Koxx4, Keys & Locks Guru - Page 3 - Steve Saunders Goldwing Forums
post #21 of 34 (permalink) Old 03-10-2009, 03:53 PM
Lock and Key Guru
koxx4's Avatar
GSMacLean wrote:
I don't know if this is the correct way to fix a jammed/gummy lock as recommended by a master locksmith, but...
I have twice rescued a lock on my 1100. One was the tank lock, which got extremely stiff, and one was a helmet lock, which would unlock, but would then refuse to give up the key until you spent a minute or two wiggling it.
In both cases, I first shoved the plastic tube from a can of brake cleaner into the lock, and hosed it down, cleaning all the gunk and grime out of the lock.
Next, I did the same with a can of graphite lubricant. This is black stuff that comes in a spray can, but the carrier is extremely volatile and evaporates within seconds, leaving behind a thin coating of dry graphite, which is very slippery. You have to be careful with this stuff, because it is BLACK, and if you get it anywhere you don't want it to go, that place will be BLACK as well.
In both cases, it made the locks function as good as new.
Using the brake cleaner could be a problem as some of the locks have plastic parts in them and this could melt or weaken them.
However the graphite is a first class lubricant and has been used for yearsto ease stiff locks. It is only in the last few years that other products have been used. Most lock manufacturersnow recommend WD40 (this is cleaner to use) We use GT85 which has Teflon in it, (very slippery).
The stiffness in the locks is caused by dirt and water corrosion, so as part of normal maintenance I would recommend a quick shot of WD40 to each lock this will prevent ware and keep them running smoothly.
Ian
Master Locksmith
Most motorcycle problems are caused by the nut on the saddle.
GL1800
Triumph 3TA Trials, BSA B40, Yamaha TYZ 250Trials x2, Bultaco Sherpa x2
koxx4 is offline
post #22 of 34 (permalink) Old 03-10-2009, 07:29 PM
derekhendry's Avatar
Congratulations on your promotion Koxx4, now Ian if you can tell me the secret of why i keep losing my keys all the time please
Derek and Maggie
GL1800 2004 US spec White.
derekhendry is offline
post #23 of 34 (permalink) Old 03-11-2009, 03:45 AM Thread Starter
Silverfox's Avatar
for that you need a brain cells guru Derek.
Good to see questions and answers re locks and keys like the one from GS, and Koxx4, it helps us all learn some do's and don'ts on subjects like this.
Pete
'06 GL1800
'86 GL1200SEi
Silverfox is offline
post #24 of 34 (permalink) Old 05-21-2009, 06:08 PM
Rider15's Avatar
Send a message via Yahoo to Rider15
Check with your local lock shop. They have a spray lube specially designed to lube and clean the locks. Also a reputable locksmith can most likely make key and repair a stuck lock as long as you do not drill it out. I made that mistake once and my locksmith never lets me forget it.
Only bike I really wanted to ever own is GOLD.
There are only two types of Goldwings
Rolled Gold - Pretzels
Old Gold - Polish
Patriot Guard Rider - Let\'s Show Them The Respect They Deserve.
Rider15 is offline
post #25 of 34 (permalink) Old 05-24-2009, 09:24 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
but is the stock lock able to be rekeyed to fit the others?
pm sent
neoracer is offline
post #26 of 34 (permalink) Old 03-02-2011, 01:33 AM
hummer5205's Avatar
Year: 2008
Model: 2008 Gl 1800 P premium Audio
I use some stuff I used to use on my mtorcycle chain (kaw kz400ltdH1) Its called tryflow not sure if its the same stuff But Ive used it in my ignition switch & did this lastmay 2009 & it has always worked like a charm!
All good things come to He who waitith if he workith like hell while he waitith !
hummer5205 is offline
post #27 of 34 (permalink) Old 03-02-2011, 09:39 AM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
EDDIE W wrote:
looks like i wont be running around on an 1800 for the foresable future then
Just remember they shoot Horse thieves......Iron Horse that is
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #28 of 34 (permalink) Old 03-02-2011, 12:35 PM
Lock and Key Guru
koxx4's Avatar
Be warned, motorcycle chain lube is designed to be sticky to remain on the chain when its in motion.
The very fine springs in all pin, slide and lever operated locks will not over come this stickiness you will effectively glue the tumblers in place! The first time you put your key in it will set the position of the tumblers and the lock will work and may go on working for sometime, however should you ever insert a wrong key by mistake it will reset the tumblers to the new key shape and they will not return to a neutral position, so when you put the right key in it will be jammed solid.
If this happens don't be tempted to put screwdrivers or anything else into the lock, the slide tumblers in motorcycle locks are easy to bend and damage. In stead flush the lock with WD40 or a very thin penetrating type oil and work the key in and out until the tumblers move freely again even when the lock is working again continue to flush until you are happy that all the sticky stuff has been removed.
My best advise is never to use oil or lubes that don't expressly state on the can that they are suitable for locks.
In the course of a week we strip and rebuild about 50 motorcycle locks about 25% of which have been filled with anything from gear oil to grease and all have jammed.
Locks on motorcycles tend to be overlooked when a service is done on the bike, they are exposed to the elements, when you drop your keys you often transfer grit into the lock, when you take out of your pocket fluff is often attached to them which is then forced into the lock without your knowledge, so locks have a hard life. One squirt of the correct lube at service time will keep them sweet helps prevent jams and reduces wear to the keys.
Ian
Master Locksmith
GL1800
koxx4 is offline
post #29 of 34 (permalink) Old 03-02-2011, 03:29 PM
SabreJoe's Avatar
That is good info Ian, thanks.
SabreJoe is offline
post #30 of 34 (permalink) Old 03-02-2011, 03:43 PM Thread Starter
Silverfox's Avatar
That should prove useful Ian, thanks mate.
Pete
'06 GL1800
'86 GL1200SEi
GL1200 saddlebags, trunk locks locked and no keys pdbro Goldwing Technical Forum 2 06-22-2012 11:22 PM
Keys & locks Brad426 Goldwing Technical Forum 23 07-29-2009 11:56 AM
Thank you Koxx4 for the help and company Silverfox Miscellaneous Forum 23 03-31-2009 09:58 PM
Looking for my wallet & car keys Papajoe Miscellaneous Forum 4 06-26-2008 04:37 PM
