Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Ok I guess I will be chronicling my sidecar build and install.
Ok I guess I will be chronicling my sidecar build and install.  Rating:  Rating
 Moderators: redbaron, MDKramer, Flyone, AZgl1500 Page:  First Page Previous Page  1  2
Author Post
 Posted: Tue Jul 20th, 2010 09:28 pm 21st Post
PMQuoteReply
avidrider
Goldwing: None at present
Mileage:
Status:
Offline
Mana:
back to top
Is the Valkyrie sidecar a Cozy?
____________________
Life is like the ramp to the chicken coop, short and covered in **** [URL="http://avidrider.blogspot.com/"]http://avidrider.blogspot.com/[/URL]
 Posted: Tue Jul 20th, 2010 09:54 pm 22nd Post
PMQuoteReply
SidecarMike
Goldwing: GL1200 Aspencade, GL1500 Aspencade
Mileage: 49,000
Status:
Offline
Mana:
My Gallery
back to top
No, it was a Dnepr.
A Cozy is even lighter weight than the little Spirit.
Here are a couple Cozys mounted to vehicles that suit them.
A friend had one like this mounted to a 2004 Silverwing, but it was really too light weight for that.  It was very hard to keep it on the ground.
SidecarMike
A motorcycle is like a cast iron skillet, it mellows with age, wash it and you destroy years of seasoning!
"The Mistress" 1996 Aspencade & Friendship 3 Sidecar
1984 NightHawk 650, 1985 Aspencade
 Posted: Thu Aug 19th, 2010 04:09 am 23rd Post
PMQuoteReply
goldwingsc
Goldwing: GL1500 Aspencade
Mileage: 70k
Status:
Offline
Mana:
back to top
Howdy all. excellent forum here glad to see all the info. I have a motorvation formula II hack on mine. look forward to checking out all the posts.
 Posted: Fri Aug 20th, 2010 01:37 am 24th Post
PMQuoteReply
BigWingD
Goldwing: GL1000
Mileage: over 91,000
Status:
Offline
Mana:
back to top
@goldwingsc
Welcome to the site from WV
If you cant get there on two wheels I just wont go
 Posted: Sun Oct 10th, 2010 05:14 am 25th Post
PMQuoteReply
Lightin
Mileage:
Status:
Online
Mana:
back to top
SidecarMike wrote: No, it was a Dnepr.
very nice side hacks and how much for a gallon of petrol 3 cents :smiler:
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
 Posted: Mon Apr 4th, 2011 03:03 pm 26th Post
PMQuoteReply
3rdWHEELWINGER
Goldwing: GL1000, GL1100 Standard, GL1200 Aspencade, GL1200 LTD, GL1200 SEi, GL1500 Aspencade
Mileage: 150,000 + ...
Status:
Offline
Mana:
back to top
I just finished remaking the lower mounts on an '80s vintage calif. car that used the Bell style lower mounts. Instead of pitching the original mounts and spending the big bucks for the updated style with heim joints, I took the bell fixtures to a machinist friend and had him machine two pieces of round stock to fit tightly inside the bell, and bore and thread them the same fine thread size as the new heim joints that i purchased at my local WW Grainger store for approx $30 each(they're the same industrial strength joints). I then welded those pieces inside the bell fixtures and ground the welds smooth, and you can't tell the difference. He also took some regular hardened nut and put them on the lathe and narrowed the up to use as lock nuts. Remaking the bike mounts was a whole other project, but the bell fixture mod. saved me some serious money.
I also have a 93 Aspencade with a Champion car with the current style bike mounts, so I had a newer system to give me some ideas and some approx. measurements.
For the lower front, I used 1" heavy wall square tube that I ran directly under the oil filter and ran flat stock back to the lower engine mounts on each side of the engine. I cut the tube long enough that it came out the right side to a point under the valve cover, but not to the point that it was noticeable if I had the car off. Then I ran two support straps up to the engine guard fasten points and gusset as needed. On the outer end of the square tube on the right side, I welded a piece of round stock with a hole bored in it to accept the bolt that goes through the heim joint. I notched the square tube and angled up the outer most few inchs to kind of follow the angle of the lower tube of the engine crash guard. That got that lower joint position off the ground a little. It turned out nice, but there is not an easy way to hide that bracket like I could on my 93. I wish had taken pictures, but I didn't and I just sold the bike.
76 GL1000/ 48,000 miles-Yellow
80 GL1100S/10,000 miles-
84 GL1200A/64,000 miles-in refurb mode
84 GL1200A and 85 GL1200L- both supplying refurb projects
86 GL1200SEI/with Calif. sidecar/ 76,000 miles
93 GL1500A w/Champion Escort sidecar/20,000 miles
 Posted: Sun Jun 5th, 2011 03:30 pm 27th Post
PMQuoteReply
KC9KAS
Goldwing: GL1500 Aspencade, GL1500 SE
Mileage:
Status:
Online
Mana:
back to top
The Vetter TerraPlane had a top link that was a turn buckle that could be adjusted while riding to adjust the bike to hack angle on various pitched road surfaces so the the bike would set straight regardless of the crown in the road. I always thought that was a really good idea.
I had a JAWA hack on a 1978 GL1000. bought it so we could take the "baby" with us. We went on a 6000 mile round trip to California in 1982 with a 22 month toddler. Many stories from that trip!
 Posted: Fri Aug 26th, 2011 11:47 am 28th Post
PMQuoteReply
siouxindian
Goldwing: GL1000, GL1200 Aspencade, GL1500
Mileage: 84 1200/96000. gl 1000 58000 . 91/gl1500/73000
Status:
Offline
Mana:
back to top
how is this sidecar build coming. im done with mine it took me 1 week a couple of         16 hr days but it came out OK. it was my first time :ssshh: . to build a frame .
life is good.
 Current time is 12:38 am Page:  First Page Previous Page  1  2
 Steve Saunders Goldwing Forums > Forums > Reference and FAQ Forum > Ok I guess I will be chronicling my sidecar build and install. Top of Page
