Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > 82 GL1100 Aspencade Starter Refresh
82 GL1100 Aspencade Starter Refresh  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2  3  4  5  Next Page Last Page
Author Post
 Posted: Sun Oct 4th, 2009 07:09 pm 61st Post
PMQuoteReply
Xtracho
Goldwing: GL1200 Aspencade
Mileage: 66K
Status:
Offline
Mana:
My Gallery
back to top
OK.....did the refresh on my 1200....now I'm having a helluva time getting the starter back in. Am I doing something wrong? Is there a trick to getting the splined end of the starter to match up with the gear inside the housing?
Or maybe I'm just too stupid to figure it out.
____________________
Mark
1984 GL 1200 Aspencade
"To live you must be willing to die" Amir Vahedi
My father gets smarter everyday that he's gone.
"I worried that I had no shoes until I saw a man that had no feet"
 Posted: Tue Oct 6th, 2009 12:24 am 62nd Post
PMQuoteReply
icechopper
Goldwing: GL1200 Interstate
Mileage:
Status:
Offline
Mana:
back to top
My starter was difficult to reinstall also.  I messed with it for awhile but kept force along the axis of the starter shaft toward the splined gear while rocking and rotating the damn thing (gentley) around until it seated.  I spoke both dirty and kindly to it but kept the faith that it couldn't go together any other way.  Hope this helps.
 Posted: Tue Oct 6th, 2009 03:05 am 63rd Post
PMQuoteReply
Xtracho
Mileage: 66K
Status:
Offline
Mana:
My Gallery
back to top
Thanks..... got it in finally. Had to use brute force. Took the gear out of the housing, put it on top of the splined shaft and hammered it on. Moved it a few teeth and hammered again. Did that over and over until the shaft would fit into the gear without resistance. Put the gear back in the housing and the starter slid right in.
Guess you can't always be gentle with the things!
Mark
 Posted: Tue Oct 6th, 2009 04:49 pm 64th Post
PMQuoteReply
icechopper
Mileage:
Status:
Offline
Mana:
back to top
Is there any way that the gear on the 1200 can accidently fall down into the case?  I have read that it is a concern on other models but I didn't see it possible on this one, just curious.
 Posted: Tue Oct 6th, 2009 06:22 pm 65th Post
PMQuoteReply
Xtracho
Mileage: 66K
Status:
Offline
Mana:
My Gallery
back to top
I suppose there is a way and I've heard of others losing that gear into the housing. I was especially careful removing mine. I used a magnetic retriever and also latched onto it with a pair of needle nose pliers. Getting it out and back in was no problem. Just have to be careful.
Mark
 Posted: Wed Oct 7th, 2009 03:03 am 66th Post
PMQuoteReply
cheeprider
Active Member
Goldwing: GL1100 Interstate
Mileage: 45,000
Status:
Offline
Mana:
back to top
I used your article and rebuilt my starter. It works now.
I think the negtive cable on the battery should be removed first, because if you touch the frame with a tool while removing the cable nothing happens. If you touch something while removing the postive cable, You will get a spark and maybe fire something.
Thanks forl the help.
It is better to know where you are going than to get there fast.
former rides
1960 1950 5 horsepower Cushman scooter
1982 1974 750 cc Honda
2004 2008 50 cc Alantis Derby Scooter
2005 1991 800 cc Suzuki Intruder
2006 2001 1400cc Susuki Intrude
2009 1982 1100cc Honda Goldwing
 Posted: Wed Oct 7th, 2009 07:28 am 67th Post
PMQuoteReply
70CBto85GL
Goldwing: GL1200 LTD
Mileage: The Wing: 65,000m My butt: 155K
Status:
Offline
Mana:
back to top
It would appear a bunch of us chose late Sept, early October to do starters.  I just finished up my 85 1200 LTD.  Perhaps I cheated -- more on that later. I pulled mine a couple of weeks ago.
