GL1200 Fork Seal Tutorial - Page 13 - Steve Saunders Goldwing Forums
post #121 of 130 (permalink) Old 10-11-2013, 08:26 AM
Model: 86 aspencade
Originally Posted by Steaming Demon View Post
Is this possible without removing tubes from head clamps?
It is a million times easier removing them competely from the bike. Skipping a step isn't always the easier way out.
lucky_strike is offline
post #122 of 130 (permalink) Old 02-26-2014, 08:47 PM
Model: Aspencade
I have drilled out fork caps so I can add oil without removing caps. Do I have to remove caps to change the seals and bushings? I have the fork off and bottom bolt out and was about to remove the cap when I was wondering if the caps only come off in this process to add oil when done.
mccarterj is offline
post #123 of 130 (permalink) Old 02-27-2014, 08:48 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
I did not try leaving the caps on but I think it would be very hard to pull the seals with the springs in there and almost impossible to put the new seals in.
You will need to be able to slide the fork tube to get the seals out. Don't forget to remove the circlip. The spring pressure that makes the cap difficult to install will keep pressure on the circlip. It may even be dangerous to try it without taking the caps off.
Yes
JeffMayfield is offline
post #124 of 130 (permalink) Old 02-27-2014, 09:50 AM
Model: Aspencade
Thanks, off the cap comes tonight.
post #125 of 130 (permalink) Old 03-14-2014, 07:55 AM
Model: 1986 SEi
Very helpful topic, was reading through it all. I am going to do my seals this weekend. This guide looks much better that what is listed in my manual. Thanks
Retired Army,
US Army (1999-2013)
ABATE of MN, VFW, NRA, Wounded Warrior Project
1986 SEi
1984 Aspencade
1983 Interstate (gone)
Support the Military and Veterans- Past, Present, & Future
RetiredArmy is offline
post #126 of 130 (permalink) Old 09-25-2014, 08:16 PM
Wingnoob's Avatar
Looks like one more to do, came home today to oil running down one fork... thanks for the tutorial.
Wingnoob is offline
post #127 of 130 (permalink) Old 04-17-2015, 11:24 PM
Wingnoob's Avatar
Well it's spring and I'm going at this job. Of course some previous owner was in there already and messed up the bottom bolts - completely rounded inside. Slow and steady drilling off the heads of the bolts. Got one fork on the bench right now with the bolt drilled off and the snap ring removed. Didn't come apart right away so I'm going to soak the seal in PB overnight and see what happens.
Wingnoob is offline
post #128 of 130 (permalink) Old 04-18-2015, 10:30 AM
Wingnoob's Avatar
Hmmm I appear to have ordered extra parts. I have here 51415-mb4-003 (labelled Slider Bush) and 51419-mb4-003 (labelled Slider Bush B).
Is the 51419 just a newer version of 51415? 51419 has a groove around the middle of it, 51415 has no groove - they both are the same size and look like they fit in the same place on the fork tube.
Wingnoob is offline
post #129 of 130 (permalink) Old 05-21-2015, 08:01 PM
Quick Cal's Avatar
Model: 84 1200 Interstate
Did you get this figured out. I'm headed there now,,,,lol.
72 Yamaha XS2 650
73 Yamaha TX750
82 Suzuki GS650G
84 GL1200 Interstate
Quick Cal is offline
post #130 of 130 (permalink) Old 05-21-2015, 10:47 PM
jhngardner367's Avatar
Model: 1984 GL1200 I (California)
Honda shows the upper guide bushing as 51414-KCR-003, and the lower slider bushing as a 51419-MB4-003.
The 51415-mb4-003,does come up as a bushing,but not on the GW,as far as I can see.
My stock sliders had no groove,but the replacements did.
I think I would use the 51419.
"I can't fix it ,if it ain't broke...ya want me to break it, first???"
Expect the unexpected. But don't expect the unexpected to be the unexpected you expected !
"I'm busier than a one-legged cat,in a sandbox !"
" Give me a Goldwing,or give me VIAGRA...CUZ either way, I'm Gonna RIDE!!!"
jhngardner367 is offline
GL1200 Fork Oil Seal Installer tool Kalamata Goldwing Technical Forum 6 08-15-2012 08:53 AM
GL1200 left fork seal and antifreeze smell BACA Grizzly Goldwing Technical Forum 7 11-19-2011 11:38 AM
84 gl1200 inter. fork seal replacement. tips. kager2002 Goldwing Technical Forum 4 04-12-2011 02:46 PM
Fork seal for GL1200 wanted - Only need one ! The Gatekeeper For Sale/Wanted Forum 1 11-08-2009 06:44 PM
GL1200 fork seal replacement JOHNO Goldwing Technical Forum 9 09-02-2005 03:59 PM
