Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Single Carb Conversions for 4 Cylinder Goldwings
Single Carb Conversions for 4 Cylinder Goldwings  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  ...  44  45  46  47  48  49  50  51  52  53  54  ...  Next Page Last Page
Author Post
 Posted: Sun Mar 21st, 2010 06:32 pm 961st Post
PMQuoteReply
StrayDawg1
Goldwing: GL1000, GL1100 Standard
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
How do I put a pic on the thread...my camera takes a pic to big for it!
____________________
It's what you do that counts..not who you are! It's not what you ride....It's that you ride!
 Posted: Sun Mar 21st, 2010 06:40 pm 962nd Post
PMQuoteReply
WingForChrist
Goldwing: GL1000
Mileage: 700 miles with me - 42,000 previous owners ...
Status:
Offline
Mana:
back to top
sometimes the software that you view the pics with will allow you at  adjust the size of it.   You might open it up in MS paint and then save it.  I have done that to reduce the quality of the pic.  then could up load it.
77' GoldWing
76' GoldWing work in progress
75' Honda CB 360T -Just traded somethings with owner of a bike shop.
74' Honda CB360-Craiglist trade and total restoration project for winter time(now parts bike)
Previous:
86' Honda Rebel
07' Suzuki S40
 Posted: Sun Mar 21st, 2010 07:31 pm 963rd Post
PMQuoteReply
vrlpete
Goldwing: GL1100 Aspencade
Mileage:
Status:
Offline
Mana:
back to top
oops, mispost
 Posted: Sun Mar 21st, 2010 07:35 pm 964th Post
PMQuoteReply
vrlpete
Mileage:
Status:
Offline
Mana:
back to top
78AZWING wrote: vrlpete wrote: 78AZWING wrote: Maybe, maybe not.
The guys that build their own manifolds haven't said anything about that. Couldn't be any worse than any other manifold tha 'might' have a leak. Or one of those rubber pieces break down and leak on the original manifolds/
But then again, popping through the ol' Pearly Gates in a big ball of fire shouting "Man! What a rush!!" sounds like the way to go, doesn't it?
well, it wouldn't rate up there with death due to romping by 3 coeds, but beats the hell out of choking on popcorn in front of the tv
I'ld be willing to bet my way would never make '1001 ways to die'.
Your way on the other hand....:bow:
i like to think of it as the 'lottery win' way of checking out :cheesygrin:
 Posted: Thu Mar 25th, 2010 02:15 am 965th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
Next time I try building my own intake,I'll get help that is closer to home or learn to weld. I have to cut a piece out of the frame to clear the fuel line,but all in all things are looking like fire in the hold this weekend,probably rain again. My intake looks a little like the one badorderbob has,with few mods to it. wish me luck
 Posted: Thu Mar 25th, 2010 11:14 am 966th Post
PMQuoteReply
badorderbob
Goldwing: GL1100 Interstate
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
Hi Stdawg1,  do you have the CI manifold? I had to cut a small piece out of the frame to allow for the fuel lines on the right side bottom rail? This has been this way since last summer without any problem, I am in the process of filling the tubing and coating it with either paint or sealant to prevent rust. This procedure of cutting a small piece out of the frame still gives ample strenght, this has been done on other conversions. It's not what I wanted to do but was the only way to fit the 32/36 Weber/Holly carb, you can take the frame piece turn it backwards)Inside out) and wield it back in, not lossing any strenght if your worried about that,.....I'm still considering that!! Later,..Bob;):waving:
 Posted: Thu Mar 25th, 2010 04:44 pm 967th Post
PMQuoteReply
78AZWING
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
The CCProducts Water-jacketed intake must sit lower. I did not have to do anything to my frame to get it to fit.
 Posted: Thu Mar 25th, 2010 05:11 pm 968th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
It wasn't my chose either but I cut just a tad out mostly because I had to use about a 3/8 adaptor for the carb to fit. My friend Raymond had to do the same on his bike but had the Carb turned backwards but worked OK,.... I didn't like to do it either but,......:?it was the only way to make it fit!:lash: Jigg's 4 barrel conversion He cut the bottom rails completely out and road his bikes that way. I perfer a little more strength on the frame. I have to get back on the conversion after I redo my rear differential (used the wrong grease:sadguy:)!!  At least I did get to ride her for a little bit:cheesygrin:!! Later;):waving:Bob    Cap85 What's the progress with yours, you've been awful quite? Is the PVC working out or have you taken another route?
