CLICK HERE |
Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Bringing back a 1983 Aspencade after sitting in shed. |
Rating:
| Moderators: redbaron, MDKramer, Flyone, AZgl1500 | Page: 1 2 3 4 5 6 7 8 9 10 11 ... |
| Author | Post |
| Posted: Mon May 24th, 2010 03:32 am | 101st Post |
Tom2 wrote: You can also just use a blaster gun like this: I took a different model of that type and made a blast cabinet for aluminum oxides. Amazing what we can do with an idea and junk LOL Take of the top tank part that holds media, install an aire fitting by somewhat force fit or get fancy and tap for it. Install short junk air hose section. Take old junk chest freezer and drill hole through the top lid or high on back to ran air hose section through then put air fitting in bottom of a large can like a coffee can. Cut large enough hole so you can see your gun and work part and cover with plexi glass on the back side of freezer prefferably on the inside and cover with clear plastic wrap. Cut holes for arms under plexy window, use about 6" PVC for arm holes and cut off pants legs for sleeves, wear rubber dishwashing gloves. Run airline through a hole in the side or somewhere to connect the gun. Cut a hole for a shop vac hose and make a little metal shield so the air is drawn in from top and bottom but not direct into hose. Fill the can full of media open freezer lid and drop in part, pop hands into gloves and blast away with shop vac running. Helps also to install a light so you can better see the work part. Worked very well! Maybe I will try that with the Soda also. I was aluminum oxide blasting steel parts with my setup, but I think it should work well for Soda also now that I see the idea for the soda blaster. With Oxides I could reuse them several times so I wanted a cabinet blaster to contain them, can you use soda more than once or is it use it and toss it?
____________________ Chromo I ride for FOOD 95 SE 1500, riding now, Purple (the fastest color) 88 1500 recovering from deer hit, Phantom Gray (Most expensive color ) 82 1100 riding sometimes, Red Also 80 1100 naked and 86 1200 Interstate, not running yet. |
| Posted: Mon May 24th, 2010 03:38 am | 102nd Post |
Well sorry for all the typos again. My eyes are bothering me and fingers not working well. I spel Batter then thot nermally. LOL
| Posted: Mon May 24th, 2010 05:07 am | 103rd Post |
It was use it and lose it.. It just drifted off in the air. I am guessing in a booth type setup you could get it to last longer. A small box only cost's .70 cents.... Hal
____________________ Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE'S AWAKE" http://www.prockfamily.com and http://www.coppersjeep.com |
| Posted: Mon May 24th, 2010 09:34 am | 104th Post |
Hows the bike coming? Looks like the soda did a really nice job on everything. I may give it a try on some larger parts. On small jobs like carbs a box is not so expensive but if I try to do large stuff like an engine or fork lowers etc.. it could take a bit. Did the Soda clean up the aluminum to a kinda polished look like in the pics?
| Posted: Tue May 25th, 2010 01:17 am | 105th Post |
Bike runs great.. I need to sync the carbs. The carbs looked just like you see em. the only difference is I polished up the tops of the carbs. the rest was from boiling them and compressed air and then soda blast and hot water. Hal It should be almost time to list her up on ebay after I do the forks and the timing belts. I dont like selling stuff that has the potential for injury or failure.. In different words. I dont sell junk. And I would feel horrible if someone gets hurt due to my lack of repairing and or ensuring it is safe. Hal
| Posted: Tue May 25th, 2010 02:58 am | 106th Post |
So did you end up replacing the head gasket or was it fine and just smoking do to cleaning and sea foam? Looking forward to watching the auction and seeing more pics even though I know I can't afford this one. Hmm, would you take may 82 1100I on trade LOL I am waiting on belts and forks seals now. I want to ride. Sometimes when we plan ahead it is the plan that causes problems. Never having done forks seals I figured I might mess one up so I ordered 2 sets just in case. Shipping is 2/3 the cost of a set anyway. So I figure if I mess one up I have saved time and money ordering extras. WRONG, Got e-mail today, one of my items is being cross shipped so my order may be delayed 1-4 days before shipped. All I ordered was the seals, they had 1 set in stock and now waiting on the second set LOL Well at least it don't cost me nothing extra on shipping. However I found my forks look like new, bushings, seals dust covers, etc. .. The leaking fork has pits that looks like maybe a pipe vise was used and padding not good on one spot. So I probably only needed 1 seal not even a set really. Oh well, lets hope my timing belts arrive on time anyway on Thursday. I am glad your getting yours done better than I am getting mine done so far.