I use the side-stand method after draining the oil. Consistent with the earlier post on the 86, I figured out that the left pipes had to drop, the crash bar come off, the shift pedal out, and the rear exhaust stud removed.  Even with that the starter removal becomes a slight geometry problem.  Just a matter of hitting the right twist and angle -- by design (good ol' engineers at Honda).
Finally, I cracked the starter open.  It was no wonder it had ceased to turn - it was a real mess inside.  So then I cheated: I ordered a new one on Ebay for $135 including shipping.  Bought a set of header gaskets to replace the crushed ones.
Reinstall was, surprisingly, a breeze.   I used Sylglide on the shaft and collar and it slid right in once aligned and jostled a bit. Once secure and wired up, I briefly tested the starter before adding the new oil. Damn, spun like a top!  I heard myself saying out loud: "Good call."
Took some time reassembling with all the inter-related parts (pipes, header, shifter & fairing). Fired her up and rode down the block and back.  Fires almost instantly when warmed up.
Now I've got a real messy starter lying on the work bench waiting for some attention.  I figure a spare can't hurt.  After reading this extraordinary thread I intend to pop the new starter out in about 10K miles and clean out all the break-in brush dust.  Nevertheless, folks, I recommend the new starter route as well if you can get one in that price range.
Joe
Previously a 1970 Honda CB 750 (for 26 years)
 Posted: Tue Oct 27th, 2009 08:42 pm 68th Post
PMQuoteReply
StraightWings
Goldwing: GL1000, GL1100 Interstate, GL1800
Mileage: 2008 was a good year: 52,432 miles on 11 different ... ...
Status:
Offline
Mana:
back to top
Excellent write up.  A lot of care, well laid out, well documented.  Most people are afraid to deal with electrics, and your article makes it obvious that anyone who is willing to use care can do it.
I am NOT an electrical specialist: far the opposite, ccsailor thinks I am a dummie when he sees me working with electrics: however, by dint of experience, here's a couple things that may help, and a couple things that will, for certain:
1) I have seen several (actually, a disproportionately high number of) GL1100 motor cases, where the top starter mount bolt goes in, that are stripped out or badly cross-threaded.
It takes VERY little to cross thread into aluminum: I HIGHLY recommend for that reason(and for refitting the starter to the fargo-clutch chain sprocket)  that the pipe/header be dropped out of the way, to give you clean and clear access to the area, without threat of cross-threading bolts into the engine case. Those little 8mm bolts can be difficult to grasp in that confined space, and you do NOT want to start them with a socket wrench: you are just asking for trouble if you do.
There's no need to remove the pipe (although it is much easier working in that area if you do), just loosen the rear mount and the cross-over clamp, remove the header nuts, and it will drop down at the front enought to clear the area, and give you a straight shot at the bolts going back in. (bear in mind that you MAY need new header crush-ring gaskets to replace the header without leaks, but most often you won't unless they have been used 2-3 times previously, and are crushed completely. Hehe: I expect some raised eyebrows on that one:-) : properly, they should be replaced every time)
2) When installing the starter back in, with the pipe dropped out of the way, it's a LOT easier to get the starter lined up properly to the splines in the end-gear that is on the chain, with the pipe out of the way. (PS: I have installed many, many of these, and never had a problem lining up the starter-end splines with the gear, already installed in the chain. One reason may be that I NEVER remove the sprocket from the chain unless it is visually and obviously worn, which is rare in the extreme. The starter slides out, and the starter slides in.) I have also installed them sucessfully with pipe on, and wish I hadn't: it's a PITA, back to the risk of a cross-threaded starter mount-bolt, and more difficult to get the starter back in easily.
