NOT your normal SEAFOAM thread - Page 3 - Steve Saunders Goldwing Forums
post #21 of 36 (permalink) Old 11-10-2008, 05:30 AM
Nightrider1's Avatar
Send a message via MSN to Nightrider1 Send a message via Yahoo to Nightrider1
AZ,
Would seafoam help clean the carbon off of the Neutral Swich in the front of a 1980 GL1100? I read where it said you could safely add 1 and 1/2 ounces to each quart, which would be 6 ounces. My neutral has started staying on all the time, and Brighter in netural. It come on once before this, but after I put in the Chevron Delo 15w40, after about 12-1500 miles, It started coming and staying on. I have anotherswitch in my parts bile which I was thinking about removing, cleaning, and putting it onmy Goldwing, figuring the best would be better. What are your thoughts? What about after draining the oil, and cleaning the netural switch by directly spraying it on the netural switch? (One of my old bossed once told me i would stay on a job for an hour to try to make it 15%more efficent) lol
Thanks,
Nightrider1
AZgl1500 wrote:
William_86 wrote:
I wonder if it would be safe to use seafoam on a wet clutch crankcase anyone used it?
William,
See the thread about Sea Foam 100% Satisfied in the General Section.
https://www.goldwingfacts.com/forums/forum4/35914.html
It is quite safe for clutches. It stopped mine from slipping.
You meet the best people who ride a Goldwing
Nightrider1 is offline
post #22 of 36 (permalink) Old 11-10-2008, 06:19 AM
David,
I don't know but it might. The stuff does have some good cleaning properties to it. Why not give it a try and see.
Maybe when you are planning a day ride and then change the oil after a few hundred miles?
I left it in my bike for quite a while if I recall right. A week or maybe more, didn't document it. That would have 40 miles/day at a minimum to work and back.
It stopped the clutch from slipping on mine.
NASR 12
Forum link=>
https://bit.ly/2RsUJos
post #23 of 36 (permalink) Old 11-10-2008, 07:27 AM
John,
I think I will try it. 6 oz in the oil, and 1/2 in the rest of a full tank, run the tank out, then change the oil. It will have to get warmer though. I have not had too much luck with cold weather, (And Mike, and I don't want to push it, Promise!)
Thanks Bro!
David
AZgl1500 wrote:
David,
post #24 of 36 (permalink) Old 11-14-2008, 04:00 PM Thread Starter
wrongway's Avatar
Just of interest (to me anyway), my car was running pretty rough and I wasn't sure if it was bad gas or bad spark plugs.
Anyway, I still had the can of seafoam that I won in the NASSIR1 aution so I poured the whole thing in and filled the car with gas.
Within 40 miles the car is purring like a kitten again.
Whatever the reason for the rough running, seafoam once again has worked.
SteveSS likes this.
Greg (wrongway) and Bonnie
Currently looking to buy a GL1800 Spring 2018. Looking for 2001-2012 depending on condition, miles etc.
wrongway is offline
post #25 of 36 (permalink) Old 11-14-2008, 05:05 PM
Feetup's Avatar
Model: '84 1200 Int.
Send a message via AIM to Feetup
The MSDS sheet on seafoam states that it is:
40-60% pale oil ( a thin mineral oil)
25-35% naphtha (camp stove fuel but a good solvent)
10-20% I P A ( or Isopropyl Alcohol , common rubbing alcohol)
All fairly benign substances,but only the Isopropyl alcohol would be alien to fuel. Gasoline and naphtha are very similar in chemistry, in fact naphtha is often referred to as white gas. The pale oil is most likely a carrier andwould be unlikely to contribute to cleaning fuel systems but could add a bit of upper cylinder lubrication. The I P A is most likely the most effective cleaner, since it will dissolve a variety of water born and petroleum compounds, much like acetone, but less harsh on fuel system components.
I'm not trying to discredit Sea Foam, merely understand the science verses the snake oil.
There are two kinds of fools: one says,"This is old, therefore it is good"; the other says,"This is new, therefore it is better."¯ William Ralf Inge
Tim Johnson
\'84 GL1200I
\'75 GL1000
\'02 GASGAS Trials
\'56 Norton Dominator 600
Feetup is offline
post #26 of 36 (permalink) Old 11-14-2008, 07:45 PM
johnnynogood's Avatar
I had my '82 Wing on a lift and I was under it when I accidentally knocked over a can of Sea Foam with about 6 ounces left in it, and it fell in my mouth. I got most of it out but inevitably some went down the gullet. 2 hours later my member was so hard, a cat could'nt scratch it. I threw away the rest of my Viagra.
If you get scared half to death twice, would you be dead?
johnnynogood is offline
post #27 of 36 (permalink) Old 11-14-2008, 07:54 PM
Monkey with a Football
Rudy's Avatar
You're not supposed to be showing that thing to the cat.
Would look kind of funny when people come walking in unexpectedly.
Rudy
wasn't too much fun”
Rudy is offline
post #28 of 36 (permalink) Old 11-14-2008, 07:54 PM
mikef's Avatar
Model: Aspencade
Where did you say you got that can from?
Finally, old enough to know better. Just need some common sense now......
Patriot Guard Rider
1986 GL1200 Aspencade
1993 GL1500 Aspencade
1985 GL1200 Aspencade
1985 Suzuki Madura 700
1973 Honda 350CB
1965 Honda 50
mikef is offline
post #29 of 36 (permalink) Old 11-14-2008, 07:57 PM
I needed a witness, he was available and willing.
post #30 of 36 (permalink) Old 11-14-2008, 08:07 PM
Rudy's Avatar
I wondered what had happened to the cat.
Rudy
Rudy is offline
Is this normal ? redz90 Goldwing Technical Forum 8 01-23-2011 06:15 PM
is this normal? redrider69 Goldwing Technical Forum 6 11-19-2010 10:50 PM
SEAFOAM: what is the cheapest source for buying qty of seafoam? TwoBigCats Miscellaneous Forum 8 08-03-2010 07:08 PM
Is this normal? Evil twin Goldwing Technical Forum 16 07-18-2009 07:17 PM
are you normal?? pinkpork Fun Forum 30 06-29-2006 07:42 PM
