2002 GL1800 Remote programming - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 06-03-2008, 07:05 PM Thread Starter
TJ
TJ's Avatar
I just received a brand new remote for my GL 1800. Is it possible to program from my old remote to the new one ? I couldn't find any information in the service manual and the ops manual said to take it to your dealer to have it programmed. Sure could use some help with this one !
Thanks,
TJ
TJ is offline
post #2 of 4 (permalink) Old 06-03-2008, 08:20 PM
This should work:
1. Turn the ignition switch on - between one and four seconds and press the trunk "Pop-Up" button on the transmitter while aiming the transmitter at the trunk. Between one and four seconds, turn the ignition switch off. Note: keep the timing between one and four seconds, too fast or too slow will cause the control unit to lose the stored codes.
2. Between one and four seconds, turn the ignition switch on. Between one and four seconds, press the trunk " Pop-Up " button on the transmitter while aiming the transmitter at the trunk. Between one and four seconds, turn the ignition switch off.
3. Between one and four seconds, turn the ignition switch on. Between one and four seconds, press the trunk " Pop-Up " button on the transmitter while aiming the transmitter at the trunk. Between one and four seconds, turn the ignition switch off.
4. Between one and four seconds, turn the ignition switch on. Between one and four seconds, press the trunk " Pop-Up " button on the transmitter while aiming the transmitter at the trunk. Leave the ignition switch on.
5. Within 15 seconds, aim the transmitter (up to three) whose codes you want to store at the trunk and press the " Pop-Up " button once on each transmitter.
6. Between one and four seconds, turn the ignition switch off.
7. Confirm proper operation with the new code(s).
Kit
Kit Carson is offline
post #3 of 4 (permalink) Old 06-04-2008, 03:19 AM
wexy's Avatar
Year: 2003
Good info I will move this to the FAQ forum,,Thanks ,Ciaran
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
post #4 of 4 (permalink) Old 09-12-2011, 07:41 PM
Send a message via MSN to JEFF1 H
thanks i will try it
JEFF1 H is offline
remote for an GL1800 Ghost_Rider Goldwing Technical Forum 1 01-27-2012 06:24 PM
Keyless Remote Programming MikeR22 Goldwing Technical Forum 14 08-15-2008 03:54 PM
GL1800 Remote catmirass Goldwing Technical Forum 2 07-29-2007 07:07 PM
Modell 2006:CUSTOM PROGRAMMING THE GL1800'S OPENING CEREMONY Laureon Goldwing Technical Forum 10 03-14-2006 08:18 PM
Programming the welcolme on GL1800 novawing Goldwing Technical Forum 5 04-22-2005 10:09 AM