3) The armature end should be in-cut 1mm. "Under-power" starters are caused in large part by wear on the armature which diminishes this in-cut (as well as the brush-dust clogging the in-cut and other parts). I looked for that aspect in the write-up, and if I missed it : ooops, sorry. The armature end where the brushes contact has slots in it. It rotates under the brushes. It should be absolutely smooth, NO burs, NO lineal groves. The spaces between the little copper contacts are about the width of a hacksaw blade, an end of which I use to in-cut those grooves to the 1mm spec. You must be carefull not to bur the edge of the grooves, but that is, (if you looked carefully at the job with a magnifying glass) literally impossible to do: you will always get minute burs on the grove edges. Hence, be prepared to clean off the minor burs created, with some 900 grit then some 1200 grit sandpapers, and then use metal polish to polish the armature end as a finishing touch. (If you don't, and the armature is in any sense rough, be prepared to wear out your brushes very quickly, replace them often, and have a very dirty starter internally) Clean any metal fines and polish compound out of the area with air, spirits/alcohol, air again. If your brushes are under 7.5 to 8mm (50% approximate wear), you replace them, (although the replacement specs granted by the excellent article that this is appended to are correct at 4+mm). You may as well put new ones in while you are at it. You hopefully won't be doing this again for years: it's a worthy investment. If you noted that one of the brushes is worn substantially (more than .75 to1mm) more than the other brush: then it means that the brush spring is not matched to the other one, or the brush is not sliding properly in it's boxed retainer: clean out the retainer, & check the tension of the both springs if you have a tension-scale: you can even out the pressure by simply and cautiously tweaking them. It's not critical, but if both brushes are putting the same pressure on the armature, they will provide even contact. The measure of the fit is a similar wear pattern: all things being equal, and the brush-compound being for all intents and purposes identical on each brush.
4) ANY grease used on the moving parts should be a HIGH heat very good quality. (I use a silicon based high-heat high-quality brake grease successfully, whether rightly or wrongly, and it has worked just fine over the years.) You do not want grease getting heated and moving about inside the starter, and they do get very warm. I also individually grease both sides of any shims/spacers before installing them, and cue-tip a bit into the cap-end of the starter for the armature end bushing lubrication.
5) The number of spacers in the starter can vary, based on the amount of end-play in the armature, so don't get hung-up if yours is different. Keep the end-play (starter when assembled, pulling and pushing the armature in and out of the starter) to a minumum by using thin high-tensile washer-spacers with the right ID and OD. Do not get that tolerance too tight, there should be a small amount of play, but anything over (at a guess 10 to 15 /1000 or so, I go by feel, not gauges, on this) should be spaced out back to 5/1000 or so with additional spacers.
6) That was a good note by a couple of you on the underlying lock-nut on the starter power-strap lead. I screwed one up without thinking many years ago, and immediately took an old 10mm open-end wrench, and ground it down to about 3 to 3.5 mm thick to slide into that narrow space and act as a 'hold' on that nut while removing the power-strap to the starter. It's an essential tool when removing these starter straps (don't try using needle-nose pliers or vise-grips: the chance of slippage is far too great: sacrifice a $4 wrench for your $400 starter: the wrench will always be in your kit and is darned handy anyway). If that base-nut turns, the whole stud is turned. That stud is firmly affixed to the shoes inside the starter, and you WILL break that contact if that stud turns even a small amount. Kiss the starter goodbye.
6) It's a lot easier to KEEP the system good than to be rebuilding (worse yet, replacing)starters on an ongoing basis. There's some simple things that should be dealt with to maintain good continuity in that system.
a) The main ground-strap for this starting system is located under the rear top motor mount (triangular metal plate under the drivers thigh, left side, high up). That plate should REGULARLY (once per year) be removed, and the terminal end eye-let lightly sanded, then polished, then cleaned, and lightly greased with electrical contact grease. The motor-case at that contact point should be treated the same way, and then replaced and tightened down to proper torque specs. (Note: you should take a bit of weight off the motor from underneath while removing this mount-plate to ensure the motor does not tweak in the frame even a little bit while doing this: misaligning the motor and thereby the two 12mm short bolts, and having a heck of a time getting them back in without cross-threading them (yes, I've seen that as well). Take a little weight off with any jack that will fit under the engine.)
