CLICK HERE |
| Honda GL1500 Se Trike Build |
Rating:
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: ... 24 25 26 27 28 29 30 31 32 33 34 ... |
| Author | Post |
| Posted: Mon Mar 29th, 2010 01:41 pm | 561st Post |
Went ahead and mounted ( glued in ) the latch from the GL1800. Thought it would be easier now before I glass in the trunk section.
____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Mon Mar 29th, 2010 04:49 pm | 562nd Post |
Finally, got both inside fender glass without the cormat. Had to grind down the lip from the spice & used some resin putty to help fill in any low spots. Lay 1 layer of mat the clothe & finally last layer of mat. Rolled it all out to remove any bubbles. 2nd picture show the heavy clothe I used, think it's 12oz. Mat will add thickness & clothe helps to add strength. 2nd picture didn't show up Last edited on Mon Mar 29th, 2010 04:51 pm by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Mon Mar 29th, 2010 05:00 pm | 563rd Post |
i see what you mean about the latch , it's different fron the 1500 ones, , what did you use to fix it in place?
____________________ GL 1200 85 trike (sold) GL 1200 88 aspencade trike and trailer(sold) GL 1200 87 aspencade trike (sold) GL 1500k 89 trike build |
| Posted: Mon Mar 29th, 2010 10:43 pm | 564th Post |
Ok, got the body lined up & started to glass the trunk section on. This will at least hold it to remove & glass it all around. Will drill mounting holes before I remove the body. Will need to find a better Adhesive! I tried " PL Premium Polyurethane Construction Adhesive" at about $5.00 a tube. It didn't harden & when I turned the body over after 5 hours, the latch assy. fell off. Any idea's on what to use. Pictures are coming out hazy, don't know why. Can't change the ISO on it. Been dropped to much I guess. Put this in CorelDraw 15 & brighten it up a bit. Last edited on Mon Mar 29th, 2010 10:48 pm by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Tue Mar 30th, 2010 03:47 am | 565th Post |
can't you just glass the latch in?
____________________ just do it and ask questions later. if you never start you'll never finish. PGR # 190570 cc permit none at the present running. but looking gl 1988 1500 trike sold 2003 flhtuci sold gl 1986 1200 trike sold gl 1984 1200 trike sold first bike cb 160 honda to many to list in between |
| Posted: Tue Mar 30th, 2010 10:13 am | 566th Post |
Here are a few pictures of the body with tail lights seating on trike. I think the tail lights were the hardest part of this whole project. Still need to cut the mounts for the lights off the metal body section. Thinking I will just glass the metal into to body to hold the lights. Don't know if I should make a mold of the mounts in case someone may want a body with these lights in them. Found new tail lights on the web for about $150.00 pair. Tried to clean pictures up a little in Corel Photo Paint. Let me know what you think, Good or Bad, need feedback! Here one in which I sprayed some white gel coat digitally . Last edited on Tue Mar 30th, 2010 10:52 am by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Tue Mar 30th, 2010 02:46 pm | 567th Post |
Love it looks awesome you are great with that fiberglass!
| Posted: Tue Mar 30th, 2010 04:39 pm | 568th Post |
Instead of making a mold of the tail light holder, I carefully cut it out of the corner parts & cleaned it up. I will keep these safe in care I need them for another body.
| Posted: Tue Mar 30th, 2010 07:05 pm | 569th Post |
skoto1 wrote: can't you just glass the latch in?Thanks, Good idea, since they have angle brackets it would support side to side so it's doable. I'm not thinking so good with all of the fiber glassing been doing. Always need ideas. 100 heads are better then mine old one.
| Posted: Tue Mar 30th, 2010 09:44 pm | 570th Post |
OK now MY new 1500 is looking better...... Claude.....
