GL1100 Front Fork Overhaul - Page 4 - Steve Saunders Goldwing Forums
post #31 of 39 (permalink) Old 02-10-2009, 10:15 PM
most of the articles i have read are for 1100 or 1500 goldwings.
is there anyone who has pics or details for the 1200.or are they the same.
just trying to work myself into doing this job i guess.i debate too much i think
dsmith is offline
post #32 of 39 (permalink) Old 02-10-2009, 10:22 PM
Not all that much difference in the models. Before you work up the grit to tackle the job read up on the subject. Clymer has a good manual for the 1200 you can find it on Amazon or other books sources. One error in the Clymer book is they show the fork seal upside down, in all 'Wings the seal goes in with the openside facing the ground and the side with writing upward.
Go for it, it's not difficult and doesn't have the potential for disaster as incorrectly changing a timing belt. It's a good confidence builder.
post #33 of 39 (permalink) Old 02-11-2009, 10:43 AM
klwatts's Avatar
jbhigg wrote:
You might try looking at http://www.chuck.kichline.com then go to his goldwing pages.He has some good pictures and some hints on fork seal replacement.I also have a honda service manual for my 82 1100 and a clymer .I use the clymer in the garage and leave the honda manual in the house do it doesn"t get nasty.Got both manuals on e-bay
I think this link will work:
http://www.kichline.com/chuck/default.htm
Kevin
85 GL1200-I
USMC, (Retired)
klwatts is offline
post #34 of 39 (permalink) Old 03-11-2009, 02:01 PM
Great post, thanks for the info
firetalker is offline
post #35 of 39 (permalink) Old 05-30-2010, 06:45 PM
This is great stuff.
What normally causes one forkn leg oil rto become very dirty and dicoloured?
belly is offline
post #36 of 39 (permalink) Old 10-03-2011, 05:55 PM
randallcrawf's Avatar
I have also done it, with leaving the upper tubes in the tripple trees was very easy to do that way.
1981 gl110
randallcrawf is offline
post #37 of 39 (permalink) Old 10-03-2011, 07:06 PM
Wear can do it, fine material from the fork bushings, rubber particles from the seal, and dirt and moisture that gets past the seal all can contribute to that black gummy stuff.
post #38 of 39 (permalink) Old 10-03-2011, 09:53 PM
Can anyone tell me what these "fork gaiters" are? And where I would obtain them from? Have some fork seals leaking on my 1200, so I'm going to have to go into them at some point. And the inner cylinders are a bit rough....so I may need to do something to protect the seals....
Robert L. Gray Jr. NREMT-P
**** happens, and I am a happenin\' kind of guy!
domscorpiorlg is offline
post #39 of 39 (permalink) Old 10-03-2011, 11:50 PM
scotthohio's Avatar
Keep them clean and you shouldn't have a problem.
Scott
Traveling fork rebuilding and motorcycle delivery available.
Fork seal tutorial
86 GL1200 Aspencade
scotthohio is offline
GL1500 Front Fork Overhaul Ron Wylie Goldwing Technical Forum 5 08-22-2011 09:35 AM
1500 Front Fork overhaul nlawless Goldwing Technical Forum 4 08-30-2010 10:45 PM
GL1500 Front Fork Overhaul Ron Wylie Goldwing Technical Forum 2 02-14-2008 05:20 PM
GL1500 Front Fork Overhaul Ron Wylie Goldwing Technical Forum 1 08-07-2006 04:16 PM
Fork Overhaul - What Parts are Required - ? Ron Wylie Goldwing Technical Forum 4 07-22-2006 02:58 AM