>>>Secondary note: there is a contact cleaner/lubricant out there that I found years ago to work on my computers, cleaning and lubing RAM, PCI cards, slots etc: that is the best thing I found for ALL electrical contacts (such as the plate/strap mentioned above and terminals: bloody excellent stuff. It's called NU-TROL, made by MG Chemicals (and no, I don't own shares). It cleans contacts, and adds a layer of corrosion-proofing preservative as well. I spray it into and on ALL contacts, terminals, switches: in short, everything that carries an electrical current via contact, whether switch contacts, terminal plugs, etc.
I may use a different cleaner which dissolves/gasses off totally to clean a particularly dirty contact area, but I will ALWAYS finish up the job with this Nu-Trol stuff for the anti-corrosion effect.
Do NOT use this or anything else that leaves a film on ignition points on GL1000's. Use the dry stuff there, or just plain alcohol.<<
b) Any terminals leading to the starter system should be cleaned regularly as above: positive and negative terminals on the starter relay,  the fuse-mount points, the power-strap on the starter itself.
Keeping good strong continuity to the starter system is more than half the battle, prevents over-draw, over-heating, excess brush and armature wear, and keeps your starter in good condition much longer.
(By the time a bike is 5 years old, terminals will start to corrode in the best of circumstances, unless in a totally clean and totally dry environment: which is practically impossible. Add 10 years. Then 15 years. 20 years. >>> If you buy an older bike, and do not clean and refresh every terminal, connection, clean out and lube switches, and otherwise refresh the electrical circuitry: you are quite nutty, my friend. You are just awaiting electrical breakdown, with a timeline as to when it is going to happen being framed on a negative and expensive exponential scale)
WEAR:
Those who have that starter button on for more than 3-4 second bursts when starting anything are overheating the starter. If your "Wing" isn't starting within that time span after three tries, then you have a fuel or ignition problem anyway. Check those systems out before continuing to abuse your poor starter.
Give it a minute between those bursts as well, so that your starter can be allowed to :cool:. Just another tip for starter longevity. Doesn't play havoc with your battery as much either.
DIGRESSION to another area of: Starting a non-auto-choke Goldwing: IE: not an 1800:
In many older "Wings", expecially the GL1100's, (regardless of so called cross-overs that are supposed to allow transfer/distribution of fuels in the plenum), I have noted that the compression on the carb with the accelerator pump (#3 on 1100's, as an example) that that cylinder is down about 3-4 PSI in compression, while the others are at par.
An reasonable (? one man's opinion) assumption is that this is a by-product of washing that 'can' down while starting the bike, or a severly rich running mixture on that one 'can'. I find the later reason to be unlikely, due solely to the regular occurance of the diminished compression on that one cyclinder.
HENCE:
Do NOT pump the accelerator (meaning don't twist the throttle on a couple times before or during starting): you are just feeding raw fuel to the cyclinder(s), washing it (them) down, starting dry, and wearing out your motor needlessly.
For those 'Wings" with a manual choke (which means pretty much anything that is not auto-choked such as fuel injected models): screw the throttle on slowly just a little, THEN quickly slide your choke on when the engine starts to turn over. That way you'll be feeding 'rich' to the engine when it needs it, will be burning the fuel as it enters the "firing area" (compression chambers), and will neither be flooding it, or over-enriching it which washes the oil film off the cylinder walls.
And lastly, for the jump-on-and-go rider: warm the thing up, let that rich-mix dryness on the cylinder walls get lubed by crack-case lubricant circulation before turning into "Mario" and zooming down the road. I would expect to get only about 50% of the proper life out of an engine that is not properly warmed up, even though it'll start and run smoothly even when it is 60psi (80psi, running smoothly, but is as gutless as a hung side of beef) under Honda's rebuild time (142psi, GL1000/GL1100).
Ride safe.
A man who finds a job he loves will never work again.