____________________ THE NATION WHICH FORGETS ITS DEFENDERS WILL ITSELF BE FORGOTTEN 1982 GL-1100 Goldwing Interstate...Old Red 1982 GL-1100 Goldwing Interstate...Black Beauty 1994 GL-1500 Goldwing Aspencade...401K.... http://www.RudysBackyard.com |
| Posted: Tue Mar 30th, 2010 10:11 pm | 571st Post |
it's all that glass dust in your brain and lungs. Last edited on Tue Mar 30th, 2010 10:12 pm by skoto1 ____________________ just do it and ask questions later. if you never start you'll never finish. PGR # 190570 cc permit none at the present running. but looking gl 1988 1500 trike sold 2003 flhtuci sold gl 1986 1200 trike sold gl 1984 1200 trike sold first bike cb 160 honda to many to list in between |
| Posted: Wed Mar 31st, 2010 01:07 am | 572nd Post |
____________________ Spider Bob GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL "If a man does not keep pace with his companions, perhaps, it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away." Patriot Guard Rider |
| Posted: Wed Mar 31st, 2010 02:20 am | 573rd Post |
SpiderBob wrote:
I only see fiberglass, Resin , mat & white dust all over the whole garage. Getting tired tiring to clean up & them make more white power. HEY, maybe I can sell it. Got a couple of pounds laying around. Last edited on Wed Mar 31st, 2010 02:22 am by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Wed Mar 31st, 2010 02:57 pm | 574th Post |
Got the trunk area all glassed in. Will be making it larger over to the fender After I get the tail lights mounted.
| Posted: Wed Mar 31st, 2010 03:00 pm | 575th Post |
Started mounting the tail light bucket on one side. Used only 1 layer of mat & will let it cure. Then can remove the light assy. & add 2 more layers of glass. Watch this corner for more glassing work. Extend trunk area & add mud flips. Last edited on Wed Mar 31st, 2010 03:03 pm by skip20 ____________________ USMC, Vietnam Combat Vet. 69-70, GWRRA 78111 PGR 255645 1st Bike Honda Dream 150 Dream Bought in '68 1st GoldWing GL1100 1989 GL1500/6 (NEW)Still have runs GREAT 1993 Gl1500A Trike Build SOLD Now:1993 Gl1500SE Future Trike To many projects to finish |
| Posted: Wed Mar 31st, 2010 03:56 pm | 576th Post |
sorry my screen is flat cant see around corner Great job skip!!!!!
____________________ John3:16 The Road is long winding hilly flat hot cold sun stars AINT IT FUN!!!! 1st bike 125HD in 1969 250Honda Dream 750Honda 10 HD 89aspencade 1994 GL 1500 Trike Past ------------------- 91HD Maybe Trike project |
| Posted: Wed Mar 31st, 2010 04:22 pm | 577th Post |
looking good , ,i think thats a great idea, to extend the boot, (trunk , for you guys) as it will keep the rain water, from the wheels off the wiring to the lights,and it will add strenth, and boot space,
| Posted: Wed Mar 31st, 2010 09:46 pm | 578th Post |
Just for giggles and grins....How much more does your "new" design weight than the original?????...And right now total weight of yours....????....Remember I weight in at about 230 and the wife weights in at.... Claude.....
| Posted: Wed Mar 31st, 2010 10:04 pm | 579th Post |
redbaron wrote: Just for giggles and grins....How much more does your "new" design weight than the original?????...And right now total weight of yours....????....It is heavier then the original, but I can still pick it up by myself. There a lot more glass in it for strength & changes. Tail lights are in & mounted. Getting ready to do the trunk space. Just put it back on the trike to check for clearance. Once the trunk is done I get to make more white power grinding down the top of the fender. The on to the body work!
| Posted: Wed Mar 31st, 2010 11:58 pm | 580th Post |
Awesome! You'll be riding in no time. Great Job with all that Fiberglass.
____________________ Dave Ride Safe and Ride Often, Keep the Shiny Side up and Many Happy Miles and Smiles. "In God We Trust" All Others Must pay Cash!!! Current Goldwing 2010 Gl1800 Trike Other Rides 1985 Goldwing Aspencade Blue - Sold 2006 Harley Davidson Sportster - Sold 2006 Goldwing Navi - Sold 2007 Honda Rebel 250cc 2007 Honda 110cc 1985 1200cc Goldwing Aspencade Beige 1994 1500cc Goldwing Interstate Black 2010 1800cc Goldwing Trike Red |
| Current time is 11:57 am | Page: ... 24 25 26 27 28 29 30 31 32 33 34 ... |
| Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Honda GL1500 Se Trike Build | Top of Page |
