Homemade Bearing removal Tools for gl1200 - Page 3 - Steve Saunders Goldwing Forums
post #21 of 25 (permalink) Old 06-09-2009, 06:50 AM
GSMacLean's Avatar
How hard did you have the screwdriver wedged in the single cut? I found I REALLY had to pound it in there - and make sure it stays in there when you hit the other end.
Read my
GSMacLean is offline
post #22 of 25 (permalink) Old 06-09-2009, 04:06 PM
SKWID12's Avatar
i hit it in with a splitting ax and then hit it good but it kept blowing the screw driver out and wasted the threads
THE BEST PART OF LIFE IS WHEN YOU DONT HAVE TO TAKE YOU FEET OFF THE PEGS!!
SKWID12 is offline
post #23 of 25 (permalink) Old 06-20-2009, 10:14 AM Thread Starter
RayandTracy's Avatar
Thats why I used the cross meathod with a punch. tap punch in really snug then snug bolt to bearing and then tap punch into bolt a little more and you should be able to pop the bearing right out.
Ride Safe, Ray
RayandTracy is offline
post #24 of 25 (permalink) Old 06-21-2009, 01:20 AM
SKWID12's Avatar
thanks for the great advice and all .. the rear wheel is on and turning ,all systems are go 3...2...1...
SKWID12 is offline
post #25 of 25 (permalink) Old 06-21-2009, 03:43 AM Thread Starter
Great News glad you got it goingnow you did clean and inspect that drive flange and re lube it with moly60 while you had the rear tire off didn't you
Ride Safe, Ray
Gold Wing Steering Head Bearing Socket Tools WingMan71 Goldwing Technical Forum 11 08-25-2015 05:18 PM
Homemade clutch repair tools Elgeek General Motorcycle Discussion Forum 3 08-22-2011 11:01 PM
Front wheel bearing removal on GL1200 Xtracho Goldwing Technical Forum 10 05-22-2010 10:43 AM
GL1200 Front Wheel Bearing Removal Frank vH Goldwing Technical Forum 9 05-18-2010 08:51 PM
clutch removal tools lewisjon Goldwing Technical Forum 3 05-14-2006 11:42 PM
