How to change GL1500 gear shifter shaft oil seal. With pictures. - Page 4 - Steve Saunders Goldwing Forums
post #31 of 38 (permalink) Old 07-01-2012, 08:46 PM
thxs nice photos....cant get the spindle shaft past the frame
dogbreath is offline
post #32 of 38 (permalink) Old 07-01-2012, 09:00 PM
MarioC's Avatar
I had that problem as well. I pulled it straight down and towards the rear wheel at the same time. You might have to wiggle it a bit. I hope this helps.
If I leave a place no better than it was when I came, then I have never been there.
MarioC is offline
post #33 of 38 (permalink) Old 09-01-2012, 06:02 AM
Best looking member
Goldwinger's Avatar
Make: Honda, is there any other?
Model: 1997 SE. Pearl Green
Don't forget, if you do drop the header you will need 3 of the copper "O" ring seals to put the header back in place.
Pearl Green(The Intelligent colour)
No question A.T.G.A.T.T. (Even when it's stinking hot!!)
And if it's too stinking hot to gear up, it's too stinking hot to ride.
If your not man enough to take the lead, stop complaining from behind.
I SURVIVED NASSIR 9.... barely.
To all of the troops and Vets. Thank you. I will never forget.
A proud Wild Rhino(Ontario) since 18 Jul 2013 (That mating sound thing really works!!)
Goldwinger is offline
post #34 of 38 (permalink) Old 09-03-2012, 03:55 PM
littlebeaver's Avatar
Model: 1981 Goldwing 1100 I
Nice, I like photo's....
1981 Honda Goldwing 1100 Interstate
littlebeaver is offline
post #35 of 38 (permalink) Old 03-24-2013, 05:35 PM
jjones0187's Avatar
I had to remove the engine mount bolt and the two fame bolts behind the kickstand, then lightly pry the frame over to remove the shifter on my 99' 1500SE, and I bent the first oil seal and had to get another hard to drive the seal in straight with the exhaust in the way but its possible. If u try this get about 2 or three seals before u start, their only bout 2 dollars just in-case u ruin one like I did.
Have GoldWing will travel 82\'1100I 99\'1500SE
jjones0187 is offline
post #36 of 38 (permalink) Old 03-26-2013, 01:41 AM
FM
FM's Avatar
Model: 91-I
Might be able to NOT remove anything...
"IF" you had one of these available.
FM is offline
post #37 of 38 (permalink) Old 11-11-2013, 05:44 AM
Model: Gl1500 SE 1997
http://goldwingdocs.com/forum/viewtopic.php?f=6&t=16399
This guy worked on something to solve that prob.
bigbiker0 is offline
post #38 of 38 (permalink) Old 09-29-2015, 09:32 PM
Model: 1500 SE
I know this is an older post, but it still is great info. Thank you all!
whitewhale is offline
How to replace gl1500 shifter oil seal rphandel Goldwing Technical Forum 6 07-11-2012 07:06 AM
GL1100I SHIFTER SHAFT SEAL htcrkjak Goldwing Technical Forum 3 04-24-2012 06:30 PM
GL1500 Shifter Shaft Seal Steve G Goldwing Technical Forum 4 01-19-2011 06:34 PM
Oil Leak GL1500 at Shifter Shaft Gasket Hawaii Goldwing Technical Forum 15 03-19-2008 04:06 AM
oil seal on gear change bikerfred Goldwing Technical Forum 19 11-16-2005 10:59 AM
