How to change GL1500 gear shifter shaft oil seal. With pictures. - Page 3 - Steve Saunders Goldwing Forums
post #21 of 38 (permalink) Old 01-17-2010, 06:17 PM
Lost on this *****
Winger77's Avatar
Model: 1997 Aspy
Send a message via AIM to Winger77
Thanks grambo,,,,,,,,, I did go back to it and got it all cleaned up. It really isn't that bad,,,,, I mean, it has no apparent drip of oil,,,,,, just a light coating around it. But I will still replace it.
Where do you put the sticky sealer?? Just around the outside of it after popping it in??? And would a gasket sealer be ok to use??
The things I liked,,,,I\'ve tried em twice!
You have to be a little Crazy,,,,,, or else you\'ll go Insane.
Winger77 is offline
post #22 of 38 (permalink) Old 01-18-2010, 07:53 AM
SA Wingrider's Avatar
Model: GL 1800 Trike
Very good info and pictures...........Thank You.
Johan.
SA Wingrider is offline
post #23 of 38 (permalink) Old 08-19-2010, 08:17 AM
Robin's Avatar
excellent post, this should be in the workshop how to section.
Long and distant past. CB175, CB400/4, GL1000, 2 GL1100\'s & GL1200 Aspencade.
Then kids came along
Burgman 200 (2007-2009)
BMW RT1150RT (that was awful to ride but pretty) (in 2008).
Burgman 650 Exec from jan 2009 till july 2010.
Got an old but good 1500 SE 1992 in Aug 2010.
Currently wingless.
Robin is offline
post #24 of 38 (permalink) Old 08-19-2010, 08:49 AM
SpiderBob's Avatar
thanks for the pictures, man do they say a thousand words just by themselves.
Spider Bob
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
"If a man does not keep pace with his companions, perhaps, it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away."
Patriot Guard Rider
SpiderBob is offline
post #25 of 38 (permalink) Old 03-07-2011, 03:03 PM
MarioC's Avatar
I'm going to check out my seal today to see if it is leaking. I just finishished rebuilding the clutch slave cylinder while the bike was on the center stand. Hardest part of that was getting the bolt started to hold the bleed tube.
If I leave a place no better than it was when I came, then I have never been there.
MarioC is offline
post #26 of 38 (permalink) Old 05-11-2011, 01:10 PM
Send a message via Yahoo to wncryder
Excellent information. My shifter seal is working it's way out creating a leak so as soon as I can get a replacement seal from my dealer I will attempt to tackle this job hopefully without having to drop the exhaust. A very good tip about the difference in seal sizes, thank you.
Charlie
'98 SE
"Live Free or Die" - New Hampshire state motto
Current Rides:
\'98 Goldwing SE - Black w/ Orange Escapade Trailer
\'07 Suzuki C50 - Wife\'s Bike
wncryder is offline
post #27 of 38 (permalink) Old 06-02-2012, 02:07 PM
bhalvy's Avatar
Great lessson. I was able to remove my seal by only letting down the head / manafold it gave me enough clearance to get the shifter arm and seal out. The pics really helped.
bhalvy is offline
post #28 of 38 (permalink) Old 06-04-2012, 03:54 PM
pippomaranga's Avatar
Model: 2007 NAVI BLACK
[align=center][/align]
i made it and nasty job...
pippomaranga is offline
post #29 of 38 (permalink) Old 06-18-2012, 08:37 AM
I joined specifically for this thread. Thank you!
The Surb is offline
post #30 of 38 (permalink) Old 06-21-2012, 12:47 AM
MarioC's Avatar
Well I did get mine done but I didn't have to take the exhaust header down or take out the engine bolts.
Just a note about cleaning the engine. I used brake cleaner with the extension on it and it did a great job. But you have to be careful to much and you may see some paint flaking as a result.
I took out the three bolts and removed the exhaust cover. Then I took off the carb cover and back cover along with passenger foot rest this gave me a little more room to maneuver around. I used a 1/4 ratchet with a long extension a swivel adapter with a short extension and a 10MM socket to get the bolt completely out of the shifter. You have to work in behind the frame and use one of the fingers on your left hand up between the exhaust to get the socket on the nut. You have to take the nut all the way out. Then I used a screwdriver to pry the shifter apart a little. You can see where to put the long thin blade screwdriver to do it. It is the slot that the bolt tightens when you put it back in.
Now here is the part that makes the difference. I pulled down and to the right and it came right out. I have replaced three shifter seals using this method and have had no problems at all.
Just change your seal and reverse the process.
MarioC is offline
How to replace gl1500 shifter oil seal rphandel Goldwing Technical Forum 6 07-11-2012 07:06 AM
GL1100I SHIFTER SHAFT SEAL htcrkjak Goldwing Technical Forum 3 04-24-2012 06:30 PM
GL1500 Shifter Shaft Seal Steve G Goldwing Technical Forum 4 01-19-2011 06:34 PM
Oil Leak GL1500 at Shifter Shaft Gasket Hawaii Goldwing Technical Forum 15 03-19-2008 04:06 AM
oil seal on gear change bikerfred Goldwing Technical Forum 19 11-16-2005 10:59 AM
