by replacing a dry rotted rear tire with an Elite III.  Next up is the timing belt replacement.  Thanks for the great info on the alternative tensioners.  I'm going to try and save a few bucks.  Not to mention they look like a great way to go.  Thanks again.  Bob
 Posted: Sat Oct 24th, 2009 06:42 pm 35th Post
PMQuoteReply
sandiegobrass
Senior Guru
Status:
Offline
Mana:
My Gallery
back to top
badorderbob2 wrote: Thanks for Help Jim, about 500 miles no problem:clapper:! Pictures are of tensioner rebuild; forgot to take some installed on bike:gunhead:, Hope the Help!! :waving:Bob
Nice pictures!  Thanks.. I won't need to find mine now..
and that is my favorite method with the 42015 bearings (but the bolt size looks bigger than the 10mm.. is that just the pics or did you drill out the bearing mounting hole??)
SDB/Jim
2000 GL1500SE in CA
1983 GL1100I in SC
 Posted: Sun Oct 25th, 2009 02:01 am 36th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
No Jim I believe that's just the pictures, 10mm bolts, turned down heads, did everything like you recommended and works GREAT!!!:clapper::clapper::clapper::waving:, Bob
 Posted: Thu Dec 17th, 2009 05:42 pm 37th Post
PMQuoteReply
SuzukiStorm
Goldwing: GL1500 SE
Mileage: 96452 ...
Status:
Offline
Mana:
back to top
U are the best one man, save my money!
 Posted: Fri Feb 26th, 2010 07:21 pm 38th Post
PMQuoteReply
gold6060
Goldwing: GL1000, GL1000 LTD, GL1500 SE
Mileage:
Status:
Offline
Mana:
back to top
merci beaucoup
 Posted: Sat Feb 27th, 2010 05:14 am 39th Post
PMQuoteReply
gold6060
Mileage:
Status:
Offline
Mana:
back to top
merci beaucoup
 Posted: Mon Mar 1st, 2010 12:14 pm 40th Post
PMQuoteReply
Lightin
Goldwing: GL1500 Aspencade
Mileage:
Status:
Online
Mana:
back to top
Thanks for all your time and shareing this easy money saving Tip
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Trike project
 Current time is 08:58 am Page:  First Page Previous Page  1  2  3  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Rebuild the Timing Belt Tensioner - DIY for about $20-$25 Top of Page