 Posted: Thu Nov 5th, 2009 12:30 am 69th Post
PMQuoteReply
Xtracho
Mileage: 66K
Status:
Offline
Mana:
My Gallery
back to top
Back from 28 days offshore. Starter works like a champ. Turns over like new when engine is hot where before it would drag or sometimes not turn over at all. Guess brute force is necessary sometimes.
Mark
 Posted: Sun Dec 27th, 2009 01:07 am 70th Post
PMQuoteReply
Chauncey
Goldwing: GL1100 Aspencade
Mileage: 25000 ...
Status:
Offline
Mana:
back to top
Another success story!  checked with your instructions ( actually I checked them twice)  then did the job in about an hour total.  Mine has few miles but still has age.  The instructions were clear and complete.  I was very dissappointed when I reinstalled it and found it would not turn over, but when the battery charger was hooked up I found out why.  My battery was dead too.   Thank you.
1967 Honda 305 Dream
1983 GL1100 Aspencade
1993 Yamaha PW80
 Posted: Sun Dec 27th, 2009 01:18 am 71st Post
PMQuoteReply
Chauncey
Mileage: 25000 ...
Status:
Offline
Mana:
back to top
I got to wondering why my battery was dead.  I remember it always has (since I have had it 2 months) showed very low voltage at idle.  The last thing I did was ride in a christams parade.  Yep all the lights were on, idling for about an hour and a half.  My alternator connector looked fine, clean and bright but I packed it with dielectric grease anyway like has been suggested on the forum somewhere.  I now have 14 volts at idle.  Guess thats why the battery kept running down too.  So now I got a fresh starter and a better charging system.
1993 Yamaha PW80
 Posted: Mon Jan 11th, 2010 07:26 am 72nd Post
PMQuoteReply
jimmyman1
Mileage:
Status:
Offline
Mana:
back to top
My Question is I have an 82 wing 1100. Repaced starter cluch last year about 1000 miles on new roller ball starter cluch. Now on especially cold day the starter spin,s but does not engage
Changed oil to 5-30 a littel better staerter spins 10 times to 1 time ingageing. Any one have this problem before. I do not want to tear the whole bike down again to replace the starter cluch. Thanks Jimmyman
 Posted: Tue Feb 2nd, 2010 07:40 pm 73rd Post
PMQuoteReply
munkiwrenchertoo
Mileage: 84,000 klicks/52,000 miles
Status:
Offline
Mana:
back to top
Thanks sir Magic for your very helpful info. It made life much easier in dealing with the starter. The only thing I did not do is get the reduction gear out of the housing. After removing the circlip I tapped the end of the shaft gently a few times but it would not budge, so being the coward I am I decided not to mess with it any more. Overall the starter was in very good condititon but needed a good cleaning. Because the outer bearing looked like new I just left the gear in and worked as much grease in behind the gear plate as I could
I did a bench test of the starter before reinstalling it and the installation went well and the engine even turned over after so I am guessing I did something right! Once again thanks for your help...Evan
 Posted: Tue Feb 2nd, 2010 09:53 pm 74th Post
PMQuoteReply
Mr Magic Fingers
Goldwing: GL1100 Aspencade, GL1500 Aspencade
Mileage: 1100 has 156327 km, 1500 has 210387 ...
Status:
Offline
Mana:
back to top
Hey munkiwrenchertoo ,
Thanks for the thanks!
That shaft is in there snug. You could have used force on it as long as you protected the spines from getting burrs on it. When I work on this stuff I whack it with a 2x4! hahaha
Works for me!
Tim.
**** Proud new father of a 91 1500 Aspencade ****
3) You aren't learning much when your lips are moving.
4) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
 Posted: Fri Feb 5th, 2010 04:38 pm 75th Post
PMQuoteReply
ARKnapp
Senior Guru
Goldwing: GL1100 Standard
Mileage: 002000 km ...
Status:
Offline
Mana:
back to top
Very interesting and full of knowledge from all, it's nice to see things written by self examining folks that help themselves and others.