 Posted: Fri Mar 26th, 2010 08:34 pm 969th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
I need to cut a small piece of the right lower rail,I don't think it will change the strength either,the Wing frame is built like a tank. The Weber 32dfta has a idle cut-off solenoid and a EVAP solenoid,cut-off will be hooked up to hot Evap won't...When you put the right grease in the rearend put some LUCUS gear lube in to,get it at the local truckstop,WORKS GREAT!
 Posted: Sat Mar 27th, 2010 01:58 am 970th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
After 10 years of sitting under a tree in the Arizona desert,I fought bugs,snakes and weeds to get her. The 1980 GL1100 breaths again! The intake works and the Weber needs to be rejetted or I need to adjust it some more. After all that time sitting she smokes like hell,there only 22,495 showing on the speedo,it's the original.I may put electric fuel pump on,cause I don't think original is any good. So folks this old girl is alive!!! thanks to this website I didn't give up on her...Charlie G.
 Posted: Sat Mar 27th, 2010 02:07 am 971st Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
I assume you did the prelimanaries, changed timing belts, oil change,......etc;)! Glad another one is saved:applause:!!  Got pictures!! :waving:Bob
 Posted: Sat Mar 27th, 2010 02:14 am 972nd Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
I just wanted to get her on her feet again, I used the GL1100 to mock up the intake for my 1000,went what the hell and put a battery on it and hit the starter button. Man what a rush to hear she lite off, alot of smoke, but she runs!!!!!  I'll get pics as soon as I figure out how to put them on here.
 Posted: Sat Mar 27th, 2010 12:20 pm 973rd Post
PMQuoteReply
Yooperwing
Goldwing: GL1000
Mileage: 29000 ...
Status:
Offline
Mana:
back to top
Hey Folks,
Been lurking for a while here and just installed one of Ld's manifolds on my 78. Bike starts and runs great up to about 5000 rpm. 85mph in 5th gear. When the stock carbs were working right she would go over 100. My timing is correct,have dyna ignition.fuel is good with a new filter. I am wondering if a larger jet would help the high end perfomance. I do have a set of new coils and wires but have not installed yet.
Looking for some advice from you carb guru's.
Thank You,
Rob
 Posted: Sun Mar 28th, 2010 01:41 am 974th Post
PMQuoteReply
badorderbob
Mileage:
Status:
Offline
Mana:
My Gallery
back to top
These set-ups were tested by Randall W. and indicated on his GL 1000 he had to increase the timing because these conversions where tested/made using a Gl1100 with vacum advance. You might use this as a reference ,......   http://archive.gwrra.org/board/messages/16683/24793.html?995922056,...........             :waving: Bob
 Posted: Sun Mar 28th, 2010 01:43 am 975th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
Yooperwing, I'm in the beginning stage of my mods, made my intake and used a Weber 32DFTA..took it for a ride around the block with NO brakes,seat,lights,and fenders. OH what fun..kids thought it was neat.
 Posted: Sun Mar 28th, 2010 01:48 am 976th Post
PMQuoteReply
78AZWING
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
Ya outa do that with at least a rear brake. Stopping is a good thing you know.
 Posted: Sun Mar 28th, 2010 01:59 am 977th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
Had to see if I could make it go! now got to make it stop,have to rebuild all the brake systems...
Attachment: 24895_1310464679828_1176958550_30823045_4675475_n.jpg (Downloaded 265 times)
 Posted: Sun Mar 28th, 2010 02:02 am 978th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
Here's the intake I made with Weber 32DFTA
 Posted: Sun Mar 28th, 2010 02:05 am 979th Post
PMQuoteReply
StrayDawg1
Mileage: many!!!!!
Status:
Offline
Mana:
back to top
 Posted: Sun Mar 28th, 2010 02:14 am 980th Post
PMQuoteReply
78AZWING
Goldwing: GL1000
Mileage:
Status:
Offline
Mana:
back to top
make up some kinda pad for a seat, plumb the brakes and bleed them, run a wire to a light on the rear for brakes one to the rear for tailights, one to the front for low beam on the headlight. Remember what the hand signals are for turning and lane changing and go for it.
You really don't need anything else except working tach and speedo (maybe just a speedo) on a wing. The faux tank and side panels are just dress up. Go Ultra Naked!
 Current time is 11:43 am Page:  First Page Previous Page  ...  44  45  46  47  48  49  50  51  52  53  54  ...  Next Page Last Page
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Single Carb Conversions for 4 Cylinder Goldwings Top of Page