| Posted: Tue May 25th, 2010 05:16 am | 107th Post |
Smoking is completely gone. Fires up and runs like a dream.. Waiting on Belts to come in from rockauto.com and then I will tackle the forks and the timing belts and put new plugs in her and flush coolant.. My brother is trying to convince me not to sell.. no luck on that.. I have too many as is.. Besides maybe I can find someone to trade me a nice Sidecar for it.... That would be COOL
| Posted: Tue May 25th, 2010 05:23 am | 108th Post |
This how I am gonna buy my next batch of baking soda..... Hal http://www.camdengrey.com/essential-oils/Raw-Materials-Salts-Sugars-Powders/baking-soda-bulk.html?attribute=weight&value=10_lbs
| Posted: Tue May 25th, 2010 07:49 pm | 109th Post |
Wow... I went to sync carbs today. Put gauges on after it was fired up. No adjustments needed. It is amazing.. It must have been synced before I got it.. But they are all perfectly balanced and synced I guess I must have down something right in a past lifetime. The idle is perfect and it throttles up like no ones business. Just need my belts to arrive. I borrowed a buddies tail pipe sniffer. It shows it in the green just a tad bit towards the lean side when all warmed up. saweeeeeeet Hal Last edited on Tue May 25th, 2010 07:50 pm by copper204 ____________________ Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE'S AWAKE" http://www.prockfamily.com and http://www.coppersjeep.com |
| Posted: Tue May 25th, 2010 08:02 pm | 110th Post |
TOILET BOWL CLEANER, HADN'T HEARD OF THAT ONE. I always used lime-a-way.
____________________ http://s925.photobucket.com/albums/ad92/aquaman51/?start=20 CUT IT TWICE AND ITS STILL TO SHORT!!! Previous rides:Royal Enfield 250, Hodoka 90, Yamaha 80,160,QT50, Norton 250, BSA 500, Kawasaki 450ltd, Susuki 125, Vespa, Hondas CT90/110, C70, Twinstar, cb400F, 3-CM400A's, CM400C, CB650C, 7-CB900c's. Not counting all the off brand and home built mini bikes and mopeds. |
| Posted: Tue May 25th, 2010 08:16 pm | 111th Post |
I am gonna try the rusteco next time.. it lloks interesting.. Hal Last edited on Tue May 25th, 2010 08:17 pm by copper204 ____________________ Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE'S AWAKE" http://www.prockfamily.com and http://www.coppersjeep.com |
| Posted: Tue May 25th, 2010 08:25 pm | 112th Post |
Thanks for the tips copper 204 i use to play with old flat head motors and used motoroil MMO and Diesel to flush em they smoked like frieght train for awhile even after flush and new oil but they cleared up
____________________ John3:16 The Road is long winding hilly flat hot cold sun stars AINT IT FUN!!!! 1st bike 125HD in 1969 250Honda Dream 750Honda 10 HD 89aspencade 1994 GL 1500 Trike Past ------------------- 91HD Maybe Trike project |
| Posted: Tue May 25th, 2010 10:30 pm | 113th Post |
I just rebuilt a willys F-head 134... such a unique engine.. Exhaust valves in block and intake valves in head... Yes they do smoke. I do not know what my brain was thinking.... Hal
| Posted: Wed May 26th, 2010 06:50 am | 114th Post |
Ok has anyone ever tried letting a wing suck up seafoam direct through the carb sync hole one carb at a time? I seen this done on a busa today was a major smoke fest....lol
| Posted: Wed May 26th, 2010 04:10 pm | 115th Post |
NO? no one tried this?
| Posted: Wed May 26th, 2010 05:34 pm | 116th Post |
OK, I am going back and reading the thread again. Just bought an 86 1200, hope I can get it running. I will blame you for my failures if I cannot get it running since you have been such an inspiration with this thread. LOL Just joking of course. And thanks for that link on the soda too. I use allot of that stuff for other things at times and will probably buy in bulk also if shipping is not too bad.
| Posted: Wed May 26th, 2010 06:59 pm | 117th Post |
I have broad shoulders BRING it....lol I am just having fun doing this for a change. the weather is rainy this week and kinda zapping my energy.. Also my replacement belts have not arrived yet.. As soon as this one is done it is on the selling block... Hal
| Posted: Thu May 27th, 2010 07:00 pm | 118th Post |
SO the saga continues. I am trying to get the title straightened out on this bike. The original owner is trying to help. DMV in California shows he is the owner. It also shows on NON-op since september 1993. But the title is lost and DMV are being jerks.. arghhhhh Oh well will get it figured out one way or another. Hal aka copper204
| Posted: Thu May 27th, 2010 11:12 pm | 119th Post |
Awesome is all I can say.
____________________ Women will never be equal to men until they can walk down the street with a bald head and a beer gut, and still think they are sexy. |
| Posted: Fri May 28th, 2010 01:15 am | 120th Post |
WELL bad news sorta... The right head does have a blown head gasket.. It is smoking and smelling strong of anti-freeze.. so off the head will come this weekend for a new head gasket and valve stem seals... oh well.. lol I like working on em so no biggee.. I guess I should take photos eh?
| Current time is 12:33 am | Page: 1 2 3 4 5 6 7 8 9 10 11 ... |
| Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Bringing back a 1983 Aspencade after sitting in shed. | Top of Page |