To all:
Keep learning, keep trying keep riding
 Posted: Thu Sep 16th, 2010 03:41 am 76th Post
PMQuoteReply
chasjo
Mileage: 90,290
Status:
Offline
Mana:
back to top
thanks for the wonderful write up. took my '81 interstate starter out tonite and followed instructions, wow not difficult at all. everything is back together and it is a tremendous improvement. thanks again for the helpful tip/instuctions.
 Posted: Fri Jun 24th, 2011 06:30 pm 77th Post
PMQuoteReply
mwlnm156
Mileage:
Status:
Offline
Mana:
back to top
Awesome write-up! I just refreshed my '82 Asspy starter last night. It took about 2 hrs. I can't believe what a difference it has made so far. I thought I was in need of another new battery because it seamed dead. I tested the battery and connections and everything was fine. I sure am glad I did not need to buy a new starter also.
I did run into one issue. While trying to remove the end with the 2 little gears from the sealed bearing I had to use a rubber mallet to persuade it to release. I also had to persuade it back in. Other than that, I had no problems.
Thanks again.
Tomorrow, You're gonna have to live with the things you say
Tomorrow, You'll have to cross bridges that you burned today
Tomorrow, And everything you do, it's coming back for you
You'll never outrun what waits for you Tomorrow.
(Sixx:A.M.)
 Posted: Sat Aug 27th, 2011 10:46 pm 78th Post
PMQuoteReply
tedmass
Mileage: 71500 and counting ...
Status:
Offline
Mana:
back to top
Did it and worked the balls Thanks agaln:waving::congrats:
When we are in the wind,We are really Free as a bird.Keep flying.......Tedmass
Newest Wing 82 GL-1100 Interstate ....love it
1st Wing 79 Goldwing 9Years...... miss it.
Half a dozen other bikes over the years .prefer The Wing
 Posted: Wed Nov 2nd, 2011 06:46 pm 79th Post
PMQuoteReply
3500 GOLF
Mileage:
Status:
Offline
Mana:
back to top
Newbie to the forum. GREAT JOB MR MAGIC FINGERS. My dad just gave me his garage kept 1983 Interstate (60k) and I was having starter problems.  I was unable to restore the starter due to extensive commutator damage. I ordered a new starter on line . My starter had the battery post near the gear end, the new one had the post on the opposite end. I would have to remove the pipes to install it. I had to pay return shipping and was refunded for the starter, but lost my original shipping costs. PLEASE make sure this doesn't happen to you if you need to buy a new starter.
Attachment: Starters.bmp (Downloaded 49 times)
Thank You Dad for the Goldwing
 Posted: Wed Nov 2nd, 2011 07:06 pm 80th Post
PMQuoteReply
Mr Magic Fingers
Status:
Offline
Mana:
back to top
Hey 3500 Golf,
First off, WELCOME to hands down the best site around for Goldwings. You will learn so much here you will be tearing deeper into your bike in no time. Great bunch of guy and gals here with incredible amounts of knowledge to go with it.
Second, Thanks for the thanks. I think this is a well read article. It's nice to be appreciated. I am honored that you chose my thread to be your inaugural post.
Sorry to see that you had problems in the first place  and even more sorry that you got a wrong starter. i would have made sure that you got your money back as it was their fault that you were shipped the wrong starter.
That being said, there is a company named DB Electrical. They make a wide variety of starters for everything that moves. They are fantastic starters and are EXTREEMLY well built. I have installed a few of them in the last few years for people and all of them were very well built and of the highest quality.
Here is the link to the starter that you need if you haven't got yours replaced yet.
http://www.dbelectrical.com/p-6641-new-honda-gl-1100-gold-wing-starter-gl1100-80-81-82-83-goldwing-smu0069.aspx
Good luck.
Tim.
P.S.  -  Drop by the New Members Introduction Forum to say hi to the other members. There is always someone there to greet you and welcome you aboard!
 Current time is 10:35 am Page:  First Page Previous Page  1  2  3  4  5  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > 82 GL1100 Aspencade Starter Refresh Top of Page
