homepage
Check your FREE keyrings and buttons order status HERE. Members who missed this can get details on the KEYRINGS THREAD in the General Discussion forum, and can claim their goodies using the REQUEST FORM
GL1500 Locked Trunk!
 Moderated by: wingnut, wexy, tanygaer, redbaron, Patch, mikef, MDKramer, AZgl1500
 New Topic   Reply   Printer Friendly
AuthorPost
Silverfox
Forum Diplomat
Goldwing: GL1800
Mileage: As much as time allows!!
Status:
Offline
Mana:
  back to top
 Posted: Sun Dec 2nd, 2007 04:09 pm21st Post
 PM  Quote  Reply
Just a thought,....if anyone else has to go to the drastic measure of the drilling, how about using a hole saw that allows for a rubber blanking plug to be used to seal the hole. Should find something suitable from your local plumbers merchants. :baffled::waving:
____________________
Pete
Calhoun Pictures.. Click to View..
Rick Anderson
Goldwing: GL1500 SE
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 21st, 2008 02:04 am22nd Post
 PM  Quote  Reply
THANK YOU THANK YOU THANK YOU, THE HANGER DEAL WORKS ON THE WING TRUNK. I JUST ABOUT GIVEN UP WHEN POP IT OPENED.BUY AROUND OF BEER FOR ALL. THANKS AGAIN
exavid
Top Poster
Goldwing: GL1000, GL1100 Aspencade, GL1500 Aspencade
Mileage: 126,000
Status:
Offline
Mana:
  back to top
 Posted: Mon Jul 21st, 2008 05:47 am23rd Post
 PM  Quote  Reply
Glad to hear the archives have helped once again!:clapper::clapper:
deerhunter214
Goldwing: GL1500 Interstate
Mileage: 162,400 ...
Status:
Offline
Mana:
  back to top
 Posted: Sun Jul 27th, 2008 07:21 am24th Post
 PM  Quote  Reply
I need that latch Bar for my 92 gl 1500 I both the hooks broke about a week or so apart. Now can not lock it. And kinda costly just for that bar New...
Terry Russell
Hardmoneyman
Goldwing: GL1500 SE
Mileage: 14600 as of 8/28/2008 ...
Status:
Offline
Mana:
  back to top
 Posted: Fri Aug 29th, 2008 08:24 am25th Post
 PM  Quote  Reply
This Forum saved my Bacon "AGAIN"
YOU PEOPLE ROCK
I found that after removing the lower trim if you lie on your back looking up and use a heavy wire vs a coat hanger along with a flashlight this was a simple task!
I used one of the wire stakes that came with my garage sale yardsign. it was heavy enough wire and i bent the last 3/4" just over 90 degrees. I slipped it in and turned it and caught the bar on the second try.
I edited Jason's photo and drew a gray line to show the approximate location of the bar you need to catch. the yellow indicates the wire I fashioned and about the angle I used. It also indicates where I slipped the hook up in from below. Just off to the side of the latches.
Thanks again
Attachment: catchwire.JPG (Downloaded 68 times)
Will those who say it cannot be done, please stop interrupting those of us who are doing it!
1991 GL1500 SE Anniversary Edition
KEN56
Goldwing: GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Tue Sep 2nd, 2008 04:05 am26th Post
 PM  Quote  Reply
Can anyone tell me how to unlock the side luggage lid on a 2007 1800 ?......
SpiderBob
Goldwing: GL1500 Aspencade
Mileage: 119,251... and counting
Status:
Offline
Mana:
  back to top
 Posted: Wed Sep 24th, 2008 06:09 pm27th Post
 PM  Quote  Reply
I closed my trunk a few weeks ago, and it would not open after that. I did take a trip down a really rough road. I had to cut a hole (5" dia hole saw) in the back behind the seat (bummer) reach inside and remove the latch screws to release the trunk. After inspecting the latch the bottom angled on the opener had broke off and the "L" piece on top to make the key work was under the cross bar not on top to let the key work. To repair I had to buy some ABS and ABS cement (two part) and cut a perfect insert piece and glued it back in. I just saw how the coat hanger works, but for a trike it would have been very difficult without chipping the paint on the fairing.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
midwing
Active Member
Goldwing: GL1500 SE
Mileage: 45000ish and counting ...
Status:
Offline
Mana:
  back to top
 Posted: Sun Oct 5th, 2008 09:40 pm28th Post
 PM  Quote  Reply
Not too proud of this but I did something similar when I was working on the rear lights.
I had the trunk latch all apart to gain access to screws and it closed and locked itself .
The hanger trick didnt work and I didnt know if the  hole in the passenger seat would work.So I just forced it and the piece thats attached to the trunk lid give in and I finally got it open. Wouldnt reccomend it but at least all I have to do is glue the piece back on.
Funny thing ..I found that the piece had been glued before so I guess the previous owner may have done the same thing
Eric
Previously owned
CBR250RR
Bandit 400
bandit 600
ST1100 Pan European
GL1500
tallmankginAl
Goldwing: GL1100 Interstate, GL1500, GL1800
Mileage:
Status:
Offline
Mana:
  back to top
 Posted: Sun Oct 26th, 2008 05:54 am29th Post
 PM  Quote  Reply
You guys are great for the less intellgent who like me can't figure out the smallest problems.  Thanks for the post it was a saver.
Ken
Flipflargin
Mileage: 69K
Status:
Offline
Mana:
  back to top
 Posted: Mon Nov 3rd, 2008 02:43 am30th Post
 PM  Quote  Reply
I have a 1995 Aspencade and accidently shut my side luggage compartment after I had unhooked  the latch cable (inside the side compartment). :shock:
I looked in my trunk and found a hole plug that revealed a push latch which unlocked my side luggage compartment.  See attachment for location.  Hopefully the 1800 has something similar?  :baffled:
Attachment: motorcycle.gif (Downloaded 11 times)
95 Aspencade
 Current time is 03:47 am
Page:  First Page Previous Page  1  2
WowUltra 1.15 Copyright © 2007-2008 by Jim Hale
Page processed in 0.5096 seconds (34% database + 66% PHP). 23 queries executed.
