GL1100 Front Fork Overhaul - Page 3 - Steve Saunders Goldwing Forums
post #21 of 39 (permalink) Old 08-31-2008, 01:33 AM
unsteadyrider's Avatar
Year: 1982
Model: GL1100I
I did mine with forks and fairing on bike. I took the spring caps off and couldn't get them back on so I made a tool.
I used 2in PVC slip to thread adapter, 2in cap, a plastic tubeI found in my garage that just fit around the cap and Epoxy puty.I knotched the tube for the valve. Using Wax Paper over the cap formed the Epoxy to the cap before it dried in the tool.
It gave me the control needed to push down and start the threads.
Didn't want to post that many times here so I uploaded to MY GALLERY
unsteadyrider is offline
post #22 of 39 (permalink) Old 08-31-2008, 07:57 AM
teacher's Avatar
Year: 1983
jskoblar wrote:
This strand has come a long way. So...
I tried the Lucas power steering treatment to the leaky (oil and air) forks of my '81 gl1100. Nuthin doin. Guess I gotta do it right, $30 per side for OEM seals from the only Chicago (Skokie) dealer to stock them.
But, did you soaking them overnight in the Lucas?
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
post #23 of 39 (permalink) Old 09-02-2008, 09:59 AM
jskoblar's Avatar
Hadn't, but I will this weekend, thanks.
81 GL1100 Standard
79 Yamaha XS750 Special
75 Honda CB550
jskoblar is offline
post #24 of 39 (permalink) Old 09-08-2008, 05:56 PM
tomw's Avatar
I'm having a devil of a time getting the circlips out.I can pinch them enough for them to come out of their recess but it seems like the circlip pliers do not have a strong enough grip on the clip for me to pull the clip out.
Any ideas?
Relax,we all have a little Gomer Pyle in us.
Two things extinct in America in the 21st Century,customer service and management.
tomw is offline
post #25 of 39 (permalink) Old 09-08-2008, 06:59 PM
teacher's Avatar
Year: 1983
Any ideas?
I've use the circlip pliers along with a flat bladed screwdriver. Using the pliers to get it pulled away from the wall then I put a thin bladed screwdriver behind it and wedge it out. Of course it ain't right but it does the job with no damage. Just be careful and go slow. Works for me.........................
~Butch~~~
teacher is offline
post #26 of 39 (permalink) Old 09-08-2008, 08:54 PM
tomw's Avatar
No bent circlip?
tomw is offline
post #27 of 39 (permalink) Old 09-08-2008, 09:33 PM
teacher's Avatar
Year: 1983
tomw wrote:
No bent circlip?
Nope! Not yet................guess I've been lucky.
~Butch~~~
teacher is offline
post #28 of 39 (permalink) Old 09-08-2008, 09:38 PM
Slipping a small screw driver behind the circlip as the snap ring plier pulls it inward is a pretty common way to get the clips out. You can use two screw drivers, small ones with thin 3/16" or smaller blade widths, squeeze the circlip, get the screw driver behind it to wedge it out, and work it toward the middle of the clip by inserting the other screw driver and twisting the blade to pry more of the clip out. Once you have about half the clip out of its groove you can start using the screw driver to pry the loose end upward as you work it out. If you bend the clip a bit it won't hurt, it's easy to straighten them out if you give them a bit of a wow.
post #29 of 39 (permalink) Old 09-09-2008, 05:32 PM
thank you for the help on the front fork seals.
i'm new on this site, found it via google and haven't been able to find a list of the FAQ's.
is there a blow by blow description of how to disassemble the front forks and then tell what parts need to be replaced?
i found these to be most helpful, wondering if i missed something important.
http://www.dansmc.com/81goldwing_fork.JPG
http://www.dansmc.com/forks.htm
working on both an '80 1100 and '81 1200
of course they both leak, seals dont seem to last long in the arizona desert heat.
tia.
rmwilliamsll is offline
post #30 of 39 (permalink) Old 09-10-2008, 08:39 AM
Year: 1982
Model: GL1100I
tia.
Welcome to the greatest Goldwing Forum
Try this link.
https://www.goldwingfacts.com/forums/...=fork+overhaul
In the search box at top left of home page for the forum type fork overhaul or such term.
GL1500 Front Fork Overhaul Ron Wylie Goldwing Technical Forum 5 08-22-2011 09:35 AM
1500 Front Fork overhaul nlawless Goldwing Technical Forum 4 08-30-2010 10:45 PM
GL1500 Front Fork Overhaul Ron Wylie Goldwing Technical Forum 2 02-14-2008 05:20 PM
GL1500 Front Fork Overhaul Ron Wylie Goldwing Technical Forum 1 08-07-2006 04:16 PM
Fork Overhaul - What Parts are Required - ? Ron Wylie Goldwing Technical Forum 4 07-22-2006 02:58 AM
